Difference in a '16 xp 1000 and a '17 xp 1000 - Polaris RZR Forum - RZR Forums.net
post #1 of 26 Old March 8th, 2017, 05:51 PM Thread Starter
jason07's Avatar
What is the difference in these 2 machines besides the price ('17 is 19,500 and the '16 is 20,300)
jason07 is offline
post #2 of 26 Old March 8th, 2017, 06:35 PM
Mike_jones's Avatar
Re: Difference in a '16 xp 1000 and a '17 xp 1000
Piggyback resi in the rear shocks, differences in springs. Some have an updated timing chain tensioner. Probably things I'm forgetting. There's a big thread and a video detailing the differences in here if you search
Mike_jones is online now
post #3 of 26 Old March 8th, 2017, 06:39 PM
Dizzledog1's Avatar
That's about it.
Dizzledog1 is offline
post #4 of 26 Old March 8th, 2017, 06:40 PM Thread Starter
jason07's Avatar
I appreciate the info. I searched but only found a thread for a 16 vs 17 turbo
jason07 is offline
post #5 of 26 Old March 8th, 2017, 08:24 PM
DogRunner2's Avatar
I heard the reverse chain is upgraded for 17.
2016 900s
DogRunner2 is offline
post #6 of 26 Old March 8th, 2017, 08:27 PM
ryebread929's Avatar
Reservoir on the rear shock instead of cage, voltage regulator behind grill, no more front a arm grease zerks, acc position on ignition, no front tender spring, better cam chain tensioner, different part number front diff (supposedly engages faster than ever) m12 rear radius arm bolts instead of m10, beefier radius arms, different wheels, different clutch weights. T rail seat belt dampener/neck saver. I'm sure I'm missing something. These are what I've noticed looking over my 17, and figured out the rear radius arms/bolts when I went to install the rear bumper. Had to drill the holes on the bumper bigger.
ryebread929 is offline
post #7 of 26 Old March 9th, 2017, 08:03 AM
rskeans's Avatar
My '17 has the reservoir's on the cage. Anybody know why they're different? Mine is the Ridecommand model.
2017 1000 EPS XP SE RIDE COMMAND
rskeans is offline
post #8 of 26 Old March 9th, 2017, 09:16 AM
Yep the ride command velocity blue has the older style Walker Evans shocks with remote rear reservoirs
post #9 of 26 Old March 15th, 2017, 07:30 AM
snoblind's Avatar
Can anyone confirm this? I'm thinking of updating my 14.
snoblind is offline
post #10 of 26 Old March 15th, 2017, 07:46 AM
DogRunner2's Avatar
If your going to upgrade why not go with aftermarket double chain . That's what my buddy just did on his 15.
2016 900s
post #11 of 26 Old March 15th, 2017, 09:39 AM
snoblind's Avatar
I meant replacing my 14 machine with a new 17. With rebates currently in place I might consider it if there were enough changes.
snoblind is offline
post #12 of 26 Old March 15th, 2017, 05:07 PM
Dizzledog1's Avatar
Pretty sure they are the same. Rc addition might be upgraded .
post #13 of 26 Old March 15th, 2017, 05:17 PM
roadiestar's Avatar
The 17 has the 16 High lifter reverse chain setup
roadiestar is offline
post #14 of 26 Old March 15th, 2017, 05:36 PM
Dizzledog1's Avatar
I can't find where it says that
post #15 of 26 Old March 15th, 2017, 06:06 PM
HoustonHayseed's Avatar
From what I have read, the Gold LE Rock Crawler is the only additional model that has the wider High Lifter reverse chain. I have in writing from Polaris and my dealer that the Gold LE has the heavy duty chain. They were initially advertised to have a reverse gear. I verified that they only have the heavy duty reverse chain and not the reverse gear before I bought mine.
HoustonHayseed is offline
March 2nd 2017 Recall Thread, Please Post any and all Recall Info /Questions Here Allrsdup Polaris RZR News 114 March 22nd, 2017 05:26 AM
2017 RZR 1000 & Turbo 3/8" Skid Plates UTV Inc. UTV Inc 0 November 9th, 2016 02:44 PM
One Stop Design and Machine Polaris RZR XP 1000 / RZR XP4 1000 Sway Bar Clamps Sxsperformance SXSPerformance.com 1 February 11th, 2016 02:13 PM
Wide Open SXS Polaris RZR Front Bumpers - Polaris RZR XP 1000 / RZR XP4 1000 DOM Fron Sxsperformance SXSPerformance.com 1 February 9th, 2016 11:36 AM
Walker Evans Polaris RZR XP 1000 2.5 Replacement Needle Coil Over Piggy Back Shock Sxsperformance SXSPerformance.com 0 February 2nd, 2016 11:59 AM
