Dipstick relocation - O ring problems - Polaris RZR Forum - RZR Forums.net
This is a discussion on Dipstick relocation - O ring problems within the RZR-S Specific Discussion forums, part of the General RZR category; Hey guys - I installed a dipstick relocation kit on my '09 RZR-s so I could easily check the oil without having to pull the ...
Old March 23rd, 2013, 09:56 AM   #1
rrose's Avatar
First Name: Ryan
My RZR: '09 RZR-s
Member #6011
View rrose's Photo Gallery(0)
Hey guys - I installed a dipstick relocation kit on my '09 RZR-s so I could easily check the oil without having to pull the seats and harness' out. I'm having a problem all of a sudden. I've broken two dipstick rubber O rings within 100 miles. I don't recall how many miles I had put on it before the first one broke..... But now within a 100 miles it has broken another one. Anyone else have an issue with this?
The only thing that I can think of that I've done differently lately is that I've accidentally fire it up with my exhaust plugs in. But I'm not sure if that would cause the dipstick O ring to rupture or not?!?! Maybe if the crankcase vent was clogged up?
Let me know what you guys think.
2009 RZR-S, Latest Concepts & Designs Custom Cage/Front Bumper, Race Radio, Intercom & 5" Color GPS, Holz/Kroyer Race Motor w/ Crankworks Crank (92hp), Muzzy Dual Exhaust, UMP Intake, DynaTek Coil, HCR Long Travel Kit w/ King Shocks, OMF Beadlocks, Beard Seats, Rigid Industries 30" E-Series & 10" SR-Series LED Light Bars, XP Headlight Conversion, Dakota Digital Dash, FUTV UHMW 1/2" Skid Plate w/ Thunder Hawk Skid Plate Support..... and on and on!
rrose is offline   Reply With Quote
Old March 23rd, 2013, 09:59 AM   #2
darkstar_420's Avatar
My RZR: 2011 Screamin Yellow "S"
Member #29684
View darkstar_420's Photo Gallery(0)
Re: Dipstick relocation - O ring problems
wouldnt hurt to check the vent line
darkstar_420 is offline   Reply With Quote
Old March 23rd, 2013, 12:36 PM   #3
azbill's Avatar
First Name: bill
Member #52364
View azbill's Photo Gallery(0)
Dip stick relocation kit seems like great idea , where did you find it ? and could you show a picture ?
azbill is offline   Reply With Quote
Old March 24th, 2013, 12:08 PM   #4
Desert Rat
scotty1111's Avatar
First Name: Scott
My RZR: 2010 RZR S LE Purple Thunder
Member #14659
View scotty1111's Photo Gallery(0)
I have one and have had no problems at all. Is it the Factory UTV kit?
Dune Shooting is indeed a blood sport, at least in my case!
You can say 'STOP' or 'ALTO' or use any other word you think will work, but I've found that a large bore muzzle pointed at someone's head is pretty much the universal language.
scotty1111 is offline   Reply With Quote
Old March 24th, 2013, 12:21 PM   #5
BarRZR's Avatar
My RZR: 2012 RZR 800-S L/E
Member #32278
Same here.......
Pull the dip-stick, start the engine, and put your finger over the dip-stick hole. You shouldn't feel any pressure or "pulses" at all. If you do, your PCV Valve is stuck. Also, you didn't say if your O-rings were being cut or torn.???
Cheers
Old March 24th, 2013, 01:39 PM   #6
Dmoney's Avatar
Member #42603
View Dmoney's Photo Gallery(0)
My rzr has a lot of "pulse" with the dipstick out. Where is this PCV you speak of?
2011 XP 900, Alba Racing Big Bore built motor with BoonDockers Turbo, HCR Long Travel, TMW race cage, Twisted Stitch suspension seats, Rigid LED lighting, and to many other things to list. Absolutely EPIC!!!!!!
