Budget Spring Kits - Polaris RZR Forum - RZR Forums.net
 13Likes
post #1 of 255 Old March 17th, 2016, 09:44 AM Thread Starter
jon42633's Avatar
Member #105145
View jon42633's Photo Gallery(0)
Budget Spring Kits
Hey guys! Long time reader first post. I have a 2016 900s and I'm experiencing the same as everyone else, the shock spring sag. But my question is are there any other budget options besides the bandit and racertech springs? Both of those seem to be out of stock for the 900s and the shock therapy springs are outside of what I want to spend for springs. Thanks!
jon42633 is offline
post #2 of 255 Old March 17th, 2016, 11:25 AM
SKINUM's Avatar
Member #80463
View SKINUM's Photo Gallery(0)
Re: Budget Spring Kits
Springs for these vehicles are a bit outrageous in my opinion. I purchased from Gforce but they're also $750.
SKINUM is offline
post #3 of 255 Old March 17th, 2016, 11:28 AM
clemson726's Avatar
My RZR: 2010 RZR S
Member #11797
View clemson726's Photo Gallery(0)
2.5" adapters and you can buy any 2.5" spring.
2010 RZR "S" SOLD
2015 RZR 900 S
clemson726 is offline
post #4 of 255 Old March 17th, 2016, 01:06 PM
Banks56's Avatar
First Name: Doug
My RZR: 2015 RZR S 900
Member #75096
View Banks56's Photo Gallery(0)
Where do you get the adapters?
Banks56 is offline
post #5 of 255 Old March 17th, 2016, 02:49 PM
Coon8448's Avatar
Member #83249
View Coon8448's Photo Gallery(0)
Where do you get the adapters and what length and weight works good?
Coon8448 is offline
post #6 of 255 Old March 17th, 2016, 05:31 PM
Hammer82's Avatar
First Name: Jamie
My RZR: 2015 900s black pearl
Member #47081
View Hammer82's Photo Gallery(0)
Schmidty racing 660.00 fully adjustable and in stock. He uses ebach springs which are higher quality
Hammer82 is offline
post #7 of 255 Old March 17th, 2016, 09:52 PM
PolarMud's Avatar
My RZR: 2015 900 S Titanium
Member #8480
View PolarMud's Photo Gallery(0)
these should work
Name:	coil spring adaptors.png
GForce shock revalve w/ Racertech springs
15HP ECU reflash
EPI Clutch Kit
16 XP1K
PolarMud is offline
post #8 of 255 Old March 17th, 2016, 10:03 PM
PolarMud's Avatar
Member #8480
research "tender spring swap" on here and you should find some helpful info on coil spring options. Summit racing has a large selection of Eibach and other springs starting out at around $20 to up to around $60 a spring. If you can find the right adaptors or spacers for the 2.5" springs, you should be able to make yourself a kit for around $350. I seen where one guy took the rear tender spring, moved it to the front shock and had it with a 12" 225lb eibach spring making it a dual rate setup. He was very pleased with it, even though he did not have the shocks revalved. On the back, he had a 10" 275lb spring with what I believe was a 225 to 250lb tender spring. I think he only had around $300 in it.
Some people actually buy the springs from the 4 seat 900 S. This is fine but, like all other factory springs, they will sag.
15HP ECU reflash
EPI Clutch Kit
16 XP1K
PolarMud is offline
post #9 of 255 Old March 24th, 2016, 06:45 PM
fruth04's Avatar
First Name: Travis
Member #74769
View fruth04's Photo Gallery(0)
shock therapy used to offer a stage 3 that used the stock lower springs, which is what I have, I think it was 499 and I am very satisfied with the ride improvements, but apparently you can't get that kit anymore.
15' 900s Titanium
UTVGIANT flat roof, EMP glass windshield w/wiper, custom plexi-glass windshield,
Denali 72" Snow Plow, Viper 4000# winch, 30" light bar, Racer Tech 2" Receiver
Polaris upper doors, Polaris lower door inserts.
fruth04 is offline
post #10 of 255 Old January 28th, 2017, 08:43 AM
btrshoes's Avatar
My RZR: 900S
Member #48027
View btrshoes's Photo Gallery(0)
Im very interested in trying to make my own kit, spring sets are about 80.00 a pair. might be worth the gamble, anyone else try these from Summit???
btrshoes is offline
post #11 of 255 Old January 28th, 2017, 06:46 PM
RZRdavid's Avatar
First Name: David
My RZR: 2016 Blue RZR S 900
Member #161625
Read here, especially what Larsonater said:
http://www.rzrforums.net/rzr-s-900/3...ml#post4173217
RZRdavid is offline
post #12 of 255 Old January 28th, 2017, 08:20 PM
roadiestar's Avatar
First Name: Tom
My RZR: 2017 xp1000 white lightning
Member #2518
View roadiestar's Photo Gallery(0)
roadiestar is offline
post #13 of 255 Old January 28th, 2017, 08:45 PM
ForestRZR's Avatar
Member #146417
View ForestRZR's Photo Gallery(0)
at Summit Racing get the 2.5" QA1 175-350 progressive rate springs for around $110 pr. for the front. Now the rear, theres lots of different affordable options. To keep it cheap, keep the 350lb main spring and replace the tender spring with a Pac Racing 4" long 450lb 2.5" diameter spring. This will give you an initial rate of 197lbs till full coil bind. You want a 4" long spring, so it will go into coil bind to give you a dual rate setup. This is kind of similar to what Racertech kits do. After buying the springs and a few of those Koni 2.5" adaptors, you should be able to do all of this for around $250 to $270. This will be affordable and cost effective. whatever you do, do not buy one of those $100 tender spring swap kits. That is very cheesy and cheap.
ForestRZR is offline
post #14 of 255 Old January 29th, 2017, 03:50 AM
btrshoes's Avatar
My RZR: 900S
Member #48027
Dang that's alot of good info right there!!! So the stock rear main spring is 350# that seems pretty heavy...I had a teryx4 with Bandits Springs and I think it had 320# on the rear....it rode really good.
btrshoes is offline
post #15 of 255 Old January 29th, 2017, 06:24 AM
35Contender's Avatar
Member #168105
View 35Contender's Photo Gallery(0)
Some good info .
35Contender is offline
4 Seater Shock Therapy Springs for sale quadr8cer12 Polaris RZR Parts For Sale 17 April 25th, 2016 10:49 PM
RZR XP 1000 EIBACH PRO UTV spring kits / BANDIT Utv Suspension atvpro46 Suspension 1 March 16th, 2016 10:33 AM
RZR 900 S spring kits in stock FREE SHIPPING atvpro46 RZR S 900 0 January 14th, 2016 04:06 PM
RZR XP 1000 EIBACH PRO UTV spring kits / BANDIT Utv Suspension atvpro46 Suspension 6 January 14th, 2016 11:20 AM
Xp 1000 spring kits on sale / in stock / free shipping atvpro46 RZR XP 1000 2 November 21st, 2015 04:02 PM
