Max speed seems off on 2013 XP - Polaris RZR Forum - RZR Forums.net
post #1 of 65 Old May 5th, 2013, 10:53 AM Thread Starter
MossLager's Avatar
Curious if any others have this issue and what the most likely cause is. i suspect slack in the throttle cable but that doesn't account or the reported speed. I recently had a nice long (1.5 mile) straight, smooth, slightly down hill, road to put my foot i to my new XP on. It shot out of the hole way better than my old S modl RZR. At about 65 on the speedo it started to stop accelerating. It the inched past 65-66-67-68 up to 70. I could not break 70 on the speedo.... I then checked my trusty Garmin 60Csx which is very accurate, and it showed a top speed of 64.9 mph. My old RZR-S would register 64 on the gps and speedo. So I have some bugs to work out. What is the likely cause of the speedo being off by 4 mph (stock wheel size), and why am I not hitting 74mph? This is a new RZR, with stock belt with less than 100 miles. At 64.9 would I be generating 4mph of rear wheel spin on hardpack going slightly downhill?
2007 Rhino
2010 RZR-S
2013 XP
MossLager is offline
post #2 of 65 Old May 5th, 2013, 10:57 AM
King of crash!
Send a message via Yahoo to johnnycat8
Re: Max speed seems off on 2013 XP
speed off is expected they are not accurate on any sxs but what rpm are you hitting ? this will help in deciding on what could be wrong...
johnnycat8 is offline
post #3 of 65 Old May 5th, 2013, 11:00 AM
Professor
Terse's Avatar
Were you on dirt? Could be wheel spin, not getting traction.
YFZ guru2010 RZR S, Racer Tech 2" lift, 20" and 4x 4" LED lights, Alba modified TS turbo kit, boost ref fuel pressure regulator, Alba exhaust, MCX adjustable clutch set up, Pro Armor seats, UTVInc Low Boy doors, Bruno Motorsports Lightbar Covers, 6" chopped cage, Tusk soft top, Tusk rear view mirror, Bad Dawg fold away side mirrors and grab handles, UTVInc V-brace Intrusion bar
Terse is offline
post #4 of 65 Old May 5th, 2013, 11:01 AM
Feedback Score: 14 reviews
dartersracing's Avatar
some are slower than others, sorry that dont help..i had one of the slow ones & that is why it sits at mcx usa..you should definitely be seeing 70 though on a downhill..i would say you need to adjust your clutching, what rpm is it saying at top speed? clutch kit would be required to make adjustments..
2014 PACE OFF ROAD BUILD Z1 complete
2016 XPT for US! Trail car
DC IMPORT SERVICE INC
Manteca Ca
dartersracing is offline
post #5 of 65 Old May 5th, 2013, 11:28 AM
HIGHOCTANE's Avatar
Any mods? Windshield? Added weight? Was it windy..headwind?
As Johnny said..RPM?
Slight down grade I think you should see 75 + indicated on stock tires. Some are weaker than others but that seems a little too much to account for factory variances in power output IMO. Mine on stock tires would hit 70-72 then creep to 76. On 29.5 swamp lite it still pulls 68-69 indicated..65 pretty quick then creeps up from there.
HIGHOCTANE is offline
post #6 of 65 Old May 5th, 2013, 11:32 AM
BarRZR's Avatar
Clutch problems, or, possibly, not getting enough intake-air. Verify the throttle-plate opening first, then go after the clutch's and belt, and then consider getting more COOL air to your intake/s.
Cheers
BarRZR is offline
post #7 of 65 Old May 5th, 2013, 11:34 AM
HIGHOCTANE's Avatar
He's trying to figure out why his isnt running like a typical XP would..yes check throttle adjustment..cold air intake?why mod a machine to make it perform like it should stock?
post #8 of 65 Old May 5th, 2013, 11:48 AM
King of crash!
bone stock xp with lots of add ons 2 people on gps this was 78 mph
post #9 of 65 Old May 5th, 2013, 12:10 PM
8ball_99's Avatar
My XP4 hits 75 on the road then it starts bouncing off the rev limiter. Thats with a DOM cage, bumpers, roof, doors, front and rear winshield. So I'd say in a lighter two seater you would probably be closer to 80. Honestly though how often you going to run that fast? Mine at 75 feels sketchy at best. If it pulls good up to 65, not sure I'd even worry about it. I've seen what these things look like when they crash at 35. I could only imagine a RZR crash at 75-80 mph.... And at those speeds doing anything but driving in a straight line is pretty out of the question. Atleast with atv tires and stock suspension.
Isn't is it a bit unnerving that doctors call what they do "practice"?
Why do we drive on the parkway and park in the driveway?
Problem with political Jokes is,, they get elected..
8ball_99 is offline
post #10 of 65 Old May 5th, 2013, 12:13 PM
HIGHOCTANE's Avatar
You know how it is..whether you are gonna use it or not when you buy an "extreme performance" machine and you find out yours isn't performing like it should you want to know why..you'd be the same way I bet. Easy to say don't worry about when yours is running well
post #11 of 65 Old May 5th, 2013, 12:22 PM
8ball_99's Avatar
haha yeah I mean I'd want mine to run good. But not really on the top end.. I'd be 100% ok loosing 10-15mph off my top speed for more low end. I'd rather be faster 0-60 then be able to hit 80mph on the road.
8ball_99 is offline
post #12 of 65 Old May 5th, 2013, 12:25 PM
HIGHOCTANE's Avatar
I can agree with that..but of yours didn't hit the "normal" top speed would that make you wonder if it was also accelerating 0-60 slower than "normal"?
post #13 of 65 Old May 5th, 2013, 12:27 PM
Beach Leo's Avatar
What was the elevation?
I know the higher you go
The slower she goes
You are only Remembered in Life, By your Kindness
Beach Leo is offline
post #14 of 65 Old May 5th, 2013, 12:28 PM
HIGHOCTANE's Avatar
The slower she goes
Very good point!
post #15 of 65 Old May 5th, 2013, 12:29 PM
Yamahaloverhas900xp's Avatar
We have a couple of 13's in your group of about 20 xp's. We do a lot of pavement riding. Most all have stock wheels. All the 13's are all slower than the the 11's and 12's all though they still hit the same rev limiter at the same 8550. I have a friend that has been trying to figure out why but hasn't had any luck? All of the 11's and 12' run anywhere from 75 to 77 mph on pavement. The 13's run from 69 to 73. All where radar gun verified one day when we where ridin. There where some unhappy 13 owners that day to say the least. Could it be the wetsump robbing power? Or a change in the clutch setup from Polaris?
Yamahaloverhas900xp is offline
2013 Walker Evans 2013 Shocks ktm300guy Polaris RZR Parts For Sale 15 November 9th, 2013 05:01 PM
2013 xp tire size and top speed Masonw05 RZR XP 900 7 March 5th, 2013 07:22 AM
2013 RZR XP ,and A Ranger 900 ,and a 2013 RZR 900 4 at the TAYLOR PARK CO. ride !!!!! FJK General RZR Discussion 65 August 12th, 2012 03:08 PM
Top speed 50 MPH ??? SuperBuys Engine and Drivetrain 14 March 21st, 2010 06:53 PM
Speed Key or similar mod to limit top speed? Pottery_Pal General RZR Discussion 2 March 19th, 2009 06:05 PM
