Engine Oil Options - Page 3 - Polaris RZR Forum - RZR Forums.net
View Poll Results: What Oil are you using?
PS-4 5w-50 33 14.41%
PS-4 Extreme 10w-50 45 19.65%
Amsoil 4 0w-40 6 2.62%
Amsoil sxs 5w-50 31 13.54%
Rotella T6 15w-40 36 15.72%
Joe Gibbs Driven XP7 10w-40 1 0.44%
Joe Gibbs Driven XP9 10w-40 0 0%
Maxima Semi Synthetic 4-Stroke 10w-40 11 4.80%
Maxima SXS 5w-50 10 4.37%
Mobil 15w-50 16 6.99%
Mobil European 0w-40 6 2.62%
Mobil T4 10w-40 8 3.49%
Castrol 5w-50 10 4.37%
Schaffers 5w-50 10 4.37%
Lucas Motorcycle 10W-40 0 0%
Other 9 3.93%
Multiple Choice Poll. Voters: 229. You may not vote on this poll
 30Likes
post #31 of 129 Old January 6th, 2017, 06:20 PM
nailermike's Avatar
First Name: mike
My RZR: rzr 1000 xp
Member #69774
View nailermike's Photo Gallery(0)
Re: Engine Oil Options
yes Polaris in front and rear diffs
nailermike is offline
post #32 of 129 Old January 7th, 2017, 04:59 PM
btrshoes's Avatar
My RZR: 900S
Member #48027
View btrshoes's Photo Gallery(0)
worrying about oils and researching it to hell and back is a huge waste of time and energy, run the polaris oil change kits.
btrshoes is offline
post #33 of 129 Old January 7th, 2017, 08:40 PM Thread Starter
strate6's Avatar
My RZR: 2015 XP1000
Member #81677
View strate6's Photo Gallery(0)
I understand, i bought the kit for this change. My concern is this, they engineered the oil, they also engineered the gas tank vent, and the heat shields, the hydraulic cam tensioner, the plastic front diff bearing cage, the front diff shims. So i fell its only necessary to investigate some. I know they did alot of good engineering too. But the buggy is there nitch as where the oil is the company that made it (probably the cheapest bid)
Im planning on giving the poll some time.
Mwolf83 likes this.
strate6 is offline
post #34 of 129 Old January 7th, 2017, 10:26 PM
Banned
Wheel's Avatar
Member #64360
View Wheel's Photo Gallery(0)
Oil analysis is inexpensive and I would hardly call it a huge waste of time.
Clearly, fuel dilution is a real problem in certain conditions.
Wheel is offline
post #35 of 129 Old January 8th, 2017, 12:16 PM
Roger Lee's Avatar
First Name: Roger
My RZR: 2015 1K
Member #69952
We do oil analysis all the time in on aircraft engines. The only time we see fuel in the oil is when there was some diesel fuel in the regular gas. This happens at the time when a driver refuelling tanks doesn't follow procedure in flushing a line. The diesel fuel will migrate into the oil. This is usually self limiting and usually isn't harmful because it's more trace amounts and usually goers away with other fuel fill ups and oil changes.
Roger Lee is offline
post #36 of 129 Old January 9th, 2017, 12:10 PM
DBR1990's Avatar
First Name: Dennis
My RZR: Sold and currently deciding on new one
Member #32982
View DBR1990's Photo Gallery(0)
Because of direct valve actuation I use oils with moderate to high levels of zinc. Other than that just frequent service is the recipe for success.
Mr Tommy likes this.
DBR1990 is offline
post #37 of 129 Old January 9th, 2017, 04:37 PM
Zap!
LadderLogicLloyd's Avatar
First Name: Lloyd
My RZR: XP1000
Member #83265
View LadderLogicLloyd's Photo Gallery(0)
I use rotella t6.
I change every race or every three rides, because dirty air=particle ingestion. I don't care what air filter you run, dirt can go through all of them at a certain size or smaller. I change the oil filter every other oil change. I have been steady gaining interest in seeing a OA for my car, maybe I will send one in soon.
The change in noise at idle was DRASTIC, the rotella made it sound like a sewing machine. The popo oil before I changed over, I swear the drivetrain was 3 times louder. Call me crazy or whatever but it really is simple math. Oh and my running temps during testing went down 12-20 degrees
2.5 gallons of rotella is about 50$ or so?
The full kill motor is OEM plus 6k$......
so easy even a caveman can do it.
Mwolf83 likes this.
Surrounded by awe inspiring amounts of open desert, attempting to explore every square foot of it.
LadderLogicLloyd is offline
post #38 of 129 Old January 9th, 2017, 04:42 PM
Banned
Wheel's Avatar
Member #64360
Engine Oil Options
I was hoping someone would bring up Rotella.
