Rear end squeak with pictures.
This is a discussion on Rear end squeak with pictures. within the RZR-S Specific Discussion forums, part of the General RZR category; Anyone know what we should torque the bolts to after reassembly?...
RZR-S Specific Discussion Please limit this to RZR-S only!
  #16
Old July 1st, 2009, 06:30 PM
BHazel's Avatar
My RZR: RZR-S
Member #8468
View BHazel's Photo Gallery(0) Send a message via AIM to BHazel
Re: Rear end squeak with pictures.
2009 RZR-S
  #17
Old July 1st, 2009, 06:37 PM
King of crash!
Member #787
look in the service manuel
  #18
Old July 1st, 2009, 06:45 PM
BHazel's Avatar
My RZR: RZR-S
Member #8468
So...does anyone know what the torque spec is?
2009 RZR-S
  #19
Old July 1st, 2009, 07:02 PM
bagman's Avatar
My RZR: Gen 1
Member #649
I clicked on this thread because I wanted to see what a squeak looked like. Hence the name "Rear end squeak with pictures".
I'm disappointed
  #20
Old July 2nd, 2009, 02:20 PM
Trip's Avatar
My RZR: "S"
Member #7490
View Trip's Photo Gallery(0)
Thanks for the tip, that squeak was driving me crazy. Instead of loosing or removing the bolts, I shot some WD40 in those areas and no more squeak. I now can enjoy coasting along again.
  #21
Old August 22nd, 2012, 03:23 PM
TexasRZRX's Avatar
Member #28199
View TexasRZRX's Photo Gallery(0)
Quote: Originally Posted by DWRAT View Post
It seems all the RZR-S get a rear end squeak after about 30 min of riding and all lot of you have asked for pictures so here you go.
Grease all the bolts, bushings, metel spacers & where it touches the a-arm ends.
Mine has been squeaking very badly for a while now. Just got it over to my shop to take a look at it. I thought it was the rear sway bar - or more like I hoped it was, since it has a grease fitting - but once I got it on the lift and in the air, it is definitely the same spots squeaking as shown in the pictures.
Quote: Originally Posted by Dangerous Dan View Post
I've thought about drilling some small holes in the spindles and installing some knock in grease fittings but haven't done so yet. Has anybody else done tried this? I used to do this on my sport quads in the swing arm and rear carrier- it worked great, vertually eliminated bearing replacements (lots of mud and water in the NE).
I like your idea! I might have to give that a shot before our yearly Arkansas trip in September.
2011 Polaris RZR-S 800
1998 Honda Shadow 1100
2010 X5 Camaro SS Turbo, 700HP
1969 Chevy Nova 383ci
2003 Chevy Tahoe
  #22
Old August 22nd, 2012, 06:29 PM
ShakyDog's Avatar
My RZR: 2009 RZR S LE Turbo Silver
Member #41826
View ShakyDog's Photo Gallery(0)
Squeak just does not bother me. I guess it should, it does not. Too busy enjoying myself, with too big a smile to hear the squeak. :-)
Steve
  #23
Old August 22nd, 2012, 08:08 PM
Total Loss's Avatar
Member #4844
View Total Loss's Photo Gallery(33)
You must pull the sleaves out and pack them.
Unless you like squeeks and guick bushing wear.
Also- don't overtighten the shock bolts. Let them float a little
"When you are going through hell, just keep going"
Winston Churchill
  #24
Old August 22nd, 2012, 09:32 PM
roadking's Avatar
First Name: Kim
My RZR: 2010 RZR S White
Member #15466
View roadking's Photo Gallery(0)
I took ALL the bushings , sleeves and bolts apart both front and rear and upper and lower a arms and greased with marine wheel bearing grease. Don't forget to do the shocks the bushings in them were dry as a bone just like the a arms. If you neglect the noise the bushings will wear out, which could be costly or even dangerous. I will make this a seasonal maintence from here on...
  #25
Old August 23rd, 2012, 06:30 AM
ShakyDog's Avatar
Member #41826
I am not ignoring the squeak. I am waiting on the needed maintenance because I am without a good torque wrench. Once that is found and purchased, I will be removing quite a bit of parts and lubing away.
