I was out fishing with my lightbar on and my radio playing music with the rzr not running(stupid i know) and the lightbar and radio shut off and won't turn back on. i've let it idle for 10 minutes occasionally revving to try and turn them back on but nothing is working. Help please!
What are they wired to? If they are wired to the Acc. terminal under the hood, check the fuse marked "Term" in the fuse box under the drivers seat.
Need more info.
Yes, as voltage drops, current flow increases; probably enough to blow that fuse if they were wired directly to the ACC terminal. I've also read where excess ACC current draw can arc/damage the off-on-start key switch internally. If they were correctly controlled by relays off the battery with the relay control powered by the ACC terminal then the relays may have been arc'd/burnt internally by excess current as they opened under low voltage, once burnt they won't close properly again. Need to break out a multimeter or test light and see where you don't have voltage.
Related Threads
3.1M posts
141.5K members
Since 2007
