Polaris pro HD 6000 winch install - Polaris RZR Forum - RZR Forums.net
post #1 of 19 Old July 25th, 2013, 10:07 PM Thread Starter
LukeProducts
LukeProducts's Avatar
First Name: Luke
My RZR: 2013 XP 900
Member #58476
View LukeProducts's Photo Gallery(0)
Just got the new winch from Polaris. I had a 2008 rzr 800 but with tracks it just wasn't enough power. So I upgraded to a 2013 xp 900 limited. I first put my Polaris 3500 on it but I was worried about getting stuck with tracks so when I heard about the all new 6000 I had to have it. My question is has anyone out there modified there rzr to fit this winch? They don't make a bracket for it. I'm sure I will find a way but I was curious if anyone els had done this yet?
LukeProducts is offline
post #2 of 19 Old July 25th, 2013, 10:09 PM Thread Starter
LukeProducts
First Name: Luke
My RZR: 2013 XP 900
Member #58476
Re: Polaris pro HD 6000 winch install
Front of winch
post #3 of 19 Old July 25th, 2013, 11:18 PM
dartersracing's Avatar
First Name: DONNY
My RZR: 2014 PACE Z1 1000
Member #19554
Feedback Score: 14 reviews
that is sweet..
2014 PACE OFF ROAD BUILD Z1 complete
2016 XPT for US! Trail car
DC IMPORT SERVICE INC
Manteca Ca
dartersracing is offline
post #4 of 19 Old July 25th, 2013, 11:20 PM
Hobojon's Avatar
My RZR: 2012 800 le
Member #56466
View Hobojon's Photo Gallery(0)
I havent seen it done. I think the winch motor will hit the frame, especially if you have to add a plate on top of the current winch mount for the larger bolt pattern. You may have to mount it on a bumper rather than behind the radiator.
Curious why you chose the Polaris chinese made winch instead of another mfg?
Or just get a snatch block?
The largest ive heard of being a direct bolt in is the viking 5000. The motor is small....
http://www.google.com/search?q=vikin...bPXCNDZLM3M%3A
2012 800 LE, eps, 27x11x12 HTR's, SATV 1.5" fwd control a-arms (which suck) , hl springs, rear cab divider, cooter roof, moto heater, winch/remote, brushguards, aluminum skids, uhmw sliders, utvgiant doors, air raid intake w/snorkel, rear cage support, 1.5" rear spacers and 1" front, lunatec 30" led light bar, superdave bushings, boss stereo
Hobojon is offline
post #5 of 19 Old July 26th, 2013, 07:10 AM Thread Starter
LukeProducts
First Name: Luke
My RZR: 2013 XP 900
Member #58476
You got me a little worried when you sed it would hit the frame so I slid it in place. Lots of room. The only thing it hits are hoses. As far as the Polaris winch goes. I have had 3 Polaris winches and none of them have failed me. My warn and Ramsey's have. Probably just a cowinsadence but I like the Polaris winches.
post #6 of 19 Old July 26th, 2013, 09:55 AM
Laundryboy's Avatar
First Name: Brian
My RZR: 2012 xp 900 / 2113 xp 900 4
Member #8300
View Laundryboy's Photo Gallery(0)
I thought Polaris was made by Warn, could be wrong I guess.
Laundryboy is offline
post #7 of 19 Old July 26th, 2013, 10:02 AM Thread Starter
LukeProducts
First Name: Luke
My RZR: 2013 XP 900
Member #58476
Some are. The ones that are have a warn logo on them. I think Polaris got away from it compleatly tho.
post #8 of 19 Old July 26th, 2013, 12:57 PM
Riddler6.7's Avatar
First Name: Trevor
My RZR: 14 XP1K
Member #5103
View Riddler6.7's Photo Gallery(1)
Look into what the mounting bolt pattern is. It may be the same as the 4.0 series warn winches and the superwinch terra 4500.... if so then just buy a mounting plate from KFI
2014 XP 1000 Black pearl
Sparks 1065cc, Silber Turbo kit, ARP head studs, Carrillo Rods, 9.0:1 CP Pistons, AEM infinity, Alba STM supertip clutch kit, Crow 5pt Harnesses, 30" CREE dual row light bar, OTRATTW switches, mod quad switch panel, 4' Quicklight, Pawltector parking brake, UTVgiant center seat, KFI stealth 4500 winch, UTVgiant roof, ISOTA lower doors, xp4 tender swap
Riddler6.7 is offline
post #9 of 19 Old September 2nd, 2013, 11:43 PM
Cadiero's Avatar
My RZR: 2011 RZR XP 900
Member #24352
View Cadiero's Photo Gallery(0)
Any updates?? Did it fit?
