The service manual only calls for an oil change at 25 hours and a check of all the other fluids with a change done once a year. I have read that a lot of guys on here change everything and 25, personal preference. For no more fluid than the trans and gearcases hold i think i will be changing mine at 25 and yearly after that.
I changed all my fluids after 10hrs, thought that's what the manual said. Nope, 25. All my fluids were really clean at 10 so 25 is probably ok. I'll change the engine oil again at 35 and the others at 50 or so. I did drain the tranny again, because I'm doing the gear weld mod, and it was still really clean.
As far as tips go (if you're doing it yourself) be careful not to over tighten your drain plugs. Also, if you remove your skid, the skid bolts are as soft as chewing gum and will snap off easy too.
i change my engine oil and filter every 300 miles..just because im anal about the possibilty of particles getting in the oil like dust...the diffs and tranny i check them every 6 months and change those anually..I do have the UMP inatke and i check that filter about once a month...havent needed to change it yet with over 900 miles on it...still looks new on the inside and out but i did order two spares just in case..
Related Threads
3.1M posts
141.5K members
Since 2007
