This is a discussion on RZR Derlin A-Arm Bushing Kit within the RZR Headquarters forums, part of the Supporting Vendors category; Quote: Originally Posted by RZR Headquarters Sorry guys i was mistaken about it including the spindle side bushings. Milos im sure it may be a ...
| RZR Headquarters |
#31
Re: RZR Derlin A-Arm Bushing Kit
Sorry guys i was mistaken about it including the spindle side bushings. Milos im sure it may be a hassle now that you have the kit installed, but i can give you a full refund and cover shipping if you would like to return them. I will look at getting spindle side bushings made.
Also, for guys having problems with factory worn bushings on the spindle side, is your rear camber where the top of the tires are pointed inward also? Jeremy milos ,
2008 Attitude TH 06 raptor 734 09 Raptor 700 08 RZR 860 MCX Turbo |
| Sponsored Links | ||
#32
milos
#33
milos
_______________________________ Romeo, MI |
#34
Me too.
The kit should be changed to include them.
______________________________________ My Links: Polaris Parts Microfiche , FREE DOWNLOADS , How to change a RZR clutch belt VIDEO |
#35
Also, for guys having problems with factory worn bushings on the spindle side, is your rear camber where the top of the tires are pointed inward also? Jeremy |
#36
![]() milos Sorry guys i was mistaken about it including the spindle side bushings. Milos im sure it may be a hassle now that you have the kit installed, but i can give you a full refund and cover shipping if you would like to return them. I will look at getting spindle side bushings made.
#37
Count me in, I received and installed my kit yesterday. The old bushing did need to be replaced but the squeak was till there from the spindle side.
Pete |
#38
Guys yesterday I received the bushing kit, but I don;t get bushings for the outer spindles, main reason I want this kit. They are ones which squeak badly because no grease fittings. Plus friction tube are so tight in it, bushing turns in arms not on tubes plus collar on bushings are thicker then original, when you tight the bolts you actually stop bushings by squeezing them. Not sure, if this should be like that.
#39
wont be too expensive i believe. All depends on how fast it can be turned down. Should be a lot easier than steel so im not too worried. Ill try to have an answer for you guys tomorrow afternoon.
+10 long travel ![]() utv crap hubs factory utv skid plate side by side sports lights and wheels and some other stuff |
#40
Yes, please let us know! I hate that loud squeaking!!! I would love to get this fixed!!
Merle 09 RZR "S" W/ TMW Off Roads Cage and Custom Door Panels and Paint 08 F-150 Crew Cab W/ 22"s Soon to have a 3inch drop 01 Banshee W/ Shaved head, Timing, lighted fly-well, +10 swing arm, running 9 paddles, running Nitro! Sold!!
#42
Should be no problem to add spindle bushings to the kit. On upper side spindle use same bushings as lower A arm on inside, just add 4 pc of short ones to the kit. Just 4 pc of lower spindle bushing need to be done . IMHO
milos
#43
He didnt have the exact right drill bit for the center hole and in the interest of saving time, and money, he didnt want to drill it and then turn it down. So tomorrow morning we should have the new bit. If i could run the lathe i would have had them done but i cant so i have to wait for him to make them. I am only having him make the bushings for the spindle. RZRHQ has all the rest of the bushing you need. Im not a vendor and dont want to step on any ones toes.
#44
got it all set up and i can get a set together and shipped for $50.
#45
Mark how many bushings would that be for?
| Tags |
| rzr accessories, rzr headquarters, rzr suspension, rzrhq.com |
| Visitors found this page by searching for these keywords: |
rzr worn spindle bushings |
| Thread Tools | |
| Display Modes | |
| DIY Steering shaft bushing | dh13 | Projects and How-To | 3 | February 10th, 2009 07:35 AM |
| Does anyone sell aftermarket rear pivot bushing kits? | str8rzr | Suspension | 20 | January 7th, 2009 11:16 AM |
| sway bar bushing | reds65ss | Suspension | 9 | June 8th, 2008 05:18 PM |
| HPD steering bushing kit | RGERBER | Engine and Drivetrain | 7 | December 15th, 2007 07:22 PM |
