2014 Polaris RZR 4 900 Specs - Polaris RZR Forum - RZR Forums.net
This is a discussion on 2014 Polaris RZR 4 900 Specs within the RZR XP 4 900 Specific Discussion forums, part of the General RZR category; RZRŪ 4 900 Engine Engine Type 4-Stroke DOHC Twin Cylinder Displacement 875cc Fuel System Electronic Fuel Injection Cooling Liquid Drive Train Transmission/Final Drive Automatic PVT ...
Go Back   Polaris RZR Forum - RZR Forums.net > General RZR > RZR XP 4 900 Specific Discussion
RZR XP 4 900 Specific Discussion For all specific information pertaining to the Polaris RZR XP 4 900.
Old July 29th, 2013, 06:36 PM   #1
4Nines's Avatar
My RZR: 09 RZR S
Member #5322
View 4Nines's Photo Gallery(1029)
RZRŪ 4 900
EngineEngine Type4-Stroke DOHC Twin Cylinder
Displacement875cc
Fuel SystemElectronic Fuel Injection
CoolingLiquid
Drive TrainTransmission/Final DriveAutomatic PVT P/R/N/L/H; Shaft
Drive SystemOn-Demand True AWD/2WD
Engine Braking System/ Active Descent ControlNot Equipped
SuspensionFront SuspensionDual A-Arm Walker Evans 2' body (comp adjust/res.) 13.5' (34.3 cm) Travel
Rear SuspensionTrailing Arm Walker Evans 2.5' body (comp adjust/res.) 14' (35.6 cm) Travel
BrakesFront/Rear Brakes4-Wheel Hydraulic Disc with Dual-Bore Front and Rear Calipers
Parking BrakePark in Transmission
Tires And WheelsFront Tires27 x 9-12; Maxxis Bighorn
Rear Tires27 x 12-12; Maxxis Bighorn
WheelsCast Aluminum
Dimensions / CapacitiesWheelbase107.4' ( 272.8 cm)
Dry Weight1,422 lbs. (645 kg)
Overall Vehicle Size (L x W x H)134.4' x 64' x 77' (341.4 x 162.6 x 195.6 cm)
Ground Clearance13' (33 cm)
Seat HeightN.A.
Fuel Capacity7.25 gal (27.4 L)
Bed Box Dimensions (L x W x H)23 x 38 x 10' (58.4 x 96.5 x 25.4 cm)
Front/Rear Rack or Box CapacityN.A./300 lb (136.1 kg)
Payload Capacity900 lb (408.2 kg)
Hitch Towing RatingN.A.
Unbraked Trailer Towing CapacityN.A.
Hitch/TypeNone
FeaturesCargo SystemLock & Ride
LightingWhite LED, High/Low
Electronic Power SteeringStandard
InstrumentationDigital Gauge: Speedometer, Odometer, Tripmeter, Tachometer, Coolant Temperature, Volt Meter, Hour Meter, Service Indicator, Clock, Gear Indicator, Fuel Gauge, Hi-Temp Light, Seatbelt Reminder Light; DC Outlet
ColorsColorsOrange Madness
4Nines is offline   Reply With Quote
Old July 29th, 2013, 08:07 PM   #2
lxh0318's Avatar
Member #26737
View lxh0318's Photo Gallery(0)
Re: 2014 Polaris RZR 4 900 Specs
So does this mean there won't be a 4 seat XP1000 for 2014?
lxh0318 is offline   Reply With Quote
Old July 30th, 2013, 04:48 PM   #3
gunguy's Avatar
Member #9667
View gunguy's Photo Gallery(0)
It look that way, so is the new 1000 just a bored out 900?
gunguy is offline   Reply With Quote
Old July 30th, 2013, 05:17 PM   #4
Atpalmer's Avatar
My RZR: XP4 900
Member #49255
View Atpalmer's Photo Gallery(0)
Are there any differences between the 2014 and 2013 rzr XP 4's?
Atpalmer is offline   Reply With Quote
Old August 1st, 2013, 01:42 PM   #5
Feedback Score: 6 reviews
ItsAVROD's Avatar
My RZR: 2013 WER XP4 900
Member #6423
View ItsAVROD's Photo Gallery(0)
Any one know?
