Home fabbed swat bar??????? - Polaris RZR Forum - RZR Forums.net
 7Likes
post #1 of 26 Old March 17th, 2017, 04:43 PM Thread Starter
AZRIDER82146's Avatar
First Name: Don
My RZR: '15 900 S/'10 800 S
Member #187593
View AZRIDER82146's Photo Gallery(0)
Home fabbed sway bar????
Ok, guys, new to the forum. If you read my intro, I have a 2010 RZR S with 10,000 miles on it. I said "trouble free"; but things DO wear out and break.
Well, around 8000 miles, my sway bar broke, right in the bend. I have tried welding it, but not with much success. It has worn to where it is too thin.
So,with all that being said.......has anyone taken some 1 inch by 3/32 or 1/8 wall tubing and fabbed their own, by just using a tubing bender and forming it up??
I have just been running without it for the last 1000 miles or so, which is OK; but the fact that I don't have one just bugs me!!! My OCD kicks in once in a while!!!!
Thanks in advance for any response!!
AZRIDER82146 is offline
post #2 of 26 Old March 17th, 2017, 05:25 PM
Clubin's Avatar
First Name: Clayton
My RZR: XPT
Member #61303
Re: Home fabbed swat bar???????
Can't. It's spring steel.
2016 XPT
EVO stage 2
EVO captains choice exhaust
EVO charge tube
OSP clutch kit
Rockford Fosgate Stage 4
Clubin is online now
post #3 of 26 Old March 17th, 2017, 10:46 PM
phantomusa's Avatar
First Name: Pappy
My RZR: 2012 RZR S 800 HO
Member #81875
View phantomusa's Photo Gallery(0)
I do believe you need more then a bent piece of pipe I'm sure it's a special treated steel so it will spring back into shape
Pappy
Sent from my SM-S975L using Tapatalk
Olemissguy likes this.
phantomusa is offline
post #4 of 26 Old March 18th, 2017, 02:20 AM
Rzr800s2009's Avatar
Member #182737
View Rzr800s2009's Photo Gallery(0)
This is correct.
Any reason why not to just go source a used one?id have done that before even attempting to weld it.
Rzr800s2009 is offline
post #5 of 26 Old March 18th, 2017, 06:43 AM Thread Starter
First Name: Don
Member #187593
This is correct.
Yup!!!!! As stated.......it just bugs me that I can't fix or make one!! That is all.
When trying to weld my broken one, it welded like mild steel; but as stated, was too thin to have any strength. And I will probably try fabbing one, just to see what happens!! If it works, I will let everyone know how it turns out!!
post #6 of 26 Old March 20th, 2017, 03:27 AM
Member #182737
This is correct.
Well cant blame ya there but things are what they are.Even if you found the sprung steel to do it the welding would probably weaken or take the spring from the steel.
Id say if you wanted to re-invent the wheel so to speak here theres plenty of other areas that could use some more intelligence and thought added to these things for much needed improvements.
post #7 of 26 Old March 28th, 2017, 02:54 PM Thread Starter
First Name: Don
Member #187593
OK Flag Re: Home fabbed swat bar???????
Well, boyz n gurlz........done deal!!angel
Just FYI......I pulled the old sway bar out and did a couple tests on it.
1. Took a center punch and hammer, and gave it a good rap on an un-damaged place of the old sway bar......it left a divot in it like it would in mild steel.
2. Took a drill and tried drilling where the divot was.....it drilled like mild steel.
3. Touched the old sway bar to a grinder, and it threw a spark pattern like mild steel
Good to go!!
When I was in town, I stopped at a steel warehouse and picked up a 5 foot piece of 1 inch tubing/ 1/8" wall thickness. I put it in the tubing/pipe bender with the correct die....bend, bend, to proper length. Cut the ends to proper length, flattened the ends, drilled holes in the proper place and bolted it in!!!!
$7.64 total price and had about 15" of tubing left over!!! Quite simple, actually!!
I guess I learned the old oilfield way.......if ya CAN'T do it, ya CAN'T stay!!!!!!!!!
Thank you for all the great information!!
post #8 of 26 Old April 18th, 2017, 12:10 PM
Life is Good!!
RZRBLDE's Avatar
First Name: T.J.
My RZR: 2011 RZR S 800
Member #42201
View RZRBLDE's Photo Gallery(14)
Good Job!! This is a common problem, they all break! My RzR broke one and my step-dad has a Ranger and it broke in the same spot.
2011 RZR s 800 7600mi.
2000 Dodge Ram 2500 5.9 Cummins
RZRBLDE is offline
post #9 of 26 Old April 18th, 2017, 09:43 PM
Wanna Ride's Avatar
Member #182841
View Wanna Ride's Photo Gallery(0)
Regardless, it was still spring steel. Your new one won't operate, or last, like the original one made of spring steel.
Wanna Ride is offline
post #10 of 26 Old April 18th, 2017, 10:02 PM Thread Starter
First Name: Don
Member #187593
Read post #7! This old fart does know how to test various types of steel, etc.
If it walks like a duck...........
post #11 of 26 Old April 19th, 2017, 06:13 AM
Life is Good!!
RZRBLDE's Avatar
First Name: T.J.
Member #42201
I agree with Wanna Ride...mild steel is NOT spring steel. Just cuz' you can center punch it and drill it does not mean anything when it comes to it's performance. I admire your self-sufficiency and desire to save a few bucks, but time will tell.
RZRBLDE is offline
post #12 of 26 Old April 19th, 2017, 06:37 AM Thread Starter
First Name: Don
Member #187593
So called "spring" steel is made from medium to high carbon steels. Medium to high carbon steels will throw a different spark pattern than mild steels when held to a grinder.
Medium to high carbon steels will "chip" rather than machine smoothly like mild steels.....i.e. When trying to drill them with a drill bit or when trying to machine them in a lathe.
Medium to higb carbon steels will likely break the end off of the center punch when trying to punch them.
Thanks! School's over.
post #13 of 26 Old April 19th, 2017, 06:49 AM
Life is Good!!
RZRBLDE's Avatar
First Name: T.J.
Member #42201
Okay...good luck, "teacher"
RZRBLDE is offline
post #14 of 26 Old April 19th, 2017, 06:51 AM
Ridin' above 10,000 ft!
J to the B's Avatar
First Name: Jim
My RZR: 2015 XP1K Blue Dragon
Member #6112
View J to the B's Photo Gallery(21)
Important to note is the sway bar straight piece provides frame support. Remove it and you could end up with a cracked frame like FJK several years back.
J to the B is online now
post #15 of 26 Old April 19th, 2017, 08:54 AM
Wanna Ride's Avatar
Member #182841
Oh good, someone who has a little knowledge on steel and machining. No one else here has ever worked in that industry! And when you have a moment, google Kruger-Dunning effect. Have a great day, Richard and you keep on welding up those custom "swat" bars.
UTV INC & Totron 30" LED Light Bar Kit UTV Inc. UTV Inc 53 October 11th, 2016 07:56 AM
Winjet 30" Curved Light Bar Sshsjd10 RZR S 900 2 August 24th, 2016 06:11 AM
Currie Polaris RZR XP Antirock Rear Sway Bar Kit Sxsperformance SXSPerformance.com 2 August 23rd, 2016 10:22 AM
Currie Enterprises Antirock Sway Bar Kit Sxsperformance SXSPerformance.com 2 March 10th, 2016 03:22 PM
