lug nut/rim size for new 1000 - Polaris RZR Forum - RZR Forums.net
This is a discussion on lug nut/rim size for new 1000 within the RZR XP 1000 forums, part of the General RZR category; anybody know if the wheel bolt pattern is the same or not and will 12" wheels fit on the 1000xp...
Go Back   Polaris RZR Forum - RZR Forums.net > General RZR > RZR XP 1000
Old August 1st, 2013, 01:21 PM   #1
FISTofZUK's Avatar
First Name: Nick
Member #23703
View FISTofZUK's Photo Gallery(0)
FISTofZUK is offline   Reply With Quote
Old August 1st, 2013, 01:29 PM   #2
bfarmer16's Avatar
My RZR: 2014 XP1000
Member #12918
View bfarmer16's Photo Gallery(0)
Re: lug nut/rim size for new 1000
I've heard that the bolt pattern is the same, Larger diameter studs, 12" wheels won't fit due to the larger brakes.
bfarmer16 is offline   Reply With Quote
Old August 1st, 2013, 01:39 PM   #3
quadbike's Avatar
Member #57507
View quadbike's Photo Gallery(0)
Same brake as the scrambler 850 I'm guessing so 14's a must
quadbike is offline   Reply With Quote
Old August 1st, 2013, 02:37 PM   #4
Zach_at_NXG's Avatar
Member #58043
View Zach_at_NXG's Photo Gallery(0)
Confirmed the new RZR 1000 has a 14" wheel with a 4x156 lug pattern. The studs are 12mm by I believe 1.5 pitch. The 12" wheels will not fit due to the larger break package. NXG wheels are boxed and ready to be placed on that new RZR 1000 you just purchased. NXG offers a 14"x6" or a 14"x7" black powder coated wheel. Finished off with black zinc coated hardware and a paint ready raw finished ring. Check us out on Facebook for all our updates at www.facebook.com/nxgwheels or check out NXGwheels.com to see all of our products.
Phone - 951-354-8272
Fax - 951-354-8599
Email - sales@nxgwheels.com
http://nxgwheels.com/
https://www.facebook.com/NXGWheels?ref=hl
Zach_at_NXG is offline   Reply With Quote
Old August 1st, 2013, 02:41 PM   #5
quadbike's Avatar
Member #57507
So not a M10 x 1.25mm thread as the Scrambler 850...RZR900's are a 3/8 unf M10.
Never seen a M12 x 1.5 thread on a quad!!!!
Old August 1st, 2013, 05:49 PM   #6
FISTofZUK's Avatar
First Name: Nick
Member #23703
so if took a 14" wheel that fits a 900
will it not fit on the new 1000 because the studs are bigger?
looking to place an order for 14" HiPer wheels
not sure now if ill need some special lug nuts or if the stock ones will work with these wheels
or do I need to wait until the correct wheels are available
Old August 6th, 2013, 04:30 PM   #7
FISTofZUK's Avatar
First Name: Nick
Member #23703
i went and ordered HiPer wheels
14x10 5+5 4/156 wheels for the rear
and 14x9 5+4 4/156 wheels for the front
going to be running the 28" STU paddles and ribbed steer tires
hope I don't have any issues with the wheels
Old August 6th, 2013, 04:42 PM   #8
DWRAT's Avatar
First Name: Dan
My RZR: 2014 RZR-XP1000
Member #5778
View DWRAT's Photo Gallery(0)
You could drill out the bolt holes in about 5 min total.
2005 Rhino 660---Sold
2008 Rhino 700---Sold
2009 RZR-S------- Sold
2011 RZR-XP9-----Sold
2014 RZR-XP1K---Sold
2011 Rhino 700
2016 RZR-XPT----Sold that POS
DWRAT is offline   Reply With Quote
Old August 6th, 2013, 04:49 PM   #9
BarRZR's Avatar
My RZR: 2012 RZR 800-S L/E
Member #32278
Quote: Originally Posted by DWRAT View Post
..........You could drill out the bolt holes in about 5 min total.
