2017 rzr xp1k suspension - Polaris RZR Forum - RZR Forums.net
 6Likes
post #1 of 30 Old May 18th, 2017, 07:16 PM Thread Starter
adambomer3's Avatar
First Name: Adam
My RZR: 2014 900XP Stealth Black
Member #83822
View adambomer3's Photo Gallery(0)
Anyone done any upgrading to the factory shocks/springs? I'm unhappy with the stock ride/ sag. Currently looking at shock therapy dual rates and valving. But feedback is always nice if someone else has any other ideas Click image for larger version
ID:	424993Click image for larger version
adambomer3 is offline
post #2 of 30 Old May 18th, 2017, 07:31 PM
Expat's Avatar
First Name: Larry
My RZR: 2016 Turbo
Member #75196
View Expat's Photo Gallery(0)
Re: 2017 rzr xp1k suspension
It will be the best money you spend on your machine. I just had it done to my XPT and my buddy to his 2014 XP and the differance is amazing. You gain 2 to 3 inches in ride height and your machine will ride about twice as good as a new turbo does.
Motoman314 likes this.
2016 XPT Spectra Orange
Method 405s with 31x11.50x15 Super Swamper LTBs and a few other things
Review and info on my accessories
Expat is offline
post #3 of 30 Old May 19th, 2017, 07:18 AM
TOD
TOD's Avatar
My RZR: 2015 XP 1000 4
Member #81636
View TOD's Photo Gallery(0)
I put the Shock Therapy Springs and revalve on my 2015 XP4 and it was worth every penny. Should have been the first upgrade to my machine.
TOD is offline
post #4 of 30 Old May 19th, 2017, 10:12 AM Thread Starter
adambomer3's Avatar
First Name: Adam
Member #83822
Hmm from the sounds of it I should go with the shock therapy idea
post #5 of 30 Old May 19th, 2017, 12:03 PM
SHPirate's Avatar
My RZR: 2016 RZR XP 1000
Member #178857
View SHPirate's Photo Gallery(0)
I just put a shock therapy stage 4 spring kit on my 2016 XP 1000. The change is night and day AWESOME. Because I added front and rear bumpers, rock sliders, skid plate, roof with stereo, winch and spare tire, my suspension was collapsed. With the shock therapy stage 4 spring kit my RZR is 3-4 inches higher than stock and rides like a pillow. I honestly think having the suspension revalved is overkill and not necessary (Unless you are racing or doing some serious jumping).
My stage 4 kit is one of the best mods I've done to my RZR.
SHPirate is offline
post #6 of 30 Old May 19th, 2017, 01:33 PM
TOD
TOD's Avatar
Member #81636
I would agree. My buddy just put the springs on his XP4 and the improvement was great. I couldn't really justify the revalve...
TOD is offline
post #7 of 30 Old May 19th, 2017, 02:17 PM
RZRWorks's Avatar
First Name: Carl
My RZR: 2016 XP1K
Member #132361
View RZRWorks's Photo Gallery(0)
Depends on how you ride. Medium to fast riding, you bet, Shock Therapy is probably what you want. Slow technical riding, revalve is not necessary, new tender springs will do the job
2016 XP1K, RZR Works aluminum diamond plate roof, RZR Works spare tire carrier, RZR Works Rock Slyders, RZR Brake Lok, 30-10-14 Roctanes on Method 401 wheels, aftermarket tender springs front and rear, Super ATV 1/2" skid, Factory UTV trailing arm guards, Polaris retractable harnesses. Gen II Duraclutch from Hunterworks, 21% reduction low gear only, Much more to come...