Steve
  #26
Old August 23rd, 2012, 08:21 AM
scotty1111's Avatar
Desert Rat
First Name: Scott
My RZR: 2010 RZR S LE Purple Thunder
Member #14659
View scotty1111's Photo Gallery(0)
Shaky, you can get a decent click type torque wrench that will serve the purpose at Harbor Freight or Northern Tool. Everyone has been asking for torque specs, they are listed below. Note: Shock bolt torque is important, do not over-tighten. Spec is 27-33 ft.lbs.
1. Install lower A-arm assembly onto vehicle frame. Torque
new fasteners to 33 ft. lbs. (45 Nm).
2. Attach lower A-arm to bearing carrier. Torque new fastener
to 38 ft. lbs. (52 Nm).
3. Route brake line on top of the lower A-arm and between
lower shock mounting tabs.
4. Reinstall the lower portion of the shock to the lower A-arm.
Torque shock fastener to 27-33 ft. lbs. (37-45 Nm).
5. Install upper A-arm assembly onto vehicle frame. Torque
new fastener to 33 ft. lbs. (45 Nm).
6. Attach upper A-arm to bearing carrier. Torque new fastener
I don't replace the fasteners every time I take it apart. If there are issues with the fastener or nut then I replace them. If you're worried about the nut backing off, use a drop of BLUE Loctite (NOT RED).
Dune Shooting is indeed a blood sport, at least in my case!
You can say 'STOP' or 'ALTO' or use any other word you think will work, but I've found that a large bore muzzle pointed at someone's head is pretty much the universal language.
  #27
Old August 24th, 2012, 07:07 AM
csvette3023's Avatar
First Name: Matt
My RZR: 2009 RZR Camo
Member #31819
View csvette3023's Photo Gallery(0)
http://www.rzrforums.net/projects-ho...have-come.html
  #28
Old August 26th, 2012, 04:58 PM
tankertrooper's Avatar
Member #26154
View tankertrooper's Photo Gallery(0)
I just pulled the bolts and greased everything with polaris waterproof brand and havent heard nothing all summer
  #29
Old August 30th, 2012, 09:34 AM
Heston83's Avatar
Member #43919
View Heston83's Photo Gallery(0)
Texas Re: Rear end squeak with pictures.
Quote: Originally Posted by CFDWheeler View Post
Mine squeeks like hell too. Do you take the bolts out to grease them or just leave them in? Also, what kind of grease do you use? Spray white lithium, or what?
I am a distributor for Green Grease. Waterproof, synthetic, high-temp stuff. It's the best Ive ever seen (which is why Im now a distributor...) Anyway, its $8.95/14 oz tube, and fits in your grease gun. I usually ship it out on the same day you order, so you'll have it pretty quickly.
I have two Ebay sales going for it right now. Single tubes, as well as 10-tube cases. Check my feedback, 100%, and you get the security of PayPal.
Single tubes:
14oz Single Waterproof Green Grease! High Perf, Synthetic, High Temp Grease | eBay
Cases:
Case of 10, 14oz Waterproof Green Grease! High Perf, Synthetic, High Temp | eBay
  #30
Old August 30th, 2012, 10:12 AM
BarRZR's Avatar
My RZR: 2012 RZR 800-S L/E
Member #32278
Quote: Originally Posted by csvette3023 View Post
This ought to be a sticky! I did mine, and it sure makes lubing the rear bearing-carrier bushings EASY!
Also, Green Grease is available from Amazon; 3 tubes for $10.99:
Amazon Amazon
Cheers
brand new rzr s rear end squeks
grease coming out of back of rzr
polaris razor squeak rear end
polaris razor squeaky rear end
polaris rzr rear end squeak
polaris rzr s squeak
polaris rzr s squeaky rear end
rear end squeak
rzr s grease spray
rzr s rear end squeaking
rzr squeeking in rearend
spendle bushings tork
squeak in rear 2011 rzr
squeaky rzr
squeak..squeak...squeak Bigbadfords General RZR Discussion 16 April 25th, 2010 04:10 PM
NEED RIGHT REAR INNER CV or Complete rear axle rzrgrl Want to Buy 5 February 16th, 2009 08:05 PM
RZRS Rear bumper to protect the rear tail lights. Daryle Skaugstd Bumpers, Skid Plates and RZR Protection 0 October 16th, 2008 01:15 PM
WTB front and rear bumpers, rear acc. bar, Harryscarlot Want to Buy 0 August 4th, 2008 07:11 AM
Pictures of lock and ride rear box? vmax4 General RZR Discussion 43 May 10th, 2008 12:00 PM
