Buying used 900... What to look for?? - Polaris RZR Forum - RZR Forums.net
This is a discussion on Buying used 900... What to look for?? within the RZR XP 900 forums, part of the General RZR category; Im picking up a used 900 le non-eps tomorrow from a private party. My question is their anything specific weakness' that I should look for ...
Old February 12th, 2013, 05:11 PM   #1
marwilli's Avatar
Member #50905
View marwilli's Photo Gallery(0)
Im picking up a used 900 le non-eps tomorrow from a private party. My question is their anything specific weakness' that I should look for on this machine. ie, frame, engine case, differential, noises ect... Thanks in advance!
Forgot to mention it has 100hrs and 1000 miles
marwilli is offline   Reply With Quote
Old February 12th, 2013, 05:19 PM   #2
domestictuner's Avatar
Member #21859
View domestictuner's Photo Gallery(23)
Re: Buying used 900... What to look for??
wore out/bent suspension mounts, dusted throttle body, broken engine mounts, wore out prop shaft bearing, bent axles
domestictuner is offline   Reply With Quote
Old February 12th, 2013, 05:31 PM   #3
marwilli's Avatar
Member #50905
What is a "dusted throttle body"
It does have a factory warranty until sept 2014
Old February 12th, 2013, 06:17 PM   #4
JiAnthony315's Avatar
First Name: Ji
My RZR: 2013 XP 900
Member #36958
View JiAnthony315's Photo Gallery(1)
Make sure there isnt sand or dirt in the throttle body is what I think he means but may be wrong..
The XPs tend to get sand past the air filter to becuase the airbox doesnt seal that great..Check the clean/motor side of the air box for exsesive sand or dirt..
2013 XP, Pro Armor Doors and 4pt Harnesses
Racertech dual rate springs, SATV Nerf bars
Polaris lock-n-ride roof & Windshield, Knine Axle Armors
SSV Works overhead 4 speaker System, Blue LED lights
Custom Legue Graphics Kit
JiAnthony315 is offline   Reply With Quote
Old February 12th, 2013, 06:33 PM   #5
marwilli's Avatar
Member #50905
Ahhh I get it.. Thanks for the explanation.
Old February 12th, 2013, 06:51 PM   #6
Feedback Score: 14 reviews
dartersracing's Avatar
First Name: DONNY
My RZR: 2014 PACE Z1 1000
Member #19554
Check for cracked case form trans/motor mount area.
2014 PACE OFF ROAD BUILD Z1 complete
2016 XPT for US! Trail car
DC IMPORT SERVICE INC
Manteca Ca
dartersracing is offline   Reply With Quote
Old February 12th, 2013, 08:09 PM   #7
Feedback Score: 8 reviews
rxutv's Avatar
First Name: RXUTV
My RZR: XP4-XP1K
Member #45286
View rxutv's Photo Gallery(0)
notice when pulling out the air filter if he has been greasing the edge of the air filter you hope to see grease. jmy2c
rxutv is offline   Reply With Quote
Old February 12th, 2013, 08:57 PM   #8
flasher's Avatar
First Name: Tim
My RZR: 2012 voodo blue xp900
Member #49789
View flasher's Photo Gallery(0)
Look under the rear gear box where it bolts together,you have to get on the pass side just in front of the rear tire,get low and look between trans and skid plate,if it looks like its leaking where the case bolts together it will cost 500 to fix,i found out the hard way,they had problems sealing from the factory,good luck
MSSHOCKS.COM
flasher is offline   Reply With Quote
Old February 13th, 2013, 05:06 AM   #9
marwilli's Avatar
Member #50905
Thanks alot for the info guys! I can't wait to get it today just hope it's as clean as it looks in the pics.
Old February 13th, 2013, 05:31 AM   #10
DoinIt's Avatar
First Name: Todd
My RZR: 2016 XP1K4 Electric Blue
Member #43515
View DoinIt's Photo Gallery(0)
The owner should be able to prove service was done at 25, 50, and 100 hours. If the 100 hour service has not been done you'll want to do that right away and keep it on it's minimum service schedule. I would get the vin and talk to the local dealer and see if any service bulletins were issued. What year model is it? 2011 had to have some heat shields installed. Drive it off road if possible, you'll get a better feel for it than just driving it down the street.
Hope it works out for you, they are a blast to drive.
DoinIt is offline   Reply With Quote
buy used razer 900
buying a polaris rzr 900 what to look for
buying a used rzr xp
buying polaris rzr used what to look for
buying used polaris rzr 900
how to inspect a used polaris razor
what to look buying used rzr
what to look for on used polaris 900 ranger
what to look for when buying a polaris rzr
what to look for when buying a rzr
what to look for when buying a used polaris ranger
what to look for when buying a used polaris razor
what to look for when buying a used rzr
what to look for when buying a used rzr 900
what to look for when buying rzr900
Buying a RZR amoyers General RZR Discussion 9 October 14th, 2012 08:25 AM
HELP! buying first rzr... What to look for? skyler.hager General RZR Discussion 22 February 24th, 2012 06:25 PM
buying a rzr randym975 General RZR Discussion 6 January 19th, 2010 02:19 PM
Buying used Andrew Willingham Forum Help, Questions and Info 35 January 8th, 2010 11:27 PM
what to look for buying used SXR Nathan General RZR Discussion 5 November 18th, 2009 11:20 PM
