2016 1000 S ECU Recall - Polaris RZR Forum - RZR Forums.net
 2Likes
post #1 of 20 Old March 17th, 2017, 07:26 AM Thread Starter
ateague11's Avatar
Member #89417
View ateague11's Photo Gallery(0)
Anyone else receive a recall notice for the ECU not having a misfire detection calibration? Anyone have the recall work done yet and did it effect performance?
ateague11 is offline
post #2 of 20 Old March 17th, 2017, 07:58 AM
Rockwerx's Avatar
My RZR: 2015 900S 2016 1000S
Member #85936
View Rockwerx's Photo Gallery(0)
Re: 2016 1000 S ECU Recall
I am curious also. Ours runs perfectly IMO. If they detune the engine I am not interested.
Rockwerx is offline
post #3 of 20 Old March 17th, 2017, 08:21 AM Thread Starter
ateague11's Avatar
Member #89417
I am probably going to have mine done this afternoon.. I will report any changes next time I ride
post #4 of 20 Old March 17th, 2017, 05:31 PM
Kodyskruizer2's Avatar
Member #136481
View Kodyskruizer2's Photo Gallery(0)
I had mine done yesterday havent noticed anything yet but havent got to open it up yet either i was told its retuning a couple sensors to help keep it from over fueling but idk
kodyskruizer
Kodyskruizer2 is offline
post #5 of 20 Old March 17th, 2017, 05:59 PM
Dizzledog1's Avatar
First Name: Josh
My RZR: 2016 xp 1000
Member #70121
View Dizzledog1's Photo Gallery(0)
Don't do it!!! Every time the belt slips it will throw a misfire code!! It will ruin your Rzr. My 16xp is in the shop now for the second time with the same problem. My buddies refused the flash and they have no issues what so ever. I repeat do not do it!!
Jerry357 likes this.
Dizzledog1 is online now
post #6 of 20 Old March 17th, 2017, 07:46 PM
Bobonater's Avatar
Member #142849
View Bobonater's Photo Gallery(0)
So belt slip then misfire code. Does that mean you have to take it in everytime to get the code cleared or does the code go away after some driving
Bobonater is offline
post #7 of 20 Old March 17th, 2017, 08:13 PM
Dizzledog1's Avatar
First Name: Josh
Member #70121
Depends. Most of the time it takes a new belt. Dealership said they fixed it. They loaded it on the trailer. I started it on the trailer at my house to unload. Bam same codes. Misfire cylinder 1 misfire cylinder 2. The belt they just put on didn't even have a mile on it. And they said it was belt slip. I call bullsh$&. The flash is junk. My Rzr ran strong before the flash. Now it sucks. Do some research on here and you will see. I was stupid and didn't refuse the flash. Now I have a lawn ornament .
post #8 of 20 Old March 17th, 2017, 10:56 PM
Allrsdup's Avatar
First Name: Joe
My RZR: 2016 S 1000
Member #30349
View Allrsdup's Photo Gallery(0)
the ecu flash just adds a misfire detection to the ecu so it can correct it. if you got a recall as i did its because certain ecu went out without a misfire detection in the stock programming . you will not feel nor does it effect performance.
Allrsdup is offline
post #9 of 20 Old March 18th, 2017, 06:40 AM
Dizzledog1's Avatar
First Name: Josh
Member #70121
You'll see. That's the whole problem. I almost think that Polaris set it up this way so we have to buy more 200$ belts to make up for the last recall. Mines has had 6 belts on it since I bought it. It barely even has 1000 miles on it. My 900xp had one belt in 2700 hundred miles that I owned it.
post #10 of 20 Old March 18th, 2017, 01:57 PM
RZR pirate's Avatar
Member #154593
View RZR pirate's Photo Gallery(0)
I just got my recall. This is a tough call. No problems at all so far but I sure don't want to go up in flames. What are the odds of this?
RZR pirate is offline
post #11 of 20 Old March 18th, 2017, 02:01 PM
Dizzledog1's Avatar
First Name: Josh
Member #70121
Highly unlikely it burst into flames from not getting their reflash
post #12 of 20 Old March 19th, 2017, 05:56 AM
xcntrk's Avatar
Member #86299
View xcntrk's Photo Gallery(0)
I did the ECU reflash recall on my 16' S model. So far no problems, don't notice any difference. I've flogged it pretty good since the reflash too, including deep snow with lots of tire spinning and potential for belt slippage from moisture. So far so good... Only thing left to test is high speed runs.
WoodzRider likes this.
2016 RZR S 1000
xcntrk is offline
post #13 of 20 Old March 19th, 2017, 10:09 AM
WoodzRider's Avatar
My RZR: 2016 S1000
Member #186121
View WoodzRider's Photo Gallery(0)
I got the ecu recall done and I have had NO problems or issues yet. Power seems the same. I have only been able to put 24 miles on since the recall was done. Wisconsin weather isn't cooperating!
WoodzRider is offline
post #14 of 20 Old March 19th, 2017, 11:51 AM
RZR pirate's Avatar
Member #154593
Good to hear the recall isn't causing problems for everybody. Is there anything else that could be causing Drizzledogs problems? He sounds like he really had it with this issue.
post #15 of 20 Old March 19th, 2017, 12:54 PM
Dizzledog1's Avatar
First Name: Josh
Member #70121
I have . Before the flash it ran flawless. Now I almost don't even want it back. Kinda sad. I hope it works out for all of y'all. Maybe they are doing a different flash on the 1000s. Idk. I'm just fed up with it
Official Turbo recall thread UPDATED recall and extended warranty information FJK RZR XP Turbo 780 February 21st, 2017 09:02 AM
2017 Rzr 1000 4 vs 2016 rzr 4 1000 bjdyer24 RZR XP 4 1000 14 December 17th, 2016 05:26 PM
[Rig for Sale] 2016 Polaris Scrambler XP 1000, Black / Lime Squeeze | S3 Power Sports S3-PowerSports S3 Power Sports 0 March 25th, 2016 09:58 AM