Dmoney is offline   Reply With Quote
Old March 24th, 2013, 02:21 PM   #7
rrose's Avatar
First Name: Ryan
My RZR: '09 RZR-s
Member #6011
Scotty - I appreciate the tip! Ill check that ASAP - if it is pulsing, where is the PCV valve located? What does it do? And how hard is it to replace or repair? Can I do it without taking the bed off?
Old March 24th, 2013, 02:49 PM   #8
BarRZR's Avatar
Member #32278
It's located on top of the valve-cover, and you'll have to remove the bed to get to it and clean it.
Cheers
Old March 24th, 2013, 06:13 PM   #9
Desert Rat
scotty1111's Avatar
First Name: Scott
Member #14659
Yeah it's at the end of the vent tube that melts on the later models.
I'd rather be riding in the desert than using Tapatalk!
Old March 25th, 2013, 06:57 PM   #10
rrose's Avatar
First Name: Ryan
My RZR: '09 RZR-s
Member #6011
Hey BarRZR - so, you'll pull the two small bolts that hold the vent line connection piece to the valve cover - what will I find under there? I keep my rzr in my trailer that's already in the desert - so I'm gearing up to make this repair in the dirt. How will I clean it? I've looked all through the manual/bible, but I can't find any reference to it at all.
I'm hoping I can get it out without pulling my bed - my bed is a son-of-a-gun to remove!
Old March 25th, 2013, 08:32 PM   #11
Member #29684
all i do is unbolt the entire bed, when i had an s bar, except the rear four around the muffler and lift the front end up with tarp straps, gives you enough room to so the small things like that without removing the s bar
Old March 25th, 2013, 09:15 PM   #12
rrose's Avatar
First Name: Ryan
My RZR: '09 RZR-s
Member #6011
Thanks Darkstar - I think I might be able to actually get a little more room to work!
Old April 13th, 2013, 03:16 PM   #13
rrose's Avatar
First Name: Ryan
My RZR: '09 RZR-s
Member #6011
Ok - I've got a little more information now. When you remove the dipstick - it is giving a bunch of pressure coming out the hole - sprays oil out too. I checked the PCV on the valve cover - was working fine and clean - vent line was clear. I hooked a vacuum up to the PCV port, and you could feel the vacuum at the oil dipstick hole - leads me to think no obstruction. The pressure coming out of the PCV was very minimal and kinda timed on/off/on/off - the pressure coming out of the dipstick was very rapid. I'm think its a oil system issue - Possiably a stuck check valve in the oil filter? Any thoughts?
Old April 13th, 2013, 03:54 PM   #14
King of crash!
Member #787
this is normal the rzr 800 has allways sprayed oil out the dipstick this is why it has a lock lever...
Old April 13th, 2013, 04:29 PM   #15
Dmoney's Avatar
Member #42603
My understanding is the high pressure comes from the cylinders moving in unison as opposed to 180* out from each other. Mine has always been that way.
Sent using Tapatalk 2
2013 rzr 800s dipstick leaking
2014 polaris razer dip stick location
2014 rzr oil dip stick relocation
2014 rzr oil dip stick relocation problems
buy oil dip stick relocator kit for 2014 rzr 800s
dipstick location 2014 polaris 800 crew
dirt in dipstick tube on 900 polaris crew
is there a o ring on the dipstick for a 2012 rzr 900 xp
oil dipstick relocation 2014 rzr 900
polaris 800 crew pvc valve
polaris 800 crew.le dipstick leak
ranger crew 800 dipstick how to remove to change o ring
ranger xp900 dip stick fix
what size oring fits polaris dipstick tube
where doies o-ring go on polaris dipstick
Dipstick Relocation temecularanger Engine and Drivetrain 7 February 25th, 2012 10:09 PM
Dipstick Relocation scotty1111 RZR-S Specific Discussion 18 November 4th, 2010 07:46 PM
2011 dipstick relocation tachdriver General RZR Discussion 10 October 28th, 2010 10:25 AM
RZR Dipstick Relocation Kit Factory UTV Factory UTV 16 February 28th, 2010 11:20 PM
Oil dipstick relocation Airborne LT General RZR Discussion 29 January 11th, 2010 06:17 PM
