Harmonic noise at low speed - Polaris RZR Forum - RZR Forums.net
post #1 of 18 Old March 20th, 2017, 10:46 AM Thread Starter
BigJohnStud's Avatar
Howdy. 2017 XP 1000 LE. Getting a weird harmonic noise at low speeds. Dunno what to think. I'll try posting a video. Happens more in high than in low. Thanks for any input. No change in power at all. Can make it go away by throttling up, but it doesn't seem normal.
Well, now I need to learn how to upload videos
Don't hate, Cultivate!
BigJohnStud is offline
post #2 of 18 Old March 20th, 2017, 11:05 AM Thread Starter
Re: Harmonic noise at low speed
Have longer videos if y'all can't hear the noise.
post #3 of 18 Old March 20th, 2017, 11:06 AM Thread Starter
18hrs on it, btw.
post #4 of 18 Old March 20th, 2017, 11:51 AM
headn4thehills's Avatar
My 16 does the same thing. Seems to do it more frequently when I run for a good length of time. There is a thread on here about it. LOTS of us have that sound. Drives me crazy. I just installed hunter works secondary rollers and it reduced the noise quite a bit, but it's still there. Some guys have had success with clutch kits. Some have several thousand miles on there machines with that sound and have had no issues. Even some of the 900 xp's do it.
2016 XP1K Sunset red, FUTV 3/8 skid, Polaris aluminum roof, pro armor harnesses, modquad rear view mirror, Emp half windshield, prp door bags.
2012 rzr s, polaris roof, emp half windshiels, pro armor rock sliders, FUTV skid plate, lock and ride box, pro armor 2" harnesses, utv inc doors and graphics, utv inc parking brake, Polaris front brush guard, prp seats, Totron 30" light bar, Rigid D2's sti beadlocks. (SOLD)
headn4thehills is offline
post #5 of 18 Old March 20th, 2017, 01:47 PM
Logman62's Avatar
Mine had a similar noise when I first bought it. I was convinced it was coming from the clutches as well. Ended up being my metal roof vibrating when the motor was hitting certain RPMs, it was so damn loud you couldn't really tell where it was coming from.
I was able to get the noise to happen consistently then have someone start pressing and holding their hands on any sheet metal parts until I found it. I would check all your aftermarket parts, put foam between anything made of sheet metal and the frame.
Logman62 is offline
post #6 of 18 Old March 20th, 2017, 01:53 PM Thread Starter
I do have the aluminum roof. Has foam between it & cage. I'll try your suggestion. Had a Dodge once that made a crazy harmonic noise. Found out it was the magnetic CB antenna oscillating. Worth a shot. Thanks.
post #7 of 18 Old March 20th, 2017, 02:27 PM
Logman62's Avatar
All it takes is 1 edge to be barely touching your cage and it will sound like a jet engine preparing for takeoff. Hope that is it because it is a cheap fix!
Logman62 is offline
post #8 of 18 Old March 20th, 2017, 04:46 PM
Dizzledog1's Avatar
It's your clutches without a doubt. Mine has done it since day one. I've tried everything. Hunterworks rollers , clutch alignment tool, dalton clutch kit. Only thing left I can do is drop 2k in a duraclutch. Doubt that will happen.
Dizzledog1 is offline
post #9 of 18 Old March 20th, 2017, 06:17 PM
Gut-pile's Avatar
I have a 17 with about 100 miles on it and it's been doing this exact noise since about mile 10. It's definitely coming from the belt and does it at low speeds up until about 10-12 MPH and goes away after that. Seems to do it worse in high but is very noticeable in low also. I plan to take mine back to the dealer after the break in to see what they say. So is this a common problem with these because three other guys I ride with have 1000's and don't have this issue?
Gut-pile is offline
post #10 of 18 Old March 20th, 2017, 06:39 PM
Mcebull's Avatar
My 17 xk1k4 with less than 100 miles makes the same sound. It drives me crazy.
Mcebull is offline
post #11 of 18 Old March 21st, 2017, 03:45 AM
Dizzledog1's Avatar
What 1k does your friends have?
post #12 of 18 Old March 21st, 2017, 01:57 PM
bubba626's Avatar
same on mine as well, low speed, goes away after rpms increase. noise sounds like it is coming from belt/clutch area. 17'xp1000 has around 25 hours and has made this noise since 2-3 day.
bubba626 is offline
post #13 of 18 Old March 21st, 2017, 03:16 PM
CaseyK's Avatar
The noise is definitely your primary clutch
CaseyK is online now
post #14 of 18 Old March 21st, 2017, 03:55 PM
deblas's Avatar
I've got a 14 1000 4 seater and it has done it from day one. I have heard that same noise on so many cars I'm no longer concerned!
2500 miles, Sparks clutch kit and same belt for the last 1800 mi.
And the only reason I changed belts was due to the clutch retro fit kit....you all with the newer cars don't have to worry about that!!
Don't worry...this noise actually is normal
Sent from somewhere over there...
2014 XP4 1000 Titanium
deblas is offline
post #15 of 18 Old March 21st, 2017, 05:41 PM
Gut-pile's Avatar
Two have 16 models and one has a 17.
Gut-pile is offline
rpms and speed When should you use low and when should you use High?? rzr lover RZR S 900 6 January 17th, 2017 08:53 PM
Lower speed limit in low range is really annoying! Driverzr RZR XP Turbo 23 October 4th, 2016 04:27 AM
Low speed jerking CKoliba RZR S 900 32 August 30th, 2016 08:12 AM
Problem whit my low speed dannydorion RZR XP 900 0 August 22nd, 2016 10:37 PM
Low Speed tip- maintenance check hedbutter RZR XP 1000 1 July 16th, 2016 04:21 PM
