Just Put Bandit Springs On (review) - Polaris RZR Forum - RZR Forums.net
post #1 of 26 Old May 3rd, 2016, 01:47 PM Thread Starter
1371's Avatar
My RZR: 900 S
Member #124497
View 1371's Photo Gallery(0)
Finally went with the bandit springs and so far there a huge difference from stock. I was at 12” front and 10.25” rear. Now I’m 14” front 13” rear. I went with them because they’re less than half the price of competitors and I didn’t want to spend the money on springs with the stock shocks. Eventually Im going with rebuild able ones that are valved for the springs. When one of these wear out or I have the money.
So far I’ve only road behind the house and the ride feels much better. The rear felt a little stiff but I’m sure it’ll smooth out or I can just put the stock main spring back if I feel it necessary. I carry about 330 lbs cab weight and just a 35 qt cooler in the bed plus bumpers. I’m going riding in two weeks so I’ll keep ya’ll posted.
I went with the stock preload of 7.25” in the front and 2.5” in the rear, which is .25” less than stock because the bandit tenders are that much taller. Eventually I’m going to run the rear tender up front and make them dual rate, when I get the time to powder coat them black.
Any question let me know I had a hard time finding good reviews on these, so I plan on posting reviews every few ride and when I change stuff.
1371 is offline
post #2 of 26 Old May 3rd, 2016, 02:57 PM
Mr. & Mrs. PewPewPew
KC Desert's Avatar
First Name: Kat & Chris
My RZR: 2015 GNS 900 Trail EPS
Member #79033
View KC Desert's Photo Gallery(0)
Re: Just Put Bandit Springs On (review)
Thank you for doing this. I look forward to the testing results.
KC Desert is offline
post #3 of 26 Old May 3rd, 2016, 03:36 PM
Rockwerx's Avatar
My RZR: 2015 900S 2016 1000S
Member #85936
View Rockwerx's Photo Gallery(0)
Thank you for your review! I will look forward to more info!
Rockwerx is offline
post #4 of 26 Old May 3rd, 2016, 06:25 PM
Redd900S's Avatar
First Name: Adam
My RZR: 2015 900 S Redd
Member #83856
View Redd900S's Photo Gallery(0)
I ordered the bandit kit as well to get back some ground clearance and hopefully improve ride quality. Should arrive tonight! Im torn on whether to throw the stock rear tenders up front or not...
I'll report back after i take them out as well.
Redd900S is offline
post #5 of 26 Old May 3rd, 2016, 07:46 PM
Kgorman's Avatar
Member #105737
View Kgorman's Photo Gallery(0)
Does anyone know the stock spring rates?
Looks like bandit is:
225lb front
320lb rear with ???lb helper
2016 RZR S 900
BITD #1936 XP1000
Kgorman is offline
post #6 of 26 Old May 3rd, 2016, 08:19 PM
Redd900S's Avatar
First Name: Adam
Member #83856
According the the oem parts finder on rockymountainatv; stock is 140 front, 175 rear tender, and 350 rear main.
I can confirm the bandit springs are printed on the spring as front at 225, rear main 320, and tender ???
Redd900S is offline
post #7 of 26 Old May 4th, 2016, 08:32 AM Thread Starter
1371's Avatar
My RZR: 900 S
Member #124497
I would have went ahead and put them on. I just didn't want two different colors. Ill do it eventually but if you do please let me know how it rides. The front already rides a lot better just with the heavier bandit spring.
1371 is offline
post #8 of 26 Old May 11th, 2016, 04:17 PM Thread Starter
1371's Avatar
My RZR: 900 S
Member #124497
Just A little update on the springs. Ive been riding around the house a few times for about a week and half and the new ride height is about 13.5" up front and 12.25" in the rear (was 14" and 13") which isn't bad I knew they would sag a little. Not going to be able to go ride and really test them out this weekend but will the following. Ill keep y'all posted on how they do.
