Polaris RZR Forum - RZR Forums.net (http://www.rzrforums.net/forums.php)
-   RZR-S Specific Discussion (http://www.rzrforums.net/66-rzr-s-specific-discussion/)
-   -   Dipstick relocation - O ring problems (http://www.rzrforums.net/rzr-s-specific-discussion/105165-dipstick-relocation-o-ring-problems.html)
rrose March 23rd, 2013 08:56 AM
Hey guys - I installed a dipstick relocation kit on my '09 RZR-s so I could easily check the oil without having to pull the seats and harness' out. I'm having a problem all of a sudden. I've broken two dipstick rubber O rings within 100 miles. I don't recall how many miles I had put on it before the first one broke..... But now within a 100 miles it has broken another one. Anyone else have an issue with this?
The only thing that I can think of that I've done differently lately is that I've accidentally fire it up with my exhaust plugs in. But I'm not sure if that would cause the dipstick O ring to rupture or not?!?! Maybe if the crankcase vent was clogged up?
Let me know what you guys think.
darkstar_420 March 23rd, 2013 08:59 AM
Re: Dipstick relocation - O ring problems
wouldnt hurt to check the vent line
azbill March 23rd, 2013 11:36 AM
Dip stick relocation kit seems like great idea , where did you find it ? and could you show a picture ?
scotty1111 March 24th, 2013 11:08 AM
I have one and have had no problems at all. Is it the Factory UTV kit?
BarRZR March 24th, 2013 11:21 AM
Same here.......
Pull the dip-stick, start the engine, and put your finger over the dip-stick hole. You shouldn't feel any pressure or "pulses" at all. If you do, your PCV Valve is stuck. Also, you didn't say if your O-rings were being cut or torn.???
Cheers
Dmoney March 24th, 2013 12:39 PM
53 Attachment(s)
My rzr has a lot of "pulse" with the dipstick out. Where is this PCV you speak of?
rrose March 24th, 2013 01:21 PM
Scotty - I appreciate the tip! Ill check that ASAP - if it is pulsing, where is the PCV valve located? What does it do? And how hard is it to replace or repair? Can I do it without taking the bed off?
BarRZR March 24th, 2013 01:49 PM
It's located on top of the valve-cover, and you'll have to remove the bed to get to it and clean it.
Cheers
scotty1111 March 24th, 2013 05:13 PM
Yeah it's at the end of the vent tube that melts on the later models.
I'd rather be riding in the desert than using Tapatalk!
rrose March 25th, 2013 05:57 PM
Hey BarRZR - so, you'll pull the two small bolts that hold the vent line connection piece to the valve cover - what will I find under there? I keep my rzr in my trailer that's already in the desert - so I'm gearing up to make this repair in the dirt. How will I clean it? I've looked all through the manual/bible, but I can't find any reference to it at all.
I'm hoping I can get it out without pulling my bed - my bed is a son-of-a-gun to remove!
darkstar_420 March 25th, 2013 07:32 PM
all i do is unbolt the entire bed, when i had an s bar, except the rear four around the muffler and lift the front end up with tarp straps, gives you enough room to so the small things like that without removing the s bar
rrose March 25th, 2013 08:15 PM
Thanks Darkstar - I think I might be able to actually get a little more room to work!
rrose April 13th, 2013 02:16 PM
Ok - I've got a little more information now. When you remove the dipstick - it is giving a bunch of pressure coming out the hole - sprays oil out too. I checked the PCV on the valve cover - was working fine and clean - vent line was clear. I hooked a vacuum up to the PCV port, and you could feel the vacuum at the oil dipstick hole - leads me to think no obstruction. The pressure coming out of the PCV was very minimal and kinda timed on/off/on/off - the pressure coming out of the dipstick was very rapid. I'm think its a oil system issue - Possiably a stuck check valve in the oil filter? Any thoughts?
johnnycat8 April 13th, 2013 02:54 PM
this is normal the rzr 800 has allways sprayed oil out the dipstick this is why it has a lock lever...
Dmoney April 13th, 2013 03:29 PM
53 Attachment(s)
My understanding is the high pressure comes from the cylinders moving in unison as opposed to 180* out from each other. Mine has always been that way.
Sent using Tapatalk 2
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
