RZR Derlin A-Arm Bushing Kit
This is a discussion on RZR Derlin A-Arm Bushing Kit within the RZR Headquarters forums, part of the Supporting Vendors category; Quote: Originally Posted by milosusa Just one more Q. I go to your website to order them and on the check out you stated weight ...
Go Back   Polaris RZR Forum - RZR Forums.net > Supporting Vendors > RZR Headquarters
RZR Headquarters RZR Headquarters - Toll Free 877-581-0041
  #16
Old June 9th, 2009, 10:03 AM
RZR Headquarters's Avatar
Member #350
View RZR Headquarters's Photo Gallery(0)
Re: RZR Derlin A-Arm Bushing Kit
Quote: Originally Posted by milosusa View Post
Just one more Q. I go to your website to order them and on the check out you stated weight for shipping 17 # . They are so heavy or is mistake ?
milos
mistake, i got it corrected. Thanks for the heads up.
  #17
Old June 9th, 2009, 11:38 AM
milosusa's Avatar
Feedback Score: 6 reviews
My RZR: 2008 Red
Member #1361
View milosusa's Photo Gallery(27)
milos
Ok, my order go thru. Thanks for correcting weight so fast.
milos
2008 Attitude TH
06 raptor 734
09 Raptor 700
08 RZR 860 MCX Turbo
  #18
Old June 9th, 2009, 02:25 PM
cheek's Avatar
S.O.B son of boss
First Name: Josh
My RZR: Busa RZR
Member #1165
View cheek's Photo Gallery(0)
the bushings dont require grease cause Delrin has natural lubricity properties.
  #19
Old June 9th, 2009, 09:10 PM
jsawyer's Avatar
Uh Oh
Member #6096
View jsawyer's Photo Gallery(0)
subscribing. I want to know if these work
2009 RZR-S
White Knuckle Big Bore coming soon...
http://www.modernmustangmuscle.com/t...mustanggt.html
  #20
Old June 10th, 2009, 05:50 AM
BeachHead's Avatar
Member #5518
View BeachHead's Photo Gallery(0)
Had a hot rod with delrin bushings...no squeeks, so I'd assume they'll work as well in this application. Definitely on my "list", just have to save up some $'s.
  #21
Old June 10th, 2009, 07:13 AM
swingarm1's Avatar
Banned
Feedback Score: 41 reviews
First Name: Iron Man
My RZR: Mine
Member #7690
View swingarm1's Photo Gallery(4)
I start to be tired of squeaking and putting grease on OEM ones all the time. Hopefully they will help, any discount for RZR forum members ?
milos
If there is I'm due a refund... I bought these about a month ago and it was $180.00 plus shipping...
How do you like them ? Did they take care of squeaking ? You run them dry ?
milos
Easy to install, no squeaks and yes I run them dry... Well worth the money as far as I'm concerned...
  #22
Old June 10th, 2009, 07:14 AM
swingarm1's Avatar
Banned
My RZR: Mine
Member #7690
Yes they do like a hot knife in butter...
  #23
Old June 10th, 2009, 10:37 AM
av8ing's Avatar
First Name: Kevin
My RZR: 2009 RZR S
Member #8187
View av8ing's Photo Gallery(4)
Any special tools, or tips/tricks to install them? or is it just unbolt, slide them in, and torque them in.
  #24
Old June 10th, 2009, 11:42 AM
milosusa's Avatar
My RZR: 2008 Red
Member #1361
They are easy to change, only special tools I can think off will be a torque wrench, if you want to tight A arms bolts to manufacture specifications . But you can go just by common sense, because pivot tube don't let you squeeze the bushings anyway.
milos
2008 Attitude TH
06 raptor 734
09 Raptor 700
  #25
Old June 26th, 2009, 09:55 PM
milosusa's Avatar
My RZR: 2008 Red
Member #1361
Quote: Originally Posted by big guy View Post
does this kit also include the bushings that go in the rear outer spindles do you have to buy the whole kit or can you just get the parts you need?
yes, and it is only sold as a complete kit.
Guys yesterday I received the bushing kit, but I don;t get bushings for the outer spindles, main reason I want this kit. They are ones which squeak badly because no grease fittings. Plus friction tube are so tight in it, bushing turns in arms not on tubes plus collar on bushings are thicker then original, when you tight the bolts you actually stop bushings by squeezing them. Not sure, if this should be like that.
milos
2008 Attitude TH
06 raptor 734
09 Raptor 700
  #26
Old June 27th, 2009, 08:36 AM
crazywatson's Avatar
Just kidding!
First Name: steve
My RZR: red
Member #3534
What no bushings for the spindle side???????????I was getting ready to order them and that was one of the reasons why.Taking the suspention apart to lube the bushings is retarded.Poo short changed us on the grease fittings on these bushings.
  #27
Old June 27th, 2009, 01:19 PM
gone!!!!!!!
Member #787
did they miss it or just not included????
we need to know
lots of toy's
  #28
Old June 27th, 2009, 02:51 PM
Member #350
Sorry guys i was mistaken about it including the spindle side bushings. Milos im sure it may be a hassle now that you have the kit installed, but i can give you a full refund and cover shipping if you would like to return them. I will look at getting spindle side bushings made.
Also, for guys having problems with factory worn bushings on the spindle side, is your rear camber where the top of the tires are pointed inward also?
Jeremy
  #29
Old June 27th, 2009, 07:59 PM
Delinquent RZR's Avatar
Bent Motorsports
My RZR: 09
Member #6540
View Delinquent RZR's Photo Gallery(28)
I have some delrin at work i bought to do all my bushings. I will find out how long it takes to make them and i will try to whip out some extra ones for you guys if ya want. Ill look into it on monday so let me know if your interested.
+10 long travel
utv crap hubs
factory utv skid plate
side by side sports lights and wheels
and some other stuff
  #30
Old June 27th, 2009, 08:01 PM
Bent Motorsports
My RZR: 09
Member #6540
fyi that is the spindle ones im talking about
+10 long travel
utv crap hubs
Tags
rzr accessories, rzr headquarters, rzr suspension, rzrhq.com
rzr worn spindle bushings
DIY Steering shaft bushing dh13 Projects and How-To 3 February 10th, 2009 07:35 AM
Does anyone sell aftermarket rear pivot bushing kits? str8rzr Suspension 20 January 7th, 2009 11:16 AM
sway bar bushing reds65ss Suspension 9 June 8th, 2008 05:18 PM
HPD steering bushing kit RGERBER Engine and Drivetrain 7 December 15th, 2007 07:22 PM
