I have recently done alot to my Rzr within the past couple weeks getting ready for a trip. I added Muzzy exh, PCV, Auto Tune, Epi Clutch, EMP intake, Adjusted throttle cable. I had also tapped into fuse panel to have accessories on their own toggle switch and through Ignition, the accessorie are ran through a fuse panel, with individual fuse blocks. as of now only 3 accessories wired in. Winch with relay, stereo with relay, and under body LED lights. I sat in the RZR and started it, I quickly relized that I am throwing a code. I went through the diagnosis and came up with numbers 32, and 58. the # 32 had no info, and 58 had to do with: Cooling Fan: Open Load, Cooling Fan: Short Circuit to Ground, Cooling Fan: Short Circuit to Battery, all of those fall under 58. Did I mess up the fan relay? What and how can I check things out? Any thoughts and ideas would be greatly appreciated!
