Carrier Bearing Sound??? - Polaris RZR Forum - RZR Forums.net
 16Likes
post #1 of 77 Old May 10th, 2017, 10:26 AM Thread Starter
Hurseyc's Avatar
My RZR: 2015 900 S - Havasu Red
Member #84362
View Hurseyc's Photo Gallery(0)
I have a new and exciting sound I'm hoping you guys can help me diagnose.
In the video the 1st part I'm rolling the RZR by hand and in the 2nd part I've got the rear end jacked up, am laying under it looking at the carrier bearing rotating the rear wheels.
I've isolated the sound to right around the carrier bearing, so that what I think it is, but I've never read about anyone having a sound like this when the CB goes out.
Anyway, please take a listen and let me know what you guys think.
Thanks!
Chris
Hurseyc is offline
post #2 of 77 Old May 10th, 2017, 10:35 AM
TripleTee's Avatar
My RZR: 2016 RZR S EPS Spectra Orange
Member #161569
View TripleTee's Photo Gallery(0)
Mine made a similar sound approx six months ago. I sprayed it with WD-40 and turned the wheel until the sound went away then hit it oil. Been fine since. I pulled the console and looked at it again a few weeks ago and no noise whatsoever. Hopefully it stays that way.
TripleTee is offline
post #3 of 77 Old May 10th, 2017, 10:37 AM Thread Starter
Hurseyc's Avatar
Member #84362
Re: Carrier Bearing Sound???
That's encouraging and that was actually my next question. Basically is it a death sentence for the CB with that noise? Thanks for the info!
We've got a trip to Brimstone coming up in two weeks and the last thing I want to deal with is the CB going out while I'm deep in the mountains.
Hurseyc is offline
post #4 of 77 Old May 10th, 2017, 11:31 AM
Larsonator's Avatar
My RZR: 2015 900S
Member #73551
View Larsonator's Photo Gallery(0)
I was just thinking earlier today I need to inspect mine. I was considering buying a bearing and replacing the driveshaft yoke roll pin with a bolt now, so it would be easier to change out during a weekend trip.
Hurseyc likes this.
Larsonator is online now
post #5 of 77 Old May 10th, 2017, 12:03 PM Thread Starter
Hurseyc's Avatar
Member #84362
Very cool. I didn't know that was an option.
Hurseyc is offline
post #6 of 77 Old May 15th, 2017, 08:30 PM
btrshoes's Avatar
My RZR: 900S
Member #48027
View btrshoes's Photo Gallery(0)
Holy crap, my 900 started making the same exact sound today rolling it in my garage...Now what???? hahaha
btrshoes is online now
post #7 of 77 Old May 16th, 2017, 03:51 AM
tekaitis's Avatar
Member #93874
View tekaitis's Photo Gallery(0)
Mine is in the shop for a replacement for the same thing. But my sound began as a resonance/shimmy between 35-40 mph. I never heard it squeel at low speed but it felt like it was rubbing a bit.
Sent from my MotoG3 using Tapatalk
tekaitis is offline
post #8 of 77 Old May 16th, 2017, 04:30 AM Thread Starter
Hurseyc's Avatar
Member #84362
My extended warranty is covering it. They're replacing the CB and I think also the u-joints. The tech tried to get polaris to cover a whole driveshaft replacement but they wouldn't. I never heard why they wanted the whole driveshaft replaced but that seems overkill to me. I should have it back this week.
Hurseyc is offline
post #9 of 77 Old May 16th, 2017, 09:48 AM
btrshoes's Avatar
My RZR: 900S
Member #48027
Found my sound today, carrier bearing is totally froze up...that noise is the assembly spinning in the rubber!!! 415 miles on my 900 too...damn
post #10 of 77 Old May 16th, 2017, 10:25 AM Thread Starter
Hurseyc's Avatar
Member #84362
I'm glad you found it now rather when it was too late!
Hurseyc is offline
post #11 of 77 Old May 16th, 2017, 10:29 AM
btrshoes's Avatar
My RZR: 900S
Member #48027
Out in 45 minutes thanks to the forum and youtube....dont bother with roll pin in front yoke. Unbolt front dif, pull it toward, I took clutch cover off, pulled rubber housing off while shaft still in buggy, shaft pulls out past the clutch/A arm....
post #12 of 77 Old May 16th, 2017, 10:49 AM
Zonkie's Avatar
Member #188473
View Zonkie's Photo Gallery(0)
2100 miles on mine I'd better check mine out also. Next weeks project as I'm also going back down to Brimstone soon. What a great place to ride and the cabins are awesome.
Zonkie
Zonkie is offline
post #13 of 77 Old May 16th, 2017, 11:13 AM
rush2252's Avatar
First Name: Kolby
My RZR: 2013 Rzr 800
Member #135881
View rush2252's Photo Gallery(0)
I replaced the pin with a bolt in my driveshaft on my 800, glad I wasnt the only one with the crazy idea. Getting that pin out on the trail would be nearly impossible! Luckily I dont have a carrier bearing in my 2 seater, but from what Ive seen they are a pretty cheap design. I would at least toss a replacement in the toolbox if you are worried about it ruining your weekend plans!
rush2252 is offline
post #14 of 77 Old May 16th, 2017, 12:33 PM
UT Trails's Avatar
My RZR: 2016 S 900 EPS
Member #146497
View UT Trails's Photo Gallery(0)
Are these bearings as dry from the factory as the wheel bearings?
Would it be worth the time to try to get grease into them? I see they are fairly expensive. Maybe a small hole through the bearing seal and use a grease injector needle, resealed with silicone seal.
If the SuperATV replacement bearing worked for the 900 S, and they sold replacement bearings by themselves, I would just get one of those.
UT Trails is offline
post #15 of 77 Old May 16th, 2017, 05:06 PM
btrshoes's Avatar
My RZR: 900S
Member #48027
I found out my dealer got Polaris to cover this even though I'm out of warranty. Yeehaw...I am going to try and grease it somehow before I put it in.
Carrier Bearing Dro727RZR RZR S 900 20 March 10th, 2017 02:30 PM
How to replace Carrier Bearing? XP4 1000 Metatrox Engine and Drivetrain 5 February 20th, 2017 05:10 PM
12 XP4 900 Carrier Bearing Install WV23RZR4 RZR XP 4 900 Specific Discussion 3 October 27th, 2016 05:22 PM
We sell Sandcraft Carrier Bearing $240 Free Shipping and 48 RZR Giveaway entries UTV Family Engine and Drivetrain 0 July 14th, 2016 10:00 AM
