Report any 2014 XP-1000 problems here - Page 12 - Polaris RZR Forum - RZR Forums.net
This is a discussion on Report any 2014 XP-1000 problems here within the RZR XP 1000 forums, part of the General RZR category; not unpatriotic... feel free to post about it in another thread... just keep this one on topic....
Go Back   Polaris RZR Forum - RZR Forums.net > General RZR > RZR XP 1000
Old September 4th, 2013, 11:12 AM   #166
Tuf-Skin's Avatar
First Name: Clifford
Member #2228
Re: Report any 2014 XP-1000 problems here
Old September 4th, 2013, 11:24 AM   #167
MisterHall's Avatar
Member #44203
View MisterHall's Photo Gallery(0)
Any more issues?
2013 Wildcat Limited
-Adam
MisterHall is offline   Reply With Quote
Old September 4th, 2013, 02:18 PM   #168
nvpowerdoc's Avatar
First Name: Joe
My RZR: 2009 RZR-s
Member #6665
View nvpowerdoc's Photo Gallery(43)
So I took my XP1000 to the dealer this morning regarding the front-end vibration and low front diff oil level.
Service manager indicated service tech originally checked front diff oil-level pre-delivery by loosening the drain bolt and just simply checking for fluid because he was unable to remove the filler plug (either because he stripped it, or it was installed to tight). Kind of bogus, but at least they replaced the filler plug today and filled the oil to the right level (I'm still going to check this evening).
As for the driveline vibration, no luck with any dealer resolution. Indicated to the service manager what folks on here were saying Polaris claims the repair to be (rotate the u-joint by 6 splines??). My unit was the second one in the shop at thsi delar for this issue. Dealer claims they are waiting for Polaris to issue a service bulletin and won't (can't) really do much at this time. I did have the service rep notate my paperwork indicating the drive-line / diff vibration issue and I'll just have to follow-up in a month or so...
Results are about what I expected.
2014 XP1000
2009 RZR-s, pretty much stock - except the 800W 5-Channel Alpine Amp under the hood and 5 speaker system to boot!
Now only one 700 Raptor
nvpowerdoc is offline   Reply With Quote
Old September 4th, 2013, 02:26 PM   #169
Dirtmod15jr's Avatar
First Name: Brian McLemore
My RZR: 2015 RZR 900 S
Member #17976
View Dirtmod15jr's Photo Gallery(0)
Quote: Originally Posted by GIL View Post
Quote: Originally Posted by Macman12 View Post
All of these issues is making my decision to wait until after January seem worth while.
It could be much worse!!! We could all own Can Am's or Artic Cats!!! LMAO
Hey now! After the three recalls on my Maverick it seems to be working fine. Although there were no indications of problems before hand.
New Starter
New Clutch Stud and Nut
Fix Pass Grab Handle.
Seriously though good luck guys, I hope Polaris gets these issues straightened out for you. No one likes to see riders missing rides due to an issue outside of your control.
Dirtmod15jr is offline   Reply With Quote
Old September 4th, 2013, 03:07 PM   #170
Tuf-Skin's Avatar
Member #2228
Have them call Polaris again.
Polaris emailed my dealer a 10 page "prop shaft re-phase" instruction booklet.
it is basically 1 or 2 steps per page with pictures.
to rotate the front drive shaft 6 splines (90 degrees) they have to grind off a "staked tooth" (bump in the spline valley) on the prop shaft, then re-install everything.
I had the dealer give me a copy of the instructions so I would have it in the future if I needed to remove the drive shaft for any reason.
Old September 4th, 2013, 03:39 PM   #171
GIL
GIL's Avatar
First Name: Gil
My RZR: 2014 XP1000
Member #48199
View GIL's Photo Gallery(0)
Is it possible to make that 10 page document a sticky? I feel that alot of us on the forum are capable of performing the procedure ourselves and not having to wait in line at a dealership for repairs. Maybe I'm wrong and it could go real wrong, but would like to think that the people that laid down that kind of money on a 1000 would be smart enough to know if they are capable of the repair themselves or need to rely on their local dealer. Just a thought.
Again-THANK YOU so much for posting all of your findings / fixes / and valuable info!
GIL is offline   Reply With Quote
Old September 4th, 2013, 03:48 PM   #172
Tuf-Skin's Avatar
Member #2228
I think it is best that the dealer make the repair. That way it is on record with Polaris that your machine has had the warranty work done.
Old September 4th, 2013, 04:16 PM   #173
Scoob03's Avatar
My RZR: XP 1000 & 900
Member #49040
View Scoob03's Photo Gallery(0)
Ok. So just dropped mine off at dealer after calling and explaining issues to Svc dpt. they had the 10 page manual there for 1000 driveline re-phase. They seemed ready to go and 100% willing to get it fixed. Made me feel good
Scoob03 is offline   Reply With Quote
Old September 4th, 2013, 04:22 PM   #174
Redflametech's Avatar
First Name: Tim
My RZR: currently don't have one
Member #30289
View Redflametech's Photo Gallery(0)
My Arctic Splat runs great, and they stood behind their product like no other, that being said, I learned my lesson buying a first year model, so as much as I loved my RZR S (bulletproof machine) and believe in Polaris engineering, there is no way in hell I'll be jumping back to this machine for a couple of years. Best of luck to all those who did, I'm sure Polaris will work it out, they are the industry leader for a reason.
