No Power???
This is a discussion on No Power??? within the RZR-S Specific Discussion forums, part of the General RZR category; I have battery charged to 12+ volts but, no power on the rig . . . Where should I look??? The 75 amp fuse is ...
RZR-S Specific Discussion Please limit this to RZR-S only!
Old January 21st, 2012, 07:50 PM
DuneMe's Avatar
1 Mark in a world o Mikes
My RZR: RZR-S
Member #3684
View DuneMe's Photo Gallery(0)
No Power???
I have battery charged to 12+ volts but, no power on the rig . . . Where should I look??? The 75 amp fuse is fine. . . The fuses in the fuse box (at least the ones on the left) look good too.
I have no power but, the battery is good???
I have a stereo system (actually an Amp.) connected to the battery (but, that is a seperate connection. I'll check the fuse on it.)
No other accessories.
2005 GMC Duramax
WW LE3505 + 4'
RZR-S
Raptor 700's for the Wife and I
Raptor 250 for the Daughter
Old January 21st, 2012, 08:08 PM
King of crash!
Feedback Score: 8 reviews
Member #787
Re: No Power???
bad connections or ground... dont just look take apart and clean them all it doesnt take much... get a volt meter and ck youll find it fast that way. also if you have volts up to fuse box the ign switch gets dirty and makes bad connection also ck that too
Old January 21st, 2012, 08:19 PM
FunRide's Avatar
First Name: Jim
My RZR: '11 S
Member #17399
Re: No Power???
Check your battery terminal connections too. Clean and make them tight, not sort of hand tight.
Old January 21st, 2012, 09:18 PM
DuneMe's Avatar
My RZR: RZR-S
Member #3684
Re: No Power???
I think they are tight, but I will check again tomoeeow. . .
Oh, I did check the power (with a voltage meter) for the BRAKE LIGHT SWITCH (I think). I didn't have the Brakes Depressed but, there was no power (now I need to check that B4 I go to bed. . . )
Let me check that. But, it does prove I have power downstream of the battery so, my battery connections should be good. . .
2005 GMC Duramax
WW LE3505 + 4'
RZR-S
Old January 21st, 2012, 09:46 PM
DuneMe's Avatar
My RZR: RZR-S
Member #3684
Re: No Power???
OK checked everything but, now that I think of it, I was checking against the positive node but, I was checking against the negative connection on the battery. So, I'll have to check the negative connections on the battery tomorrow.
2005 GMC Duramax
WW LE3505 + 4'
RZR-S
Old January 22nd, 2012, 03:39 AM
scottymac's Avatar
My RZR: is red and white and scratched all over
Member #33814
View scottymac's Photo Gallery(1)
Re: No Power???
If it is a 2010 and newer there is a small fuse box on the lower rear passenger side frame that holds 2 fuses. Check and make sure they are seated. Mine came loose on a ride and I lost all power while I was in the woods.
Old January 22nd, 2012, 01:50 PM
DuneMe's Avatar
My RZR: RZR-S
Member #3684
Re: No Power???
It is a newer model (I think???) but, I'll look. . .
(Just back from Church abd now there is football that will take my afternoon. . . )
Anyone share a picture???
2005 GMC Duramax
WW LE3505 + 4'
RZR-S
  #8
Old February 2nd, 2012, 07:00 PM
DuneMe's Avatar
My RZR: RZR-S
Member #3684
Mwink Re: No Power???
I'm back from vacation (Disneyland Wha-Who.)
Still have the same issue. . .
Checked The Key per the manual - good.
Checked The Break Pressure Switch also per the manual - good.
What should I check next?
2005 GMC Duramax
WW LE3505 + 4'
RZR-S
  #9
Old February 2nd, 2012, 08:18 PM
jmattor's Avatar Premium Member
Feedback Score: 4 reviews
First Name: Jim
My RZR: 2010 RZR 4bo
Member #12929
View jmattor's Photo Gallery(19)
Re: No Power???
When you say that you checked the key...what exactly did you check?
I had an issue with the ignition switch where the wires came loose on the backside....no ignition. Pulled the switch and crimped all the wires and haven't had a problem since.
When checking all the fuses, use an ohm meter, not just a visual check. Sometimes they look good but aren't.
Lastly, fusible links on the + cable from the battery. If you shorted something, a link may have blown.
Good luck, hope you fix it.
I love the smell of styrene in the morning....
  #10
Old February 2nd, 2012, 09:02 PM
DuneMe's Avatar
My RZR: RZR-S
Member #3684
Re: No Power???
I'll check the cables to the ignition tomorrow for continuity. I too noticed they did seem like they could be loose.
That is exactly why I post stuff on this forum. . .
2005 GMC Duramax
WW LE3505 + 4'
RZR-S
  #11
Old February 4th, 2012, 12:14 PM
DuneMe's Avatar
My RZR: RZR-S
Member #3684
Re: No Power???
What voltage should I see on these (unconnected.)
I got 0 on the 1st one and very small voltage on the 2-4 pins.
(Is this right???)
If I wasn't clear before, this is on the 4 wires that are connected to the back of the key. I used my multi-meter when the unit was disconnected from the key.
2005 GMC Duramax
WW LE3505 + 4'
RZR-S
  #12
Old February 6th, 2012, 08:59 PM
DuneMe's Avatar
My RZR: RZR-S
Member #3684
Question Re: No Power???
Anyone???
2005 GMC Duramax
WW LE3505 + 4'
RZR-S
  #13
Old February 8th, 2012, 01:15 PM
DuneMe's Avatar
My RZR: RZR-S
Member #3684
Re: No Power???
SomeTING is wrong???
2005 GMC Duramax
WW LE3505 + 4'
RZR-S
  #14
Old February 8th, 2012, 01:20 PM
First Name: Jim
Member #12929
Re: No Power???
(Is this right???)
Doesn't sound right. Mine were loose, so it was easy to fix. If you aren't gettiong 12v at the switch you should chase those wires back to a fuse.
  #15
Old February 8th, 2012, 02:40 PM
kbigo09's Avatar
Member #23505
View kbigo09's Photo Gallery(0)
Re: No Power???
i had this SAME exact problem with my 2011 i could be riding and the whole bike would shut off like i disconnected the battery then after a few turns of the key bam it would turn on again. the problem i had with mine was the dielectric grease in the ignition plug(right behind the key) was getting water in it so i cleaned it up redid the grease and bam havent had a problem since.
08 rzr 170 no power to ignition
08 teryx not getting power to fuse box
2008 rzr no 12 volt power to start
check ignition switch
no power
no power in rzrs after washing
polaris rzr 170 no power to key switch
polaris rzr 170 won't start
polaris rzr no power
polaris shorted battery no power
raptor 700 key on no power
rzr brake pressure switch delete
rzr lost all power would not crank
rzr lost power
rzr no power
rzr no power to key
rzr s fuse box
rzr shut off no power
short on my polaris rzr no power
what fuses check on rzr polaris
more power Wicked93 RZR 170 Specific Disccusion 5 September 29th, 2011 08:26 PM
Winch power leads and 1314 Sure Power tachdriver General RZR Discussion 4 November 22nd, 2010 01:49 AM
need more power mikemnkt Forced Induction 2 December 8th, 2009 10:35 AM
I need power!!!!!!!!!!!!!!!!!! budlight_87 RZR-S Specific Discussion 55 October 21st, 2009 08:13 AM
rzr s needs some power bigguyrides RZR-S Specific Discussion 9 March 3rd, 2009 07:51 AM
