rear shock squeak - Polaris RZR Forum - RZR Forums.net
rear shock squeak
This is a discussion on rear shock squeak within the RZR-S Specific Discussion forums, part of the General RZR category; I have a 2009 RZR S with a bad squeak in rear. I finally isolated it to the top rear shock mount. I removed the ...
Old April 26th, 2012, 10:48 AM   #1
dennis248's Avatar
Member #38247
View dennis248's Photo Gallery(0)
rear shock squeak
I have a 2009 RZR S with a bad squeak in rear. I finally isolated it to the top rear shock mount. I removed the bolt, cleaned it and applied light grease. I tightened the bolt and nut back to 37 ft lbs with a torque wrench and it still squeaks. When I loosen the nut about 1/2 turn the squeak stops. Anyone else have this issue? I am considering adding a second nut as a jam nut and leave it looser than the 37 ft lbs. I also tried a couple of different types of lubrication for the shock mount but it still squeaks if I torque it to the recommended setting.
Dennis
dennis248 is offline   Reply With Quote
Old April 26th, 2012, 11:00 AM   #2
N0OSV's Avatar
First Name: Jim
My RZR: 2010 RZR
Member #29795
View N0OSV's Photo Gallery(0)
Rzr Icon Re: rear shock squeak
I would not leave the nut loose. Is it possible noise is between the bushing and the shock? You greased between the bolt and bushing but how about bushing and shock. The bushing can be removed. It's a little difficult but can be done.
N0OSV is offline   Reply With Quote
Old April 26th, 2012, 11:02 AM   #3
BlairW's Avatar
My RZR: 2011 RZR-S LE Orange Madness
Member #16164
View BlairW's Photo Gallery(0)
http://www.rzrforums.net/rzr-s-speci...intenance.html
BlairW is offline   Reply With Quote
Old April 26th, 2012, 11:11 AM   #4
Feedback Score: 4 reviews
jmattor's Avatar
First Name: Jim
My RZR: 2010 RZR 4bo
Member #12929
View jmattor's Photo Gallery(19)
Quote: Originally Posted by BlairW View Post
That's the post you want right there ^
It isn't the bolt that's squeaking. Take 'em apart and clean them up and lube them good. Mine were a mess!
I love the smell of styrene in the morning....
jmattor is offline   Reply With Quote
Old April 26th, 2012, 09:40 PM   #5
dennis248's Avatar
Member #38247
Great information. I will work on taking the shock mount apart to lube it. Thank you for the tip! Dennis
Old April 29th, 2012, 03:31 PM   #6
Desert Rat
scotty1111's Avatar
First Name: Scott
My RZR: 2010 RZR S LE Purple Thunder
Member #14659
View scotty1111's Photo Gallery(0)
Dennis, the torque specs in all my books say all the shock bolts torque to 27-33 ft.lbs. 37 will bind them. Also, if the squeak doesn't go away, take a look at the upper bearing carrier bolt/bushing (outer end of the rear upper a-arm). That rascal will squeak up a storm.
Dune Shooting is indeed a blood sport, at least in my case!
You can say 'STOP' or 'ALTO' or use any other word you think will work, but I've found that a large bore muzzle pointed at someone's head is pretty much the universal language.
scotty1111 is offline   Reply With Quote
Old April 29th, 2012, 07:04 PM   #7
dennis248's Avatar
Member #38247
Thanks Scotty. i need to get my own service manual. i got the spec off another post.
Old April 30th, 2012, 02:06 PM   #8
Desert Rat
scotty1111's Avatar
First Name: Scott
Member #14659
ITEM TORQUE VALUE
ft.lbs. (Nm)
Front LH / RH Upper A-Arm Bolt 33 ft. lbs. (45 Nm)
Front LH / RH Lower A-Arm Bolt 33 ft. lbs. (45 Nm)
Rear LH / RH Upper Control Arm Bolt 33 ft. lbs. (45 Nm)
Rear LH / RH Lower Control Arm Bolts 33 ft. lbs. (45 Nm)
Lower LH / RH Rear Bearing Carrier 38 ft. lbs. (52 Nm)
Upper LH / RH Rear Bearing Carrier 33 ft. lbs. (45 Nm)
Outer Tie Rod to Bearing Housing 42.5 ft. lbs. (58 Nm)
Front Ball Joint Pinch Bolts 17 ft. lbs. (23 Nm)
Front Upper / Lower Shock Bolt 27-33 ft. lbs. (37-45 Nm)
Rear Upper / Lower Shock Bolt 27-33 ft. lbs. (37-45 Nm)
Front Wheel Hub Castle Nut 80 ft. lbs. (108 Nm)
Rear Wheel Hub Castle Nut 80 ft. lbs. (108 Nm)
Wheel Nuts (Cast Rims) 90 ft. lbs. (122 Nm)
Wheel Nuts (Steel Rims) 27 ft. lbs. (37 Nm)
Tie Rod End Jam Nut 12-14 ft. lbs. (17-19 Nm
Seat Belt to Seat Base 40 ft. lbs. (54 Nm)
Steering Wheel to Shaft 25-31 ft. lbs. (34-42 Nm)
Upper Steering Shaft to U-Joint Shaft 15-19 ft. lbs. (20-26 Nm)
Lower Steering Shaft to Box 30 ft. lbs. (41 Nm)
Steering Box 17 ft. lbs. (23 Nm)
Old April 30th, 2012, 07:25 PM   #9
dennis248's Avatar
Member #38247
Scotty : You r the man,
Gun Robh Math Agad ( Scottish for Thank You )
Old June 21st, 2012, 06:51 PM   #10
Prmcconn's Avatar
Member #33613
View Prmcconn's Photo Gallery(0)
Ok the book calls that bolt a pinch bolt. The one attached to the cv housing next to the wheel. Now call me crazy but is that bolt suppose to be turned lefty loosy to remove and slide out. Because I just tried mine and use crazy force and all of a sudden I heard a snap noise like I just hurt the bolt. Does anyone know how to get that damn bolt off so I can grease it. Thought the noise was the shocks like everyone else and I was clearly mistaken. Damnit.
2012 rzr s le white/orange madness
Prmcconn is offline   Reply With Quote
Tags
rzr s suspension
bolt super squeak
how to stop shocks from squeaking
polaris rzr sqeeking shock mount
rear shoch squeeks
rear shock squeak
rear shocks bolt squeak
rear shocks squeak
rzr forum shock squeak
rzr rear shock squeaking
rzr s rear end squeaking
rzr s squeak
squeak
squeaky rzr shocks
squeaky rzr tie rods
why do shocks squeak
Rear end squeak with pictures. DWRAT RZR-S Specific Discussion 35 September 14th, 2012 12:17 PM
rear shock keith0715 Want to Buy 1 March 17th, 2011 05:35 PM
Rzr s rear shock donjulpax Want to Buy 5 March 14th, 2010 03:28 AM
A new squeak coming from rear Joey RZR-S Specific Discussion 9 October 18th, 2009 04:40 PM
WTB rear axle and rear shock zimpun Want to Buy 0 August 18th, 2009 06:07 AM
