2010 rzr s stalls on hills only - Polaris RZR Forum - RZR Forums.net
post #1 of 3 Old October 21st, 2012, 03:07 PM Thread Starter
dunavantsbodyshop's Avatar
Member #46533
View dunavantsbodyshop's Photo Gallery(0)
My rzr stalls on steep bumpy hills only time it ever happens..dealer said change plugs and add seafoam to gas so i did all that even drained the gas rode it at a ride after it was fine..today i go on another ride and it does the same thing it sputters dies and most of the time loses all power as far as electrical and wont start back until cutting the key on and off a few times or waiting 30 seconds or so... afterwards if you try to throttle it it will usually dies again unless you barely touch the throttle its pretty irritating also has brand new battery dunno what else to do check engine light flashed a few times after it died today but then just stopped and went off..dealer says cant check unless it's on so im at a loss any help would be great thanks
dunavantsbodyshop is offline
post #2 of 3 Old October 22nd, 2012, 04:36 PM
JiAnthony315's Avatar
First Name: Ji
My RZR: 2013 XP 900
Member #36958
View JiAnthony315's Photo Gallery(1)
Re: 2010 rzr s stalls on hills only
If your engine light comes on you should be able to check the code it is throwing...Also i may be wrong but I think if the engine light comes on it stores it in the computer whether it stays on or not...
Also have you checked you fuel pressure when it is messing up? If not do that because my fuel pump went out...As far as doing it just on hills, I have no idea about that..
JiAnthony315 is offline
post #3 of 3 Old October 22nd, 2012, 06:03 PM Thread Starter
Member #46533
Thanks for your help i think i may have found the problem...someone spliced the hot ignition wire at one time and didnt use the right connectors...i messed with it today and figured out it was my electrical problem anyways as they were pretty much just staying together by the other wires pushing against it..as for fuel pressure im gonna check that tomorrow thanks for your help i really appreciate it
170 stalls when you touch pedal WChighfill RZR 170 Specific Disccusion 15 July 6th, 2012 01:13 PM
170 stalls on whoops WChighfill RZR 170 Specific Disccusion 2 May 23rd, 2012 08:59 AM
RZR 170 stalls in a right turn CoryD RZR 170 Specific Disccusion 3 January 20th, 2011 05:48 PM
rzr 4 sputters,backfires,stalls out riverride Engine and Drivetrain 9 February 9th, 2010 08:35 AM
Low Idle and stalls Kragar General RZR Discussion 1 June 7th, 2009 11:53 AM