I ran rotella synthetic in my motorbike, as did a whole lotta other dudes on the forums. No troubles, and it was $20 for a gallon.
Mwolf83 likes this.
Wheel is offline
post #39 of 129 Old January 9th, 2017, 06:11 PM Thread Starter
strate6's Avatar
My RZR: 2015 XP1000
Member #81677
I was leaning towards rotella, my only problems with it are 540 Rat's testing ranking 161 of 194 at 67,804psi highest was 134,000. And then some claim it made there engine runn warmer.
But comparing the unreliable Blackstone results it looks promising rotella vs PS-4 Extreme 10w50
Some of the reports may have come for forum members on here, if you want me to pull them down or credit PM me.
But yeah rotella meets the CJ-4 and JASO MA2 which are good right? And above poster claimed smoother and cooler running.
So im to Rotella, Amsoil, or PS-4 extreme(in that order probably). Everything else is ester oil (race) mail order.
ID:	371377   Click image for larger version
strate6 is offline
post #40 of 129 Old January 9th, 2017, 07:42 PM
paul463's Avatar
My RZR: 2014 XP1000
Member #39598
View paul463's Photo Gallery(0)
I use Schaeffer 5-50.
If you use anything else your machine will explode and kill every living thing within a 1/4 mile. Ever seethe end that movie Predator? Yeah, that kind of explosion.
paul463 is offline
post #41 of 129 Old January 9th, 2017, 09:24 PM
Zap!
First Name: Lloyd
My RZR: XP1000
Member #83265
Best post yet, you sir are clearly an experienced forum member. Seriously. +1 to you
I didn't do a ton of research to get to Rotella. I just read as much as I could stand it here and on the oil forum and a few other places, it's probably more reading than most would do.
On a slightly serious note, I had a hard time finding negative info on the Rotella. Maybe I didn't look in the right places?
Oh and whoever had info on sending in oil for OA, please share. My curiousity is growing. I may start doing one every 6 months in an attempt to learn something.
post #42 of 129 Old January 10th, 2017, 06:42 AM
DogRunner2's Avatar
Member #137545
Google Blackstone labs.
2016 900s
DogRunner2 is offline
post #43 of 129 Old January 11th, 2017, 09:32 AM Thread Starter
strate6's Avatar
My RZR: 2015 XP1000
Member #81677
Rotella is in the high 40w.
We were in the single digits last week, everyone says the PS4 extreme is the better oil but it being a 10w, I'm at the lower end of the spectrum with my temperature outside. I'm leaning towards the Rotella. I called Amsoil and asked the same question to guys and got two different answers. They said that they don't do API spec on her oil because OEM does not anymore.
ID:	371409   Click image for larger version
strate6 is offline
post #44 of 129 Old January 11th, 2017, 10:07 AM
rynomx785's Avatar
First Name: Ryan
My RZR: 15 XP 4 1000
Member #61131
View rynomx785's Photo Gallery(0)
I did a bit of research a while back and I landed on Mobil1 T4 10W-40. I found a motorcycle oil analysis test and the T4 was top 3 in every category. What finalized my decision was that I live in a small town and I can get the T4 locally at O'reilly's. I put the T4 in the first time at about 1500 mile (3rd change if I remember correctly) and currently have 4700 miles on my XP 4 1000. I change it at 40 hours intervals and it hasn't started using any oil yet. I live in the AZ desert and make a few trips a year to the dunes.
The fuel ingestion is interesting. I will be sure to limit my cold starts going forward.
rynomx785 is offline
post #45 of 129 Old January 11th, 2017, 02:26 PM
desertjunky's Avatar
First Name: Don
My RZR: 2015 xp4 voodoo blue
Member #72304
View desertjunky's Photo Gallery(0)
Arizona Flag Re: Engine Oil Options
I run Schaeffer's 5w50 and have run Lucas 5w50 with wix filter change every 50 hrs 7600 mi in the desert clean the air filter evey oil change no issues if you do proper maint then it does not matter it is what you prefer as an oil
desertjunky is offline
Tags
oil change , oil filter , oil type
2017 XP1K Timing Chain Tensioner - I Think Polaris Fixed It! Sshsjd10 RZR XP 1000 76 March 30th, 2017 05:41 AM
oi cooler joemamma RZR 900 Engine 25 June 22nd, 2016 03:15 AM
Possible coolant in engine oil rdsnake RZR XP Turbo 4 May 2nd, 2016 06:10 AM
Oil cooler on Prostar engine 2011redxp RZR 1000 Engine 0 February 4th, 2016 08:38 AM
