wiring help with switches Polaris to UTV Inc - Polaris RZR Forum - RZR Forums.net
This is a discussion on wiring help with switches Polaris to UTV Inc within the RZR XP 4 1000 forums, part of the General RZR category; I am trying to replace the stock head light switch with the one from utv inc switch. Polaris switch has five plugs in the back ...
Go Back   Polaris RZR Forum - RZR Forums.net > General RZR > RZR XP 4 1000
Old November 10th, 2013, 11:55 AM   #1
tpollock33's Avatar
First Name: Travis
My RZR: XP1000
Member #45974
View tpollock33's Photo Gallery(0)
I am trying to replace the stock head light switch with the one from utv inc switch. Polaris switch has five plugs in the back and utv inc only have four. Everything works but the switch wont light up. Anyone run into this problem and have a fix. Thanks
tpollock33 is offline   Reply With Quote
Old November 10th, 2013, 01:43 PM   #2
coffeeguy's Avatar
First Name: Kelly
My RZR: 13' 800 S LE
Member #60005
View coffeeguy's Photo Gallery(0)
Re: wiring help with switches Polaris to UTV Inc
Haven't seen the switch, perhaps you need a jumper from the lead that feeds the headlights so the switch illuminates.
Sent from my iPhone using RZRForums.net mobile app
13' 800 S LE
coffeeguy is offline   Reply With Quote
Old November 10th, 2013, 05:08 PM   #3
Owner-Light it Up Offroad
Feedback Score: 16 reviews
MATT1524's Avatar
First Name: Matt
My RZR: 2016-Turbo 4
Member #13639
View MATT1524's Photo Gallery(0)
Seems like to make the factory ones work it had to be a special switch. Double pole double throw? Cant recall. I have 5 of them wired up but not the factory switches.
Give nick a call sure he can tell you.
Here is what i followed...
We Sell: Totron, Viper, Rigid, PRP & MORE!
CALL 479-222-5398
479-434-4161
WWW.GETLITFS.COM
Your one stop shop for all your UTV & Truck needs!
We have a REAL store front!
3201 Wheeler Ave-Fort Smith, Arkansas
MATT1524 is online now   Reply With Quote
Old November 15th, 2013, 06:38 AM   #4
poolman's Avatar
Member #6919
View poolman's Photo Gallery(0)
Without seeing the switch I am just guessing but if the only problem is the light in the switch won't light up, it is probably missing the ground. The switch is just dealing with 12 volts out to the lights but when you have an led inside the switch, you need to supply the ground. Give UTV a call and see if you can get a diagram of how their switch is arranged.
poolman is offline   Reply With Quote
Old November 15th, 2013, 07:45 AM   #5
Feedback Score: 8 reviews
UTV Inc.'s Avatar
First Name: UTV INC
Member #184
here is a diagram:
UTV Inc. is online now   Reply With Quote
Old November 15th, 2013, 07:47 AM   #6
UTV Inc.'s Avatar
First Name: UTV INC
Member #184
The top LEFT prong is the 12v in for the LED. so however you want that to turn on would be based on you.
If you want the LED to turn on when the switch is turned "on", wire it as above.
If you want the LED to turn on when the key is in the on position, then wire it to a hot ignition wire.
Hope this helps?
Old November 15th, 2013, 10:35 AM   #7
tpollock33's Avatar
First Name: Travis
My RZR: XP1000
Member #45974
Got it fixed. The Stock switch comes with two grounds at the top of the switch you remove the one for jumper for led. Then you take out the bottom jumper for led and put that where you just took out the ground one. Then on the stock switch there is a prong right beside the jumper for led at the bottom and you move it over to the bottom jumper for led and it works. The spare ground just heat shrink it up and it will not be reused. Figure i would post the answer to my own question in case someone else runs into the same problem. Thanks UTV Inc and Johnny swtichs look awesome.
Old December 16th, 2013, 05:50 PM   #8
rzrxpdude's Avatar
Member #61933
View rzrxpdude's Photo Gallery(0)
So did you loose the functionality of low and high beam?
2011 RZR XP 900 EPS Street Legal
Stealth Black Plastics & Custom Reflective Red Decals
2" Extreme Lift w/ 30" Motoclaw's on 14" M20's
Pro armor suicide doors, 4 - 6.5" Kicker sound system, American Rock Rods dash plates, UTVinc switches, Dragonfire Front & Rear Bumpers w/ 12" LED Bar, Simpson 5pt harnesses
rzrxpdude is offline   Reply With Quote
Old December 17th, 2013, 07:18 AM   #9
tpollock33's Avatar
First Name: Travis
My RZR: XP1000
Member #45974
I did not do that switch yet but you probably would. This wiring help was for buying stock wiring harness with swtichs. So i replaced the stock swtiches with the new ones from UTV INC. I will be doing the headlight switch soon and when i do i will post what the fix is for that.
Old October 6th, 2014, 11:23 PM   #10
Aln
Aln's Avatar
First Name: Al
My RZR: 2015 900 White Lightning
Member #71064
View Aln's Photo Gallery(0)
Do you have a similar drawing for the 8 terminal winch switch (SKU 3352) that I recently ordered? I ordered a horn switch and have wired that, it looks great, just like factory. The winch switch that I currently have has only 3 terminals/wires and I am a little puzzled as to which of the 8 terminals on the new switch I connect them to.
Thanks, they are a great looking product and you shipped to Canada very quickly.
Aln is offline   Reply With Quote
Old December 12th, 2015, 04:42 PM   #11
joekamkod's Avatar
First Name: Joe
My RZR: 2016 turbo 2016 xp1000 2017 general 4
Member #27276
View joekamkod's Photo Gallery(0)
I need help with the winch switch I received also it works but can't figure out how to get it to light up ????? It has 8 pins in the back got them from utv inc .
joekamkod is online now   Reply With Quote
2012 polaris rzr headlight switch
2014 rzr 800 light switch wire harness
2016 rzr 1000s switch wiring
how to wire rzr switches
polaris 4011500 switch wiring diagram
polaris rzr 1000 wiring diagram
polaris switch schematic
rzr 1000 headlight harness diagram
rzr 1000 headlight switch
rzr 1000 wiring harness diagram
rzr light swith terminals
rzr switch wire
universal ignition switch wiring diagram for rzr 800
wiring new polaris switch
RZR1000 Dash Switches (Where to buy additional switches) 14.RZR1000 RZR XP 1000 6 November 24th, 2013 08:55 PM
Utv inc polaris rzr xp 1000 oil pressure wiring kit UTV Inc. UTV Inc 2 October 19th, 2013 07:09 AM
Swapping switches on LED universal wiring harness RainemMan General RZR Discussion 6 August 16th, 2013 12:28 PM
Polaris GPS Wiring NCsledhead Lighting, Stereo and Electrical 3 January 14th, 2013 08:58 PM
Polaris Wireless Remote wiring help. Fimea General RZR Discussion 0 October 4th, 2012 02:13 AM