RZRWorks is offline
post #8 of 30 Old May 19th, 2017, 03:46 PM Thread Starter
adambomer3's Avatar
First Name: Adam
Member #83822
Yea I've pretty much made my mind up on the new springs but can't decide on the valve. I know something has to change. I ride about everything some days it might be slow speed crawling stuff others high speed trails hit water breaks and stuff.
post #9 of 30 Old May 20th, 2017, 08:46 AM
rzron800's Avatar
First Name: ron
My RZR: 14 xp1k black beauty
Member #35449
View rzron800's Photo Gallery(0)
i did the shock therapy deal and did not like it. i'm however in the process of
getting it don with Ed (pound of sand) i would suggest that you at list talk to him 1st
and no i'm not trying to bad mouth shock therapy
rzron800 is offline
post #10 of 30 Old May 20th, 2017, 09:01 AM
rzron800's Avatar
First Name: ron
Member #35449
as far as i know shock therapy use 1 valving and possibly work with spring rate.
Ed would customize valving and spring rate to your riding style, location, car wight, bigger tires. i have a body with can am rs ? (the big 1) that ride was tough to say the list. Ed played with it a little and now it rides like a charm
rzron800 is offline
post #11 of 30 Old May 20th, 2017, 09:29 AM
Expat's Avatar
First Name: Larry
My RZR: 2016 Turbo
Member #75196
What exactly did you have done, what stage? Hard to imagine anyone not being happy unless something is wrong. It is a big step up in the ride of a XPT and a HUGE leap up in a XP. Something must be wrong or the full kit (sway bars etc not done.)
Expat is offline
post #12 of 30 Old May 20th, 2017, 10:24 AM
rzron800's Avatar
First Name: ron
Member #35449
i did every possible upgrade they offer re valve, springs, cross overs, sway bar. my ride end up so stiff that 2 mo later i just put on a set of 15s take offs and got my ride back. the only problem with the stocks is the springs don't last that's why i'm going with all new 2-1/2" fronts and re valve/spring on the rears. it will probably take 2-3 weeks to get don I'll report after i get everything dialed in. i did the shock therapy deal over 2 years a go they may of change setups since than. again i don't mean to take anything from shock therapy they are getting raving reviews on here
but the'r not the only one's that can do better then stock, its actually pretty
easy to do unfortunately
rzron800 is offline
post #13 of 30 Old May 20th, 2017, 10:30 AM
Fimea's Avatar
First Name: Rick
My RZR: 2015 XP1000, 2011 XP900
Member #29192
View Fimea's Photo Gallery(0)
I went with the Zbros Stage3 kit, and installed it myself. Best thousand bucks I've spent. (I already had the sway bar.) For an extra $80, they will powdercoat the springs to an optional color too.
http://zbrozracing.shopgate.com/item/333233
Sent from my SAMSUNG-SM-G890A using Tapatalk
2013 Ram 2500 & 3500 dually, diesel, crew cab
2002 Ford F-250 7.3L diesel, crew cab
2004 Wanderer Toyhauler
2015 RZR XP1000 Voodoo Blue
2011 RZR XP900 LE White Lightning
2008 LTR450, 2004 YFZ450,2003 YFS200
Fimea is online now
post #14 of 30 Old May 20th, 2017, 10:32 AM
rzron800's Avatar
First Name: ron
Member #35449
and by the way it was a pleasure working with Jason great customer service
my disappointment is was with the end result only
rzron800 is offline
post #15 of 30 Old May 20th, 2017, 10:32 AM
Expat's Avatar
First Name: Larry
My RZR: 2016 Turbo
Member #75196
Yes they constantly update. You can also get the shock valving updates free when you send them in to rebuild. My XPT and my buddies 2014 XP are about as far away from stiff as there is. The ride as soft as a 78 fleetwood and track like new BMWs with the sway bars.
Expat is offline
April 2017 RZR of the Month Voting is Open! Wreckless123 RZR Of The Month Contest! 0 March 15th, 2017 11:25 AM
Marks RZR XP 4 Turbo Build Gallery UTV Inc. UTV Inc 4 September 2nd, 2016 03:04 PM
Pro Armor Polaris RZR Sniper XL Suspension Seats Sxsperformance SXSPerformance.com 0 February 19th, 2016 11:45 AM
UTV INC XP 1000 Grills UTV Inc. UTV Inc 7 January 28th, 2016 07:28 AM
