Won't do anything! No Power - Polaris RZR Forum - RZR Forums.net
This is a discussion on Won't do anything! No Power within the RZR XP 900 forums, part of the General RZR category; Turn key and nothing. No power to speedometer. Thought it was just dead so hooked jumpers up and still nothing. Battery has power to spark ...
Old April 19th, 2013, 03:12 PM   #1
Big Kel's Avatar
First Name: Kelley
My RZR: 2012 XP900 and a 2010 800
Member #23199
View Big Kel's Photo Gallery(0)
Cool Won't do anything! No Power
Turn key and nothing. No power to speedometer. Thought it was just dead so hooked jumpers up and still nothing. Battery has power to spark cables so should light up dash. All known fuses good. Friend coming over with voltage meter to start testing but I don't even know where to start. Also cables tight and main ground tight. I can start following hot wires but certainly out of my element. What direction. This has to be something that stops everything. Didn't check the larger plug ins in the fuse box. Just the small fuses.
Big Kel is offline   Reply With Quote
Old April 19th, 2013, 03:18 PM   #2
sandblster's Avatar
Member #46247
Re: Won't do anything! No Power
Start with a battery test for over 12 volts is the first thing. Sparking cables means nothing. Then ALL fuses. Then battery voltage into and out of ignition switch. Then starter solenoid. Download manual and follow the troubleshooting flow chart in back. Good luck.
sandblster is offline   Reply With Quote
Old April 19th, 2013, 03:27 PM   #3
Big Kel's Avatar
First Name: Kelley
Member #23199
Is the solenoid the small gold part that is what the main battery cable goes to? What is the electrical control box? Behind the Seat?
Old April 19th, 2013, 03:31 PM   #4
sandblster's Avatar
Member #46247
Yes, has two battery cables and two smaller wires from the ignition switch. The box behind the seat is the ECU module, i.e. engine computer.
Old April 19th, 2013, 07:01 PM   #5
DVRod's Avatar
First Name: Doug
My RZR: 2011 RZR 900 XP and 2015 Ranger 900 Highlifter
Member #19968
View DVRod's Photo Gallery(0)
check your circuit breaker to see if voltage is passing through
Name:	circuit breaker.jpg
DVRod is offline   Reply With Quote
Old April 22nd, 2013, 09:06 AM   #6
Big Kel's Avatar
First Name: Kelley
Member #23199
Thanks for the answers and suggestions. I had tried to jump it off and even then I didn't have cluster lights so I assumed I had more than a battery problem. Wrong. I didn't have good cable connection so made a wrong assumption. Batt was dead so now I have to figure what killed it. Thanks
Old June 9th, 2013, 12:06 PM   #7
rzrtodd40's Avatar
My RZR: RZR 900 XP
Member #30881
View rzrtodd40's Photo Gallery(0)
My buddy having similar problems. Did you figure out what was draining your battery...
2011 900 XP White LE
Pulled by 2007 Tundra 5.7
Protected by Kimber
rzrtodd40 is offline   Reply With Quote
Old June 9th, 2013, 02:38 PM   #8
Big Kel's Avatar
First Name: Kelley
Member #23199
Not sure if we found anything or not. Have not had any problem since. My friend noticed a tail light on later when it shouldn't have been. He has an 800 that if he leaves the key in the ignition it will go dead. Kept key out of it for a while but it's in it now and no problems so I know something was up but hasn't reoccurred.
2011 polaris rzr wont do anything
2013 polaris rzr no power
2013 rzr 800s no power
2013 rzr 900 xp draining the battery while key is off
2013 rzr no lights
2014 rzr 800 battery dead
900 rzr good battery no power
my rzr 800 has no power to switch
no power on a my rzr 900 at all
no power to the ignition switch 2014 rzr 800
polaris ranger no power to ignition
polaris rzr dash dies when i turn key
polaris rzr not starting no lights
rzr 900 has no power to computer
what makes a rzr get no power
NO POWER TO STARTER????? POWER AT SOLENOID Will not start?? cheshier2 RZR-S Specific Discussion 3 March 29th, 2012 03:25 PM
power jarvis11 RZR-S Specific Discussion 3 September 6th, 2011 03:49 PM
Help with Big Gun Power Box Chief131 Forced Induction 0 April 21st, 2011 09:01 PM
Winch power leads and 1314 Sure Power tachdriver General RZR Discussion 4 November 22nd, 2010 02:49 AM
HELP!!!!!Looking To Add some Power to the 08 rzr need Help bigbronco1638 Engine and Drivetrain 6 November 30th, 2009 04:59 PM
