2016 1000S Springs - Page 2 - Polaris RZR Forum - RZR Forums.net
2016 1000S Springs
This is a discussion on 2016 1000S Springs within the RZR S 1000 forums, part of the General RZR category; Fox is not giving these away are they? All I know something needs to be done. What would it accomplish to just replace the tender ...
Go Back   Polaris RZR Forum - RZR Forums.net > General RZR > RZR S 1000
Old January 10th, 2017, 07:25 AM   #16
RZR pirate's Avatar
Member #154593
View RZR pirate's Photo Gallery(0)
Re: 2016 1000S Springs
Fox is not giving these away are they? All I know something needs to be done. What would it accomplish to just replace the tender springs?
RZR pirate is offline   Reply With Quote
Old January 10th, 2017, 07:48 AM   #17
Xc rzr rider's Avatar
Member #174769
View Xc rzr rider's Photo Gallery(0)
That's a great question I might call fox and ask them that. Nothing wrong with lower springs.
Xc rzr rider is offline   Reply With Quote
Old January 10th, 2017, 07:52 AM   #18
Rockwerx's Avatar
My RZR: 2015 900S 2016 1000S
Member #85936
View Rockwerx's Photo Gallery(0)
Replacement of the weak rear tender springs is a patch to the problem. The stock springs will keep collapsing as you tighten them up to keep the stock ride height. This is what happened to our 900S and our 1000S. I installed Bandit springs and they have been great. Got the ride height back and they have not collapsed since setting them up.
Rockwerx is offline   Reply With Quote
Old January 10th, 2017, 08:23 AM   #19
Allrsdup's Avatar
First Name: Joe
My RZR: 2016 S 1000
Member #30349
View Allrsdup's Photo Gallery(0)
Just changing the tender spring is a Band-Aid fix the 2 are meant to match each other top and bottom so you should change them in a pair if you just want to do the rears $250 just for the rears is not bad if money is an issue I think the rears are much worse than the front since they hold most of the weight you could always do the fronts down the road
Allrsdup is offline   Reply With Quote
Old January 10th, 2017, 08:46 AM   #20
dentalpain's Avatar
Member #147945
View dentalpain's Photo Gallery(0)
I installed racer tech dual rates on my 16 1000s...easily the best upgrade ive done....very hard to bottom, improved clearance and softer ride throughout the stroke. I felt I had to do something at 350 miles, my stock tenders were shot.
I read a lot of comments like mine before ordering...they were telling the truth.
dentalpain is offline   Reply With Quote
Old January 10th, 2017, 08:50 AM   #21
cranky1's Avatar
My RZR: 2016 blue fire s1000
Member #110081
View cranky1's Photo Gallery(0)
I just did the schmidty racing med kit on my s1000, so far it's a great upgrade
cranky1 is offline   Reply With Quote
Old January 10th, 2017, 11:48 AM   #22
alpha0815's Avatar
My RZR: S 1000
Member #107138
View alpha0815's Photo Gallery(0)
Quote: Originally Posted by Allrsdup View Post
fox makes spring upgrades. its 250 for rear and 250 for the front. you can just get the rears first. also bandit spring kit for all 4 shocks is like 360.
Link on where to buy? Would like to look at these.
UTV Suspension Upgrades | FOX
scroll down the to s upgrade halfway down page. call them to order.
I think I'm going to contact them to find out, but I was under the impression that Fox only offered these springs for the S 800, last generation.
alpha0815 is offline   Reply With Quote
Old January 10th, 2017, 04:10 PM   #23
Cooper09's Avatar
Member #154761
View Cooper09's Photo Gallery(0)
Hello dentalplan..what spring rate did you go with for the racer tech springs?
Cooper09 is offline   Reply With Quote
Old January 10th, 2017, 08:01 PM   #24
RZRdavid's Avatar
First Name: David
My RZR: 2016 Blue RZR S 900
Member #161625
RZR pirate, I went with Racertech medium's and it is night and day difference. I have never regretted that choice, it is one of the best things you can do to your machine! Well worth the money spent, after the first ride I was very satisfied. There is a reason there are so many vendors providing spring sets for the S models.
From my research at the time, roughly a year ago, there were basically 3 choices I knew of at the time, Racertech(RT), Shock Therapy(ST) and Bandit were just on the scene. The Bandits were not dual rate on all four corners and I couldn't find much info so I removed them from my choice. But since then, many people on here have purchased Bandits and really enjoy them. If the budget is thin, Bandit is the way to go!
