This is a discussion on should i remove rear sway bar? within the RZR-S Specific Discussion forums, part of the General RZR category; someone told me i should remove my sway bar.is this good to do?i have a 2010 rzr-s...
| RZR-S Specific Discussion Please limit this to RZR-S only! |
| Sponsored Links | ||
Re: should i remove rear sway bar?
I haven't had sway bars since the long travel. Don't even think about it anymore.
Try disconnecting without removing and see if you like it. |
Yes you get more roll but as stated got use to it pretty quick.
Ride Glamis and desert. Something I've never tried to do allot is slide the back end. A little is fun but too many vid's of rolling due to improper slides. Also if your accidentally in AWD things can go bad. I thought you can disconnect the rods without too much problem to try it out??? |
I have removed my front, and left the rear connected... it gets little hairy driving fast in the hard pack with the rear disconnected. You get way better articulation in the front without them.
The 2010 RZR-S does not have a front sway bar only the rear.
I think if you are talking the straight RZR removing the front sway bar would be just fine but I would be a bit scared to get rid of the rear one. Let us know what you do and how the ride turns out. |
#9
havent had a rear sway bar since it broke a cpl of months back. really like it that way.and sorry to contradict, but mines an 08 std rzr, and opz's2010,we both got frt swaybar.
#10
I liked the rear sway bar off. Then I installed the progressive springs and Loved it even more.
09 Weber RZR 130HP w/ Makin Trax XPS 60" conversion
#11
I took my front say off and it wasnt cool IMHO for the dunes...I put it back on right away. I have a standard RZR. RZRS's dont have a front say...only a rear. Your best bet is to remove it and see what you think...if you dont like it put it back on.
#13
Same as trailblazer. Once it broke, just removed the pieces. I think it's a little goosier in the rear without it.
I think the answer on whether you need it depends on the type of riding you do. If it's low speed rock crawling kind of thing, you can probably do without it. If it's higher speed duning, might want to leave it. |
#15
I think it also depends on springs, rear sway off with stock springs is squirly, with after market springs like the King Progressives, it rides fine at high speed. I have a RZR no an S
Factory UTV Skids & A-Arms, UMP Filter J-Strong Roof, Stereo & 4" HIDs ITP SS212, 26" Bighorns,WARN Winch Trinity Stage 4 pipe & Trinity fuel control, Dirty Dawg Clutch Afco MT1 shocks (with progressive springs) They're Awesome ![]() 1 Limey in a world of Yanks
| Search tags for this page |
can i improve articulation on a polaris atv,how to disconnect rear sway bar rzr s,how to remove sway bars on polaris rzr xp?,rear sway bar broke on rzr after lift install,rear sway remove,remove rear sway bar,removing rear sway bar on 2008 rzr,removing rear sway bar on polaris rzr s,rzr s articulation gains,should i disonnect sway bars on rzr,should i remove rear sway bar on rzrs,should i remove the sway bar on rzr after lift,take off rear sway bar,why you should not remove your sway bar,will removing my sway bars really be that good
| Thread Tools | |
| Display Modes | |
| Remove the rear sway bar if you have progressive springs? | Tuf-Skin | Suspension | 24 | December 21st, 2009 03:04 PM |
| Rear Sway Bar | UTVRZRREBEL | Suspension | 4 | December 12th, 2009 05:34 PM |
| Remove rear diff without removing motor | hiddenfromtherest | Engine and Drivetrain | 7 | June 11th, 2009 05:04 PM |
| Rear Sway Bar | crashncash | Want to Buy | 2 | June 11th, 2009 03:44 AM |
| Rear RZR sway bar? | bearfoot | Suspension | 0 | January 24th, 2009 12:08 PM |