Redflametech is offline   Reply With Quote
Old September 4th, 2013, 05:31 PM   #175
Txjole's Avatar
First Name: Joe
My RZR: 2013 XP4 Walker Evans
Member #52971
View Txjole's Photo Gallery(0)
"They stood behind their product like no other" you can't fool me. I owned a Tigershark under warranty when they closed the doors. I was told sorry about your bad luck in not so many words when I needed work done. I will never think nor say a good word about that joke of a company ever.
2013 RZR XP4 WE
Txjole is offline   Reply With Quote
Old September 4th, 2013, 09:19 PM   #176
newrzrforme's Avatar
First Name: Bart
My RZR: 1000 xp
Member #60150
View newrzrforme's Photo Gallery(0)
After reading this forum I took mine out the fuel pump seemed a little noisy but I deal with high pressure pumps in boats and it dose not seem much louder I can here it at idle but not going down the road.It dose have a rattle coming from the front so I will talk to my dealer tomorrow.The front diff was full of oil.the glove box is a piece of crap I was thinking of heating it and tweaking it to make it fit better I cant believe they would release the car like that one other thing I noticed was I have a chip in the paint on 3 of the long springs of my shocks I don't know if this is normal or not.You guy's have been very helpful to a newbie like me thanks for everything Bart
newrzrforme is offline   Reply With Quote
Old September 4th, 2013, 11:13 PM   #177
Tuf-Skin's Avatar
Member #2228
If you lift up on the glovebox door when you close it, it will latch better and stay shut.
Just have to get the latch lined up.
Old September 5th, 2013, 12:46 AM   #178
nvpowerdoc's Avatar
First Name: Joe
My RZR: 2009 RZR-s
Member #6665
I'd prefer to do this myself (if there was a sticky). Dealer did not have instruction booklet - seemed they were waiting for Polaris to call them back. Even could print the sticky and take it to the dealer...
2014 XP1000
Old September 5th, 2013, 01:00 AM   #179
LV RzR Rider's Mechanic
LvDirtJunky's Avatar
First Name: Chase
My RZR: 2009
Member #4118
View LvDirtJunky's Photo Gallery(6) Send a message via AIM to LvDirtJunky Send a message via Yahoo to LvDirtJunky
Sounds like you guys spent 20 grand on a Mexican made $#!+ box ....
Sent from my radd iPhone
2009 poolaris RZR Bikeman pipe , ump , powercammander , Throttle play adjusted , lonestar grill's .she rips
www.utvcrap.com , These guy's ROCK
I.U.O.E. Local 12 . Work Union Live Better
LvDirtJunky is offline   Reply With Quote
Old September 5th, 2013, 01:23 AM   #180
Krunch0's Avatar
First Name: Randy
My RZR: 14' RZR 4 1000 Titanium
Member #40141
View Krunch0's Photo Gallery(0)
Ours fits better than yours but doesn't stay closed worth a damn and we haven't taken it off road yet Dealer told me Polaris has a fix and will be distributing it soon, we'll see. How this got by the Polaris testing folks is beyond me. Unless we are the Polaris testing folks
They test just like the Russians do for Military aircraft. They make a run of a few aircraft and put them right into service without serious flight testing. As problems crop up they fix them on the next batch and so on. This is what we are doing for Polaris. They will fix the issues in the next revision, but leave ours without the fix.
Famous last words: "Dude, Watch this!"
I would love to live in a world where the chicken's motives for crossing the road are not questioned!
Krunch0 is offline   Reply With Quote
2014 rzr 1000 problems
2014 rzr xp 1000 recall probllems
2014 xp1000.problems
polaris rzr 1000 problems
polaris rzr s 1000 problems
polaris rzr xp 1000 problems
problems with 2014 rzr 1000
rzr 1000 exhaust problems
rzr 1000 power steering problems
rzr 1000 problems
rzr 1000 transmission problems
rzr 1000 trouble code 60, 61, 62
rzr 1000 xp problems
rzr xp1000 fuel problems
xp 1000 rear transmission problems
Wtb 2014 xp 1000 CRSANISLO Want to Buy 5 March 9th, 2014 06:44 PM
Trying to decide what to buy 2014 maverick xrs dps vs. 2014 rzr 1000 Luckyc1423 General RZR Discussion 30 January 22nd, 2014 03:55 PM
2014 Rzr 1000 pic MIARZR900 General RZR Discussion 2 July 23rd, 2013 01:13 AM
i got a pic of new 2014 rzr xp 1000!!!! mike1987 General RZR Discussion 10 July 16th, 2013 10:02 PM
BAJA 1000 Report, and Q&A ventracing General RZR Discussion 19 December 11th, 2011 12:21 PM
