Oil change - Polaris RZR Forum - RZR Forums.net
Oil change
This is a discussion on Oil change within the RZR XP 900 forums, part of the General RZR category; Did my first oil change in my XP900 today and looks like I'm gonna have to go buy a little bit more oil. After changing ...
Old August 6th, 2013, 06:36 PM   #1
GMC13's Avatar
My RZR: 2013 XP 900
Member #57477
View GMC13's Photo Gallery(0)
Oil change
Did my first oil change in my XP900 today and looks like I'm gonna have to go buy a little bit more oil. After changing the oil I checked the level per the manual, run for 30 seconds wait 15 then check and the oil is just barely at the bottom safe mark on the dip stick. Guess just one of those instances where the motor needs just a tiny bit more than normal. This pretty common with the 900 motors? I've noticed over the yrs that sum motors usually require a little more and sum don't.
GMC13 is offline   Reply With Quote
Old August 6th, 2013, 06:58 PM   #2
K-fab's Avatar
My RZR: 2011 XP
Member #36948
View K-fab's Photo Gallery(0)
Re: Oil change
Just did my second change on #1 and checked #2.
#1 (which I've driven like a madman since I got it - break in is warm it up and let it rip, non of that be careful and nice crap) doesn't use a drop. It has 68 hrs on it.
#2 was down about half a quart - it's the "guest" ride - nobody drives it hard. It only has 25 hours on it too.
K-fab is offline   Reply With Quote
Old August 6th, 2013, 08:19 PM   #3
diver165's Avatar
My RZR: 900XP and an 800LE
Member #38076
View diver165's Photo Gallery(0)
Re: Oil change
How much oil did you put in it? Did you use the Polaris kit for the 900XP? It includes 2 1/2qts
_____________________________________
2013 900XP White Lightning Orange Madness
2012 800 Liquid Silver LE
diver165 is offline   Reply With Quote
Old August 6th, 2013, 08:25 PM   #4
GMC13's Avatar
My RZR: 2013 XP 900
Member #57477
Re: Oil change
Yes I used the Polaris kit for the 2013 model. Used all of the oil, all 2 1/2 quarts
Old August 6th, 2013, 09:02 PM   #5
desertrider71's Avatar
My RZR: 2012 XP LE Liquid Silver
Member #45853
View desertrider71's Photo Gallery(0)
Re: Oil change
My 12 XP uses 3.5 per change. Did they lose a quart going to the wet sump ?
desertrider71 is offline   Reply With Quote
Old August 6th, 2013, 09:05 PM   #6
BCRacing24's Avatar
First Name: Brian
My RZR: 2016 XPT-4
Member #20030
View BCRacing24's Photo Gallery(0)
Usa Re: Oil change
Yes.....
Sent from my iPhone 4s using Tapatalk
BCRacing24 is offline   Reply With Quote
Old August 6th, 2013, 09:35 PM   #7
Smooth Moderator
roguedriver's Avatar
First Name: Ken
My RZR: 2011 900XP
Member #24045
View roguedriver's Photo Gallery(0)
Re: Oil change
If you put 2.5qts in, your good. Did you screw the dipstick all the way back in when you checked it?
Ken R.
roguedriver is offline   Reply With Quote
Old August 6th, 2013, 09:37 PM   #8
Scooterdog
scooterdog's Avatar
First Name: Scott
My RZR: SOLD XP 900 Orange / Black Madness LE
Member #24322
View scooterdog's Photo Gallery(0)
Re: Oil change
Hmmm.... My 2012 uses 3.5 qts per change as well
2012 XP 900 Black Orange Madness
PRP GT5050 Seats, Unisteer Power Steering, UTV Giant Doors, UMP Air Intake System, Pro Armor 5 Point Harnesses, Pro Armor Trailing Arm Guards, EMP Full Glass Windshield, Totron 30" Curved 300 watt LED Light Bar, Quick & Bad Harness Restraints, Advance Metal Fabrication Front A-Arm Guards, Tusk Skid Plate, Tusk Rear Bumper,Rear Back Bones Spare Tire Carrier and Spare, Custom Stereo, Mesh Wind-Stopper for summer, Deuce USA rear window (winter), Dual Battery Setup.... Way to much more to go.
scooterdog is offline   Reply With Quote
Old August 6th, 2013, 09:46 PM   #9
GMC13's Avatar
My RZR: 2013 XP 900
Member #57477
Re: Oil change
Dipstick wz all the way in and I used all 2.5 quarts in the kit. Didn't even spill a drop when pouring the oil in the motor. Just expected it to be a little further up the stick than the bottom safe mark.
Old August 6th, 2013, 10:31 PM   #10
Member #45853
Re: Oil change
As BCRacing confirmed, 13 model wet sump lost a quart in the redesign. Yeah for our dry sumps !
Old August 6th, 2013, 10:38 PM   #11
Scooterdog
scooterdog's Avatar
First Name: Scott
Member #24322
Re: Oil change
Ok now I feel like a dummy. Wasn't even thinking about the change from dry to wet sump.
Old August 6th, 2013, 10:41 PM   #12
Member #45853
Re: Oil change
Don't feel bad. I don't think of the wet sumpers either !
Old August 7th, 2013, 05:01 AM   #13
Trailratedcj7's Avatar
First Name: Ted
My RZR: 900 XP LE
Member #57325
View Trailratedcj7's Photo Gallery(0)
Re: Oil change
I just did my 13 the other day with the correct kit from polaris. I was also short on oil so I went and picked some more to top it off.
My Ride: 13' 900 XP LE, Orange Madness
My build thread: http://www.rzrforums.net/members-rid...get-build.html
Trailratedcj7 is offline   Reply With Quote
Old August 7th, 2013, 09:06 AM   #14
GMC13's Avatar
My RZR: 2013 XP 900
Member #57477
Re: Oil change
I'm gonna pick more oil. up to top it off as well. Don't like it barely touching the bottom safe mark
2012 polaris 900 rzr oil change kit
2013 polaris 800s oil change
2013 rzr 900xp top sump oil change
2013 rzr engine oil change
changing oil rzr 900
is it ok to run rzr 900 at max oil mark
oil change instruction rzr 900 xp 2013
oil change kit for 11 polaris rzr xp 900
polaris rzr 900 xp oil change kit to buy
polaris rzr 900xp 4 oil change kit
rzr xp 900 oil change
rzr xp oil change
xp900 2013 oil changr
xp900 what oil for oil change?
Oil Change/Fluid Change........searched jeepnatv4life RZR 570 Specific Discussion 10 July 11th, 2013 10:43 AM
oil change kit Bigred350 Engine and Drivetrain 6 August 22nd, 2012 08:03 PM
Difference Between Oil Change Kit and Extreme Oil Change Kit? olddognewtrick FixMyToys.com 5 May 18th, 2012 11:29 AM
Cam change zefire45 RZR XP 4 900 Specific Discussion 4 March 6th, 2012 08:14 AM
Oil Change nozzleman General RZR Discussion 23 February 27th, 2012 10:19 AM