My riding style is mainly slow speed trail riding in the Ozarks. Lots of rocky, rough terrain and tight wooded areas. There is the occasional higher speed runs with some playing around. I do some back road runs and catch slight amounts of air on those. For reference, I have left my rear sway bar connected. Some people remove the sway bar, I may try that in the future.
The factory set up had several issues for me. 1. The front springs were way too soft. I had to keep the shocks turned up to 12 clicks or more just to keep it from being scary and unstable. This is why you don't want to just change the rear tender. 2. The rear dual springs had two main issues for me, first the tender spring were of such low quality that they had completely collapsed by 150 miles, secondly the rear main spring was way too stiff. So, the collapse tender caused a loss of about two or three inches and left me riding on an overly harsh main spring, which literally felt like a kidney punch over every little stone. The fronts had sagged some also, which explained all the bottoming out. The machine was still fairly new, so I was able to notice an extreme change from the first couple outings.
I installed the new springs and instantly knew the ride height was restored and maybe a little more. I had 14 inches in front and 13.5 inches inches in the rear with a 1/4 inch preload. The new ride is so much better than the original equipment it's really not a comparison. At low speeds, <15mph, it is so much smoother. No more kidney punches. It is not plush or squishy by any means, its firm but compliant. The ride at higher speeds, >30mph, is almost like a hover craft even over very rough terrain, remarkable. I can fly down open trails and even catch some air, which was almost impossible with the factory set up because the back end would kick up so bad, resulting in terrible nose dives off everything. All that is resolved. Also, I run about 2 clicks in the rear and 5 clicks in the front shocks, I like it soft. I do have to adjust it up some clicks if I am doing >30mph regularly. Also, there was another benefit that is hard to explain, the springs simply react better to the terrain and situations. I would suspect some serious testing went into the spring choices by RT.
There are many good choices out there, do a little research and I think you will find something that fits the bill. My thought at the time was, if I was already going to spend hundreds of dollars on new springs, I felt it worth spending a little more and getting dual springs all the way around. From what I have read on here, you would get very similar results from the Bandits, if budget dictates lower cost, then get a set of Bandits. You will be glad you did.
Hope this helps.
RZRdavid is offline   Reply With Quote
Old January 11th, 2017, 08:41 AM   #25
Westcove's Avatar
Member #123217
View Westcove's Photo Gallery(0)
Schmidty racing dual rate springs, they use quality eibach springs in their kit.
I highly recommend getting the race set up, which includes new preload collars and new spring retainers. Definitely worth a look.
Westcove is offline   Reply With Quote
Old January 11th, 2017, 02:36 PM   #26
roushf150's Avatar
Member #109457
View roushf150's Photo Gallery(0)
I used bandit springs and am happy with them.
roushf150 is offline   Reply With Quote
Old January 11th, 2017, 09:45 PM   #27
RZR pirate's Avatar
Member #154593
Thanks RZRdavid, I do 90 percent trail riding and don't do a lot of high speed whoops atc. Don't want to throw good money after bad. The Bandits seem to be pleasing everyone and are a little lower cost. I will decide real soon though as we start doing a lot of our riding soon.
Old January 11th, 2017, 11:38 PM   #28
UberDuper's Avatar
My RZR: s1000
Member #149842
View UberDuper's Photo Gallery(0)
Wouldn't hurt to call one of the vendors here and get their recommendation based on budget, terrain, gear, etc.
UberDuper is offline   Reply With Quote
Old January 12th, 2017, 07:11 AM   #29
RZRdavid's Avatar
First Name: David
Member #161625
If you buy Bandits....you'll ask yourself...why didn't I do this sooner...LOL.
You will love the change. Do a review after the install.
Old January 12th, 2017, 10:41 AM   #30
alpha0815's Avatar
My RZR: S 1000
Member #107138
I'm sure Bandits (Eibach) are good. I'm sure Schmidty (Eibach) are good...same springs probably.
RacerTech is probably Eibach too. And they come with the complete hardware kits. RacerTech seems to have done much more extensive testing and R&D then the others, specific to our model. That is what made my mind up.
Just released new Utah ATV Trails 2016 map BobT GPS 8 October 15th, 2016 07:33 PM
2016 XP4 Turbo Tender springs Scott M Polaris RZR Parts For Sale 6 July 31st, 2016 10:35 PM
4 Seater Shock Therapy Springs for sale quadr8cer12 Polaris RZR Parts For Sale 17 April 25th, 2016 11:49 PM
Best upgrade shock Springs for 1000s bPrice51 RZR S 1000 12 April 20th, 2016 07:22 PM
Price/rebates on 2016 1000s travisH3 RZR S 1000 11 December 29th, 2015 05:37 PM
