RZR Motor Mount Brace
This is a discussion on RZR Motor Mount Brace within the RZR Headquarters forums, part of the Supporting Vendors category; RZR Tech found out the hard way that the factory engine mounting system is completely insufficient. In a hard roll over it is highly likely ...
Go Back   Polaris RZR Forum - RZR Forums.net > Supporting Vendors > RZR Headquarters
RZR Headquarters RZR Headquarters - Toll Free 877-581-0041
Old January 8th, 2009, 07:14 PM
RZR Headquarters's Avatar
Member #350
View RZR Headquarters's Photo Gallery(0)
RZR Tech found out the hard way that the factory engine mounting system is completely insufficient. In a hard roll over it is highly likely a piece of the engine casing will rip right out of the block. Once this happens the engine needs to be completely disassembled down to the bare cases. Then the casting must be thoroughly cleaned and prepped before it must be professionally welded back together. We recommend this motor mount brace to anyone as cheap insurance protection so this doesn't happen to you. This brace acts as a third mount off of the cylinder head. It adds support from a direction the OEM’s never thought to include. This third mount does very little to support the engine while the machine is in the upright position, which allows the original setup to work as designed, but in the event of a roll over this tie rod style design helps stabilize the motor from flexing too far in its original rubber mounts which in-turn causes the casing to break off. This kit requires two holes to be drilled through one of the box support tubes. Kit comes complete with Red powder coat, all necessary hardware and instructions.
Polaris RZR Engine Brace $75
Old January 8th, 2009, 07:26 PM
Crispy01's Avatar
First Name: chris
My RZR: 2008
Member #3092
View Crispy01's Photo Gallery(5) Send a message via MSN to Crispy01
Re: RZR Motor Mount Brace
i've been looking at that one...you guys ship to canada?
Old January 8th, 2009, 08:36 PM
Member #350
yes sure do
Old January 8th, 2009, 08:40 PM
Crispy01's Avatar
First Name: chris
My RZR: 2008
Member #3092
sweet i'll get in touch with you guys in a little while
Old January 11th, 2009, 12:36 AM
Member #350
Old January 11th, 2009, 11:32 AM
txwpd103's Avatar
First Name: Ryan
My RZR: Green - 2nd Gen.
Member #2463
View txwpd103's Photo Gallery(23)
Do I have to remove the bed to install?
Sleep safe in your beds knowing rough men stand ready in the night to visit violence on those who would do you harm.
__________________________________________________ __
UMP airfilter, Custom Cage, Custom Rear Rack, Custom Doors, Rear Chassis Brace, ProComp Gauges, Rugged Intercom, 2" Rubberdown Lift, Comm Radio, Custom Soft Top, 4000lb Winch, Half windshield, DunerTunes amp/speaker pods, Odyssee PCL925, Holz Grill, 4pt. Harnesses, Rear wheel spacers, pnp HIDS, 4x VisionX Solstice, Parking Brake, RacerTech Dual Rate Springs.
Old January 11th, 2009, 12:28 PM
quadnkev's Avatar
Feedback Score: 5 reviews
First Name: Kev
My RZR: Red
Member #610
To drill the holes it looks like it.
Removing the bed should be one of those things a RZR owner
has to know how to do like pooping and peeing.
  #8
Old January 11th, 2009, 12:39 PM
txwpd103's Avatar
First Name: Ryan
Member #2463
The bed is about 3 minutes, it's all the stuff above it on mine that is a PIA.
  #9
Old January 16th, 2009, 07:58 PM
Member #350
more in stock
  #10
Old January 25th, 2009, 08:47 PM
Member #350
  #11
Old January 25th, 2009, 09:05 PM
GIFF-TURBO RZR's Avatar
First Name: Gary
My RZR: 09 Standard and "S"
Member #3946
View GIFF-TURBO RZR's Photo Gallery(109)
Hmmm....Looks good, but it wont work in my case with the MCX turbo set up
got boost?
MCX-USA Turbo http://www.mcx-usa.com/
Dirty Dawg PerformanceDirty Dawg Performance 763-228-4345 or email mrgofast77@yahoo.com
Welcome to The RZR Forum's "Tour for a Cure" Fundraising Page http://www.fightblindness.org/site/T...20&pg=personal
  #12
Old January 26th, 2009, 02:12 PM
Rzr in NH's Avatar
addicted
First Name: Mike #4
My RZR: 09 red rzr
Member #4434
View Rzr in NH's Photo Gallery(0)
might mount motor better but i bet those 2 holes do a bit on weakening the frame?
  #13
Old February 9th, 2009, 07:07 PM
Garrett's Avatar
First Name: Garrett
My RZR: RZR S
Member #4513
View Garrett's Photo Gallery(0)
Does this mount clear all exhaust systems?
09' RZR S = Money pit. Gotta pay to play
Build it right the first time or don't bother wasting time.
  #14
Old February 12th, 2009, 10:47 PM
Member #350
We haven't run into any issues yet. Should it not clear with your setup we have no problems accepting a return.
Jeremy
  #15
Old February 13th, 2009, 09:54 AM
Garrett's Avatar
First Name: Garrett
My RZR: RZR S
Member #4513
Jeremy
Jeremy,
I will get my exhaust first and then order this along with some other stuff.
Bookmarks
Tags
polaris rzr, polaris rzr s, rzr chassis, rzr motor brace, rzr motor mount
Engine Brace RZRider General RZR Discussion 8 December 27th, 2008 05:40 AM
front bumper brace super s puppy General RZR Discussion 2 December 25th, 2008 10:24 PM
Rear brace RGERBER General RZR Discussion 8 September 8th, 2008 07:54 PM
Rzr 800 Rear Brace - $59.95 UTV CRAP UTV Crap 0 September 5th, 2008 10:41 AM
weak motor mount megadesertdiesel Engine and Drivetrain 1 May 27th, 2008 09:25 PM