2016 RZR Turbo
32" Roctanes on GMZ LiteLoc wheels, Zbroz high clearance radius rods, Factory UTV Rocker and Skids, PRP harness, RIGID boxes, Superwinch Terra 4500 wide spool winch, 3P clutch shims, Thunder Hawk hitch, heated seats, Tusk aluminum doors, 3 forward facing LEDs, LED rock lights, home made front tow point. Soon to come: cage, axles, high clearance suspension, shocks re-valved and springs.
Cadiero is offline
post #10 of 19 Old October 9th, 2013, 08:27 PM Thread Starter
LukeProducts
First Name: Luke
My RZR: 2013 XP 900
Member #58476
Sorry I have been super busy lately haven't done much to the rzr. It fit great. Just welded a new plate on top of the old one.
post #11 of 19 Old December 12th, 2013, 09:42 PM Thread Starter
LukeProducts
First Name: Luke
My RZR: 2013 XP 900
Member #58476
Just thought I would do some updates. A buddy of mine just bought the same 6000 after seeing the power and performance of mine. When we went to mount his we disided we hate not seeing the spool when winching. I'm not much for buying things that I can build better so we will be building winch bumpers over the next couple weeks. Ill post more pics as we go.
With 6000 pounds I'm not relying on bolts. I will be building custom plates that weld straight to the lower chassis, and 1 3/4 tube stingers
First thing to go was the plastic on the bottom
post #12 of 19 Old December 15th, 2013, 06:42 AM
Purplezuk's Avatar
First Name: Justin
My RZR: '12 XP4 900
Member #52543
View Purplezuk's Photo Gallery(0)
There aren't any off the shelf bumpers i have seen that would handle a 6k anyways. I bent the emp piece of trash bumper in the first trip with a4k winch, and that was with a Warn winch that keep disengaging under load. ( had it replaced twice and rebuild twice before the 6 month warranty expired, i have the same winch as the polaris on the rear in 3500lb and its been problem free and its been under water and mud repeatedly. I well never buy another Warn atv.winch, and i think very highly of their automotive winches.
Purplezuk is offline
post #13 of 19 Old December 15th, 2013, 07:08 AM
skaget's Avatar
My RZR: 2016 XP1000
Member #31851
View skaget's Photo Gallery(0)
I have the 3500 polaris winch and this last summer i pulled out a maverick and a xp900 4seater at the same time. I love my polaris winch and if i upgrade, it will be the 6000.
skaget is offline
post #14 of 19 Old December 22nd, 2013, 08:26 AM Thread Starter
LukeProducts
First Name: Luke
My RZR: 2013 XP 900
Member #58476
post #15 of 19 Old December 22nd, 2013, 12:27 PM
skaget's Avatar
My RZR: 2016 XP1000
Member #31851
i like how it sits in front like that.
skaget is offline
2011 Polaris Ranger 500 Crew $6000 Sig Ep Mock Polaris RZRs For Sale 1 October 8th, 2012 07:17 AM
Polaris Winch Install Question djk RZR XP 900 7 May 1st, 2012 08:24 PM
viper 3500 winch install with polaris pre-runner brushguard pn 2878282 ruger42 RZR-S Specific Discussion 1 August 20th, 2011 08:21 AM
WTB Remote Winch Control for Polaris 3500 Winch RZRdudeNY Want to Buy 6 January 2nd, 2010 12:10 PM
Winch toggle switch to install on Polaris atv. Oldie Forum Help, Questions and Info 5 November 13th, 2009 05:57 PM
