Add-on Temp gauges - Polaris RZR Forum - RZR Forums.net
post #1 of 27 Old December 28th, 2011, 08:35 AM Thread Starter
NorCalRzr-S
jrdelgiorno's Avatar
First Name: Junior
My RZR: 2011 Rzr-S(Modified)
Member #32033
Feedback Score: 12 reviews
View jrdelgiorno's Photo Gallery(10)
Rzr Icon Add-on Temp gauges
I see allot of you seasoned rzr drivers have additional gauges on your dashes. Im assuming one is a temp gauge attached to the coolant line. What gauges are recommended that most of you install and how easy are these additional monitoring systems/gauges to install? Who sells the complete install kits with lines, wires, gauges, hoses, etc...?
2011 Rzr-S
2009 36' Fuzion Fiver
2006 Dodge3500 Mega, 6"lift
Junior DelGiorno
Prior USN/USMC & Damn proud of it!
jrdelgiorno is offline
post #2 of 27 Old December 28th, 2011, 08:44 AM
YFZ 508s
YFZ508's Avatar
First Name: jason
My RZR: rzrS rzrLE rzr170rzr900s
Member #16332
View YFZ508's Photo Gallery(24)
Re: Add-on Temp gauges
i'm going to be installing a volt,temp. and oil pressure gauge,as soon as my parts come in,i was able to get everything i needed from ebay for only 62 something,i may however have to pick up a adaptor or two,not sure what comes with the gauges i bought,look on summit racing web site they have 3 gauge pods cheep
YFZ508 is offline
post #3 of 27 Old December 28th, 2011, 08:45 AM Thread Starter
NorCalRzr-S
First Name: Junior
Member #32033
I understand the concept of monitoring your oil & temp, but why the Voltage?
2011 Rzr-S
Junior DelGiorno
post #4 of 27 Old December 28th, 2011, 08:56 AM
YFZ 508s
YFZ508's Avatar
First Name: jason
Member #16332
just to make sure the system is charging the battery,,and also i have a 400watt amp sucking out some juice,just a little piece of mind
YFZ508 is offline
post #5 of 27 Old December 28th, 2011, 09:14 AM Thread Starter
NorCalRzr-S
First Name: Junior
Member #32033
Makes good sense. Does the voltage gauge just connect directly to the battery? What if you have a dual battery system isolated with a Warn isolator?
2011 Rzr-S
Junior DelGiorno
post #6 of 27 Old December 28th, 2011, 10:13 AM
turkeyhunter's Avatar
First Name: gary
My RZR: XP turbo
Member #16815
View turkeyhunter's Photo Gallery(0)
A really nice set up is the Dakota gauge pkg. It's not cheap but is one of the best out there.
turkeyhunter is offline
post #7 of 27 Old December 28th, 2011, 11:11 AM Thread Starter
NorCalRzr-S
First Name: Junior
Member #32033
Does the Dakota gauges have all of the gauges needed as well as connections? How about water tight?
2011 Rzr-S
Junior DelGiorno
post #8 of 27 Old December 28th, 2011, 11:47 AM
First Name: gary
My RZR: XP turbo
Member #16815
I went with the full speedo set up. It replaces factory speedo and has speed, rpm,odom, 2 trips, clock, water temp, oil pressure, volts, fuel. Your factory wires just plug in and all there sensors plug in. My only concern I see is I'm not sure if they make them for a 2011 yet. Yes water tight.
post #9 of 27 Old December 28th, 2011, 12:55 PM Thread Starter
NorCalRzr-S
First Name: Junior
Member #32033
Gary, Is this the setup you're talking about;
UTV-1500
2011 Rzr-S
Junior DelGiorno
post #10 of 27 Old December 28th, 2011, 01:38 PM
First Name: gary
My RZR: XP turbo
Member #16815
UTV-1500
Thats it..
post #11 of 27 Old December 28th, 2011, 06:44 PM
YFZ 508s
YFZ508's Avatar
First Name: jason
Member #16332
UTV-1500
I guess be ready to fork over some $$$$ if you wanta go with that way,,if i had the extra $$$ i would,but us poor ppl have to do what we can to achieve the same result
YFZ508 is offline
post #12 of 27 Old December 28th, 2011, 06:52 PM Thread Starter
NorCalRzr-S
First Name: Junior
Member #32033
Yeah, I checked those gauges package out, OMG, its like a $500 upgrade! Crazy...
2011 Rzr-S
Junior DelGiorno
post #13 of 27 Old December 29th, 2011, 01:51 AM
rollo331's Avatar
Member #20398
View rollo331's Photo Gallery(0)
wow that price is unreal
rollo331 is offline
post #14 of 27 Old December 29th, 2011, 04:30 AM
First Name: gary
My RZR: XP turbo
Member #16815
Yep Like I said up front it"s good BUT pricey....
post #15 of 27 Old December 29th, 2011, 05:08 AM
Banned
itsruf's Avatar
First Name: Mark -
Member #16159
Then that gage is even more desirable. Would be great to monitor your voltage. Just like having a multimeter right on the dash.
Wouldn't it be nice to toggle between the devices on read voltage at each. Just as if you were placing your test lead on each individually.
itsruf is offline
Got Gauges?? Cordachine Muddin' 41 May 26th, 2015 04:12 PM
temp, oil gauges? sethholcomb Engine and Drivetrain 3 January 22nd, 2011 01:25 AM
Water, Oil and Trans Temp Gauges How to RZR4Ratz RZR 4 Specific Discussion 5 November 28th, 2010 09:00 PM
Gauges Cordachine Lighting, Stereo and Electrical 17 June 19th, 2009 11:43 PM
More Gauges :) B-rad Projects and How-To 1 March 10th, 2009 07:54 AM