Ya, but without chucking them up in a mill, you'd NEVER get them exactly centered and champhered, and they'd be working-loose all the time. My two-bits.......
Cheers
Old August 6th, 2013, 05:00 PM   #10
Thunder45's Avatar
Member #2071
View Thunder45's Photo Gallery(0)
Couple things...not sure hiper makes a 10" wide wheel and the 14's only come in double bead lock so that takes up alot of the inside diameter of the wheel..I ran I to this with a wildcat and had to modify the caliper to make them work. I would wait before spending that kind of coin.
Thunder45 is offline   Reply With Quote
Old August 6th, 2013, 05:19 PM   #11
FISTofZUK's Avatar
First Name: Nick
Member #23703
I have a big trip planned September 13
and am already risking that the 1000 I have money down on will be on time as well
plus I believe my 900 stock wheels where 6" inset and from the pictures the 1000 wheels look to have not much offset aswell
how much do you think the ring sticks out compared to a non beadlocking wheel?
so I guess im ALL IN!
well not quite, I haven't sold my 900 yet
Old August 6th, 2013, 05:26 PM   #12
FISTofZUK's Avatar
First Name: Nick
Member #23703
im also hopeing the 12mm is not correct
seems kind of big to have almost a 1/2 stud
and maybe the hub is piloted for the wheel and if not
if I do drill them out the holes should be tapered and keep it strait enough for me
Old August 6th, 2013, 06:31 PM   #13
C6.7weldrig's Avatar
My RZR: '13 RZR-S
Member #44945
View C6.7weldrig's Photo Gallery(0)
Cheers
I've done it a ton of times. You're only drilling them out a little bit. Works just fine.
2013 Rzr-S 800 LE (orange and white)
UTV Inc custom Akimbo/Nuke roll cage (7" lower than stock), Racertech cage mounts and A-pillar braces, UTV Inc wide tall doors, Racertech Rigid Mount front bumper, complete ThunderHawk chassis reinforcements, FUTV 1/2" thick UHMW skid plates, Holz billet/polygraphite motor mounts, PRP GT suspension seats w/ PRP 2"x3" 5-point harnesses, Sparco suede steering wheel with Snap-Off quick release, UTV Inc bed access panel.... and the list goes on
C6.7weldrig is offline   Reply With Quote
Old August 6th, 2013, 08:08 PM   #14
rzrguy67's Avatar
Member #22584
View rzrguy67's Photo Gallery(0)
The studs are nearly 1/2 inch on the xp1000 same as on the Ranger
I confirmed this with the Polaris engineer at Dunefest.
rzrguy67 is offline   Reply With Quote
Old August 6th, 2013, 10:11 PM   #15
FISTofZUK's Avatar
First Name: Nick
Member #23703
so do the hiper wheels fit on the ranger?
2016 polaris rzr 1000 bolt pattern
2016 rzr lug pattern
2016 rzr turbo bolt pattern
bolt pattern for rzr 1000
hub bore size on rzr wheels
polaris rzr 1000 lug pattern
polaris rzr 1000 wheel bolt pattern
polaris rzr 1000 wheel nut pattern
rzr 1000 lug nut size
what size lug nut for polaris rzr 1000
what size wheel on 2016 rzr 4 xp 1000
wheel lug pattern rzr 1000 xp
Up to $1000 and 3.99% kabin RZR XP 900 6 March 10th, 2012 02:59 PM
RZR XP 900 VS WILDCAT 1000 vs COMMANDER 1000 X Robert77 Other Side by Side Vehicles 21 January 9th, 2012 11:21 PM
actual tire size vs. advertised size crawlrinny Wheels and Tires 1 July 7th, 2010 09:12 PM
Wheel Size to Tire Size Chart? user_name Wheels and Tires 4 May 12th, 2010 02:55 PM
