2014 Polaris RZR 900 Specs - Polaris RZR Forum - RZR Forums.net
post #1 of 2 Old July 29th, 2013, 05:38 PM Thread Starter
4Nines's Avatar
My RZR: 09 RZR S
Member #5322
View 4Nines's Photo Gallery(1029)
RZRŽ 900
EngineEngine Type4-Stroke DOHC Twin Cylinder
Displacement875cc
Fuel SystemElectronic Fuel Injection
CoolingLiquid
Drive TrainTransmission/Final DriveAutomatic PVT P/R/N/L/H; Shaft
Drive SystemOn-Demand True AWD/2WD
Engine Braking System/ Active Descent ControlNot Equipped
SuspensionFront SuspensionDual A-Arm Fox Podium X 2.0 (comp adjust/res.) 13.5' (34.3 cm) Travel
Rear SuspensionTrailing Arm Fox Podium X 2.0 (comp adjust/res.) 14' (35.6 cm) Travel
BrakesFront/Rear Brakes4-Wheel Hydraulic Disc with Dual-Bore Front Calipers
Parking BrakePark in Transmission
Tires And WheelsFront Tires27 x 9-12; Maxxis Bighorn
Rear Tires27 x 12-12; Maxxis Bighorn
WheelsCast Aluminum
Dimensions / CapacitiesWheelbase81.4' (206.8 cm)
Dry Weight1,190 lbs. (539.8 kg)
Overall Vehicle Size (L x W x H)108.4' x 64' x 73' (275.3 x 162.6 x 185.4 cm)
Ground Clearance13' (33.0 cm)
Seat HeightN.A.
Fuel Capacity7.25 gal (27.4 L)
Bed Box Dimensions (L x W x H)23 x 38 x 10' (58.4 x 96.5 x 25.4 cm)
Front/Rear Rack or Box CapacityN.A./300 lb (136.1 kg)
Payload Capacity740 lb (335.6 kg)
Hitch Towing RatingN.A.
Unbraked Trailer Towing CapacityN.A.
Hitch/TypeNone
FeaturesCargo SystemLock & Ride
LightingWhite LED, High/Low
Electronic Power SteeringAvailable on Limited Edition
InstrumentationDigital Gauge: Speedometer, Odometer, Tripmeter, Tachometer, Coolant Temperature, Volt Meter, Hour Meter, Service Indicator, Clock, Gear Indicator, Fuel Gauge, Hi-Temp Light, Seatbelt Reminder Light; DC Outlet
ColorsColorsIndy Red|Orange Madness LE
4Nines is offline
post #2 of 2 Old July 29th, 2013, 05:48 PM
Dascrow's Avatar
Member #5856
View Dascrow's Photo Gallery(0)
Re: 2014 Polaris RZR 900 Specs
And a few more photos of the 2014 Polaris RZR 900:
Dascrow is offline
2014 Polaris RZR XP 1000 Specs and Information 4Nines Polaris RZR News 536 September 13th, 2013 10:21 AM
2014 Polaris RZR 570 Specs 4Nines RZR 570 Specific Discussion 11 August 31st, 2013 06:54 AM
2014 Polaris RZR 4 900 Specs 4Nines RZR XP 4 900 Specific Discussion 10 August 1st, 2013 10:01 PM
2014 Polaris RZR 800 Specs 4Nines RZR 800 Specific Discussion 17 July 30th, 2013 03:00 PM
2014 Polaris RZR 4 800 Specs 4Nines RZR 4 Specific Discussion 0 July 29th, 2013 05:34 PM
