Cheapest power steering option. - Polaris RZR Forum - RZR Forums.net
post #1 of 30 Old February 28th, 2017, 05:39 PM Thread Starter
Criv911's Avatar
Member #77923
View Criv911's Photo Gallery(0)
I have used this forum for much valuable information, and thought that it was time to give back. I have a '15 900s white lightening. I would have bought a power steering 900, but money was tight. Well I got the idea to try to install used factory power steering. Guess what, it works. All you need is the power unit (around $200 on eBay) and the upper, and lower steering shafts ( another $50-$75). There are three wires from the diagnostic plug that have to be spliced. ( yello, orange, and blue). They go to the power unit, and the other connector is power, and ground. That's it. Polaris won't sell the patch harness, so I go the connectors, and enough wire to splice from a harness that was bad. So with a little bit of leg work, you can have Factory power steering for less than $300.
Criv911 is offline
post #2 of 30 Old February 28th, 2017, 06:26 PM
Gregg628's Avatar
First Name: Greg
My RZR: 2015 RZR XP1K
Member #39671
View Gregg628's Photo Gallery(11)
Re: Cheapest power steering option.
Nice info, thank you!!
(Did you find everything on ebay from salvaged units?)
Gregg628 is offline
post #3 of 30 Old February 28th, 2017, 06:47 PM
Cajun Jeaux's Avatar
My RZR: 2016 rzr 900 trail
Member #122809
View Cajun Jeaux's Photo Gallery(0)
Very nice. Going to eBay now. May hit you up if I come across an issue.
Btw. Does it matter what model it comes off of ( say an 800)? I have a 16 white lightening trail so I would use the same components as you.
Cajun Jeaux is offline
post #4 of 30 Old February 28th, 2017, 07:19 PM
DogRunner2's Avatar
Member #137545
Nice.
2016 900s
DogRunner2 is online now
post #5 of 30 Old February 28th, 2017, 08:21 PM Thread Starter
Criv911's Avatar
Member #77923
The unit I got has part #2411826 I'm not sure if the other units will work. That seems to be the newer number, but I'm not sure. Just make sure you get the bracket to hold it, and the correct upper, and lower shafts. They are slightly different lengths.
Criv911 is offline
post #6 of 30 Old March 2nd, 2017, 04:08 AM
Beckerj's Avatar
Member #108761
View Beckerj's Photo Gallery(0)
This is awesome. Thank you for sharing. This makes justifying going to power steering so much easier!
Would you mind posting pics of the setup?
Beckerj is offline
post #7 of 30 Old March 2nd, 2017, 07:05 AM Thread Starter
Criv911's Avatar
Member #77923
I'll try to get pics today, but it looks OEM. Because it is! The only part you need to know is the 3 wires from the diagnostic plug are yellow, orange, and green. They will match the three from the salvage plug. You might be able to wire it up without the plug, but the pins a very fine. Besides you would have to hardware it.
Also if anyone is interested I'll have the correct lower shaft available. I bought a few different versions assuming they were the same. I paid $25 plus shipping.
Criv911 is offline
post #8 of 30 Old March 2nd, 2017, 12:35 PM
thippe's Avatar
Member #185177
View thippe's Photo Gallery(0)
sounds great, if i can see a pic of the splicing that would be awesome. Maybe i'll try this instead of SuperATV
thippe is offline
post #9 of 30 Old March 5th, 2017, 08:09 PM
Stone razor's Avatar
First Name: Tarek
My RZR: 2015 900 s
Member #153409
View Stone razor's Photo Gallery(0)
A Toyota Corolla eps unit also works and they are available at your local junkyard 50-75$
Stone razor is offline
post #10 of 30 Old March 5th, 2017, 11:24 PM Thread Starter
Criv911's Avatar
Member #77923
I was looking at that route, but this take zero fabrication. It's much simpler, and is meant for a rzr.
Criv911 is offline
post #11 of 30 Old March 6th, 2017, 03:11 AM
Member #122809
Very interesting. Do you have more info on this or a link to a thread?
post #12 of 30 Old March 6th, 2017, 02:22 PM
Midtennvol's Avatar
Member #175353
View Midtennvol's Photo Gallery(0)
Any more info on this?
Midtennvol is offline
post #13 of 30 Old March 9th, 2017, 04:52 PM
onemooretime's Avatar
My RZR: 900 XP
Member #33122
View onemooretime's Photo Gallery(0)
Nice right up.
Do you know if this will work on a 2012?
RICH
2012 Orange Madness XP900
935 BB W/Alba Stage II W/UMP Intake
Pro Armor Doors, DG Offroad Cage
Twisted Stitch Seats
Riggid Industries 30" Light Bar W/Dual D side lights
Cognito Shocks W/rear dual rate springs
Rugged Radio's 650 intercom/car to car/ Elite-5M GPS
Hiper Tech 14" dual beadlock wheels
onemooretime is offline
post #14 of 30 Old March 9th, 2017, 05:37 PM
First Name: Tarek
My RZR: 2015 900 s
Member #153409
Thanks criv911, I almost bought a corolla eps until I saw this. It would've been cheaper but your right I would've been fabricating. I noticed all of Polaris eps are the same unit. My 2015 900s is already wired for it. Bought the unit with bracket and cover for 199 and the upper and lower shafts for 70. Bolted right up and plugged right in. Awesome. eBay has all the parts. Thats especially not having to fabricate one thing. Thanks again
post #15 of 30 Old March 9th, 2017, 05:41 PM
Midtennvol's Avatar
Member #175353
I haven't hardly seen any of these parts on eBay.
Unhooking the power steering... Fudd RZR S 1000 7 December 5th, 2016 08:58 AM
Power steering issue after light bar install enigma94 Lighting, Stereo and Electrical 6 October 11th, 2016 02:53 PM
rzr 900 steering shaft non power steering mark5193 Polaris RZR Parts For Sale 4 October 10th, 2016 06:20 AM
XP 900 power steering install question Longrange223 RZR XP 900 4 May 12th, 2016 05:09 AM
Power Steering Pop jodus89 RZR XP 1000 0 April 21st, 2016 02:52 AM
