2013 Rzr 800 s Throttle sensor - Polaris RZR Forum - RZR Forums.net
This is a discussion on 2013 Rzr 800 s Throttle sensor within the RZR-S Specific Discussion forums, part of the General RZR category; Anyone else having issues with their 2013 800 s throttle sensor ? Mine started after about the first 5-6 hours of use. I would start ...
Old May 15th, 2013, 08:54 AM   #1
Zornff's Avatar
Member #51819
View Zornff's Photo Gallery(0)
Anyone else having issues with their 2013 800 s throttle sensor ? Mine started after about the first 5-6 hours of use. I would start it, and then try to give it thottle and it would act like it was staving for fuel. A friend bought one soon after me and it started doing the same thing.
All i have found out is that they are having this issue with the '13's. The reset is to turn the key to on, then depress gas pedal 5-10 times, turn off and then should be good. Mine started doing it everytime i started it, so i am having it looked at, and picking it today with fingers crossed.
I hope they recall these and get it fixed permanantly.
2013 800s blue fire
PA doors, cab, front bumper, Holz rear bumper w/spare, moto alliance viper w/syn rope, EMP mr10 windshield w/wiper, EMP cargo cover, SLP clutch, EZ steer, firestorm heater, 28" Kamati Mongrels, Mastercraft seat belts. Camoplast Tatou 4s tracks for winter.
2014 900 XP 4 EPS orange madness.
Trail armor doors, PRP seats, 5 points, 1/2" skid, Zbros trailing arms, SLP clutch, raceline beadlocks w/30" Kahuna's, custom DG cage, custom soft top, heater, moto alliance winch.
Zornff is offline   Reply With Quote
Old May 15th, 2013, 08:56 AM   #2
JiAnthony315's Avatar
First Name: Ji
My RZR: 2013 XP 900
Member #36958
View JiAnthony315's Photo Gallery(1)
Re: 2013 Rzr 800 s Throttle sensor
I have been lucky so far and not had any problems yet with mine except one time. I cranked it and a buddy of mine reved it up in neutral and it stayed reved up. I turned off the machine and turned it back on and it was fine.
I agree they need to fix this ASAP..
There is a way to bypass the stupid thing but I dont know how..Maybe someone will chime in and tell us..
2013 XP, Pro Armor Doors and 4pt Harnesses
Racertech dual rate springs, SATV Nerf bars
Polaris lock-n-ride roof & Windshield, Knine Axle Armors
SSV Works overhead 4 speaker System, Blue LED lights
Custom Legue Graphics Kit
JiAnthony315 is offline   Reply With Quote
Old May 15th, 2013, 09:04 AM   #3
mrw8i's Avatar
My RZR: 2013 800S LE
Member #48175
View mrw8i's Photo Gallery(0)
See this thread. Brand New S Won't Run Kind of long read but you'll see how we figured out what we think is going on and proposed different solutions.
mrw8i is offline   Reply With Quote
Old May 15th, 2013, 11:50 AM   #4
Zornff's Avatar
Member #51819
Dealer just called and said its fixed. Guess the sensor was out of alignment. We'll see how long it lasts.
2013 800s blue fire
Old May 15th, 2013, 01:18 PM   #5
King of crash!
Member #787
their is at least 5 threads on this...id read them .... some have had good luck with the adjustment most have needed a new one. also some tricks to get it working... un plug sensor plug back in, tap sensor, hit gas pedal a few times
Old May 15th, 2013, 02:00 PM   #6
Brooklyn's Avatar
My RZR: '13 Rzr 800 S LE Orange/White Madness
Member #55694
View Brooklyn's Photo Gallery(0)
I had this same issue with my '13 800 S. I tried changing the fuel ad spark plugs. No luck. Brought it to the dealer and they changed the throttle sensor. They had a XP with the same issue. So far so good!
Brooklyn is offline   Reply With Quote
Old May 16th, 2013, 01:39 PM   #7
Zornff's Avatar
Member #51819
Just picked it up from the dealer last night. No issues as i loaded on the trailer, and then brought it home. Fired it up this morning to unload it and it did it again. iI have a call into the service department. This is pissing me off now. I guess the bypass is the only thing to do now.
2013 800s blue fire
Old May 1st, 2014, 05:23 PM   #8
Garrett.mitchell68's Avatar
Member #67579
View Garrett.mitchell68's Photo Gallery(0)
I have been told its the throttle sensor going bad. And that my local dealer had some bad ones straight from the factory but they wont fix it for free unless its under warranty. It should be a recall. Mine started about 250 miles in the middle of winter.
Garrett.mitchell68 is offline   Reply With Quote
Old May 1st, 2014, 06:03 PM   #9
RFish's Avatar
Member #56342
View RFish's Photo Gallery(0)
You know this threads a year old eh??? If you need info on it. Read the 600+ replys thread called 'brand new rzr s won't run" to make a bypass for it.
Sent from my iPhone using RZRForums.net mobile app
RFish is offline   Reply With Quote
Old November 14th, 2016, 06:31 AM   #10
Stacy's Avatar
Member #167873
View Stacy's Photo Gallery(0)
Put in the bypass
Just cut off the sensor and solder in the 6.8 K ohm resistor
You may have to do the gas peddle reset procedure because the faulty sensor can screw up the ecu sometimes I've found.
But I did it on the weekend and there has been an instant change
Stacy
Stacy is offline   Reply With Quote
14 rzr 800 s throttle position sensor
2013 800 rzr s tps location
2013 polaris 800s tps for sale
2014 rzr 800 tps sensor specs
bypass tps on rzr
can you bypass the tps sensor on a polaris
map sensor location on rzr800
pilaris rzr 800 throttle problems
rzr 800 pedal position sensor
rzr 800 s throttle problems
rzr 800 throttle position sensor
rzr throttle sensor bypass
rzr tps sensor bypass
what new part number is the rzr 800 s engine throttle pedal
will chevrolet tps work on piokaris rzr 800 s
Throttle Position Sensor. JiAnthony315 General RZR Discussion 0 August 29th, 2012 11:32 AM
Throttle position sensor Teamnipplesdeep Want to Buy 0 May 6th, 2012 10:11 PM
Need Throttle Body Sensor Help!!!!! bizness RZR-S Specific Discussion 3 December 11th, 2010 07:17 AM
Throttle Position Sensor UTVRZRREBEL Engine and Drivetrain 14 June 3rd, 2010 11:30 PM
TPS (Throttle Position Sensor) DesertSportsman Want to Buy 1 October 4th, 2009 09:19 PM