ItsAVROD is online now   Reply With Quote
Old August 1st, 2013, 01:45 PM   #6
Txjole's Avatar
First Name: Joe
My RZR: 2013 XP4 Walker Evans
Member #52971
View Txjole's Photo Gallery(0)
Spec on paper NO.
2013 RZR XP4 WE
Txjole is offline   Reply With Quote
Old August 1st, 2013, 01:54 PM   #7
protraxduner's Avatar
My RZR: 2013 XP900 4 SDR/HCR
Member #49019
View protraxduner's Photo Gallery(0)
not sure if its a mistype or not. previous rzr 4 900 said dual bore 'front' calipers only now it says front and rear. rzr 900 2 seaters still say front and the rzr 1000 says dual bore front and rear. I know my 2013 xp 4 900 has single piston rear calipers
protraxduner is offline   Reply With Quote
Old August 1st, 2013, 02:02 PM   #8
8ball_99's Avatar
My RZR: 2013 Black RZR4 XP LE
Member #7209
View 8ball_99's Photo Gallery(0)
I wouldn't think so that's like saying there won't be a XP1000 for 2014 cause they still have a 900. There is a 800 4 and a XP900 4. I'd be surprised if they don't have a XP1000 4 sooner or later. The real question, is since the 1000 is 11 inches longer then the 900 2 seater. If this is the same with the 4 seat 1000 that's going to be a long SOB... Would make it 144" long. For anyone who has seen a wild cat four in person they are 149" long.....
Isn't is it a bit unnerving that doctors call what they do "practice"?
Why do we drive on the parkway and park in the driveway?
Problem with political Jokes is,, they get elected..
8ball_99 is offline   Reply With Quote
Old August 1st, 2013, 03:01 PM   #9
Txjole's Avatar
First Name: Joe
Member #52971
Polaris comment on Facebook today when asked about the 1xp4, "that engineers are hard at work all the time, but no comment on future rzr products"
2013 RZR XP4 WE
Old August 1st, 2013, 03:36 PM   #10
Feedback Score: 5 reviews
tightline's Avatar
My RZR: RZR 4 XP
Member #3399
View tightline's Photo Gallery(0)
On the EPA papers listed for emissions they listed a 1k XP4. It is just a matter of when it will be released and like 8 ball stated. The real question is how long is this thing going to be. If it is the same length as the current 900 I am very interested and will sell right away. If it is longer I need to really think about it.
tightline is offline   Reply With Quote
Old August 1st, 2013, 11:01 PM   #11
donhd04's Avatar
First Name: Don
Member #11996
View donhd04's Photo Gallery(0)
I totally agree. They make it longer and it will take 35's just to clear a small mound.
donhd04 is offline   Reply With Quote
2013 rzr 900 4 seater specs
2013 rzr xp 4 900 specs
2014 polaris rzr 4 900 specs
2014 polaris rzr 900 2 seater length
2014 polaris rzr 900 4 specs
2014 polaris rzr 900 xp4 length
2014 polaris rzr4 xp900 specs
2014 rzr 4 900 specs
2014 rzr 900 4 specs
2014 rzr 900 dimensions
2014 rzr 900 specs
polaris
polaris rzr 900 xp 4 for sale overall lenth
rzr 900 xp4 specs
rzr xp4 900 dimensions
2014 Polaris RZR XP 1000 Specs and Information 4Nines Polaris RZR News 536 September 13th, 2013 11:21 AM
2014 Polaris RZR 570 Specs 4Nines RZR 570 Specific Discussion 11 August 31st, 2013 07:54 AM
Polaris Introduces The 2014 Lineup 4Nines Polaris RZR News 1 July 29th, 2013 09:51 PM
2014 Polaris RZR 4 800 Specs 4Nines RZR 4 Specific Discussion 0 July 29th, 2013 06:34 PM
Pic of the Polaris new 2014 RZR? jmart233 General RZR Discussion 1 July 16th, 2013 09:29 PM