1371 is offline
post #9 of 26 Old May 12th, 2016, 07:32 PM
Redd900S's Avatar
First Name: Adam
Member #83856
I ended up rattle can powdercoating the stock rear tender and putting it up front. Now, i live in the middle of phoenix, but riding through the neighborhood over the speed humps and parking lot speed bumps, it feels much better than stock. I'm not too concerned with ground clearance, but it is better than before by an inch or so. Cant wait to try it on the trails in a week! So far very happy with the purchase at $350 and quick/free shipping from Bandit. Hope to have a trail review soon
Redd900S is offline
post #10 of 26 Old May 31st, 2016, 06:32 PM Thread Starter
1371's Avatar
My RZR: 900 S
Member #124497
Put quite a few miles on the springs these last two weekends and have to say theres no doubt they're worth it. I don't seem to bottom out anymore as I did over every bump in with the stocks. I haven't put the rear tender up front yet but going to do it soon.
1371 is offline
post #11 of 26 Old June 1st, 2016, 03:29 AM
Larsonator's Avatar
My RZR: 2015 900S
Member #73551
View Larsonator's Photo Gallery(0)
I have a 215 spring on the front from a 900 4 and I put the stock rear 175 tender on top of it before our memorial day trip. It was abysmal. Way too soft. You have to crank a lot of preload into it and it still takes a ton of shock travel for the tender to coil bind. I had to brake hard for every little washout or the shocks would bottom hard. All the preload makes it rebound hard and slam the shock when you're going slow and pop over a rock or something.
farmboy tried it on top of his 175-350 progressive QA1 springs and had similar results.
It's easy enough to try, but I doubt you'll like it unless you just putt putt down trails at 15-20 mph. I'm surprised bandit recommends this.
Larsonator is offline
post #12 of 26 Old June 1st, 2016, 06:09 AM Thread Starter
1371's Avatar
My RZR: 900 S
Member #124497
Good to know
1371 is offline
post #13 of 26 Old June 1st, 2016, 06:49 AM
Rockwerx's Avatar
Member #85936
I have a set of Bandit springs to install when I make time to do it. The rear tender springs on our machine are completely collapsed and the main springs are collapsing also. After reading many posts on this subject I have decided against using the rear tender springs up front. I will be sure to post my review of the new springs.
Rockwerx is offline
post #14 of 26 Old June 1st, 2016, 08:28 AM
jodyfj40's Avatar
First Name: Jody
My RZR: 2015 900s
Member #21879
View jodyfj40's Photo Gallery(0)
Originally Posted by 1371 View Post
Finally went with the bandit springs and so far there a huge difference from stock. I was at 12 front and 10.25 rear. Now Im 14 front 13 rear. I went with them because theyre less than half the price of competitors and I didnt want to spend the money on springs with the stock shocks. Eventually Im going with rebuild able ones that are valved for the springs. When one of these wear out or I have the money.
So far Ive only road behind the house and the ride feels much better. The rear felt a little stiff but Im sure itll smooth out or I can just put the stock main spring back if I feel it necessary. I carry about 330 lbs cab weight and just a 35 qt cooler in the bed plus bumpers. Im going riding in two weeks so Ill keep yall posted.
I went with the stock preload of 7.25 in the front and 2.5 in the rear, which is .25 less than stock because the bandit tenders are that much taller. Eventually Im going to run the rear tender up front and make them dual rate, when I get the time to powder coat them black.
If your still running the stock tires once the springs settle you may want to pull some preload out of the front springs to get the front down closer to 12.50" It will help with the stiffness you felt.
jodyfj40 is online now
post #15 of 26 Old June 1st, 2016, 11:29 AM
atvpro46's Avatar
Member #48411
View atvpro46's Photo Gallery(0)
Our front springs are 225 lb. So a little heavier than the 215 oe Polaris springs. We had good luck with it when we tried it. Plus we used brand new 175 springs. It is possible that used 175 tender springs may be weakened to much for certain guys. In the end result we did like just having the 225 springs on front with no tender as we sell them in our spring kit.
atvpro46 is offline
4 Seater Shock Therapy Springs for sale quadr8cer12 Polaris RZR Parts For Sale 17 April 25th, 2016 10:49 PM
Final Review On Bandit Springs? 1371 RZR S 900 5 April 25th, 2016 01:22 PM
Tired of Sag, put 900-4 springs on 900S zwyken RZR S 900 16 March 5th, 2016 10:38 AM
2014 570 needs springs katoom400 RZR 570 Specific Discussion 8 February 5th, 2016 02:31 PM
Using WER replacement Springs? scnewcomer RZR 800 Specific Discussion 4 January 17th, 2016 01:10 PM
