Snorkeling...questions. - Polaris RZR Forum - RZR Forums.net
This is a discussion on Snorkeling...questions. within the RZR XP 900 forums, part of the General RZR category; This is definitely in my future, but after doing some research I have 2 questions. Pics I've seen; some people have 3 pipes, some have ...
Old April 23rd, 2013, 10:20 AM   #1
billabongcr's Avatar
Member #54606
View billabongcr's Photo Gallery(0)
This is definitely in my future, but after doing some research I have 2 questions. Pics I've seen; some people have 3 pipes, some have 4. Air intake, belt intake, belt exhaust... what's #4?!
Also, what all needs to be extended and relocated? Front diff, rear diff, trans, transfer case, fuel tank, bottom of throttle body, rad overflow tank and crank case...am I missing any? And are there 1 or 2 on the crank case?
Any unforeseen issues while installing I could learn from? Thanks in advance!
billabongcr is offline   Reply With Quote
Old April 23rd, 2013, 10:51 AM   #2
Fourteen's Avatar
Member #49841
View Fourteen's Photo Gallery(0)
Re: Snorkeling...questions.
About to do mine and the fourth pipe you are seeing is an additional air intake. I am going to do one 3" for the air intake and then 2" for the belt intake and exhaust.
Fourteen is offline   Reply With Quote
Old April 23rd, 2013, 11:33 AM   #3
VtecGSR95's Avatar
First Name: Frank
My RZR: 2011 RZR XP 900
Member #1482
View VtecGSR95's Photo Gallery(0)
I tried doing a single 3" intake (assuming this is a 900), and the bed didnt fit right. It was squishing down on the soft rubber 3" hose, and I didnt like that. Eventually, this would lead to a problem.
I ended up running a single 3" on the drivers side, and added a second 2" on the passenger side. I also ran a 2" for the CVT exhaust next to the pipe on the drivers side, as well as a 2" for the CVT intake on the pass. side. However, in an effort to make things look symmetrical, I used a 3"-2" coupler and ran a 3" pipe on the CVT intake on pass. side where it poles through the bed. Didnt wanna have a 3" on one side, and (2) 2" pipes on the other!
Its not as nice as I planned in the beginning but it works and it adds some extra airflow so Im ok with it.
2011 RZR XP 900:Alba Stage 2~SLP Muffler~Holz Mounts~PCV~28" Gators
VtecGSR95 is offline   Reply With Quote
snorkeling a 900xp
snorkeling a rzr with two pipes
snorkeling 800 rzr rglover RZR 800 Specific Discussion 16 March 15th, 2013 05:55 AM
Snorkeling Myths? Brunse General RZR Discussion 12 March 2nd, 2012 01:06 PM
Snorkeling and Dirt TheGriz RZR 170 Specific Disccusion 8 April 21st, 2010 09:46 AM
Snorkeling for cleaner air?? Airborne LT RZR-S Specific Discussion 7 August 25th, 2009 04:07 PM
Snorkeling The RZR (the right way) HivoltageRZR General RZR Discussion 2 March 2nd, 2009 08:15 PM
