stock xp cam and timing specs - Polaris RZR Forum - RZR Forums.net
This is a discussion on stock xp cam and timing specs within the RZR 900 Engine forums, part of the Technical category; Anyone out there have specs on the stock xp cams? I would like to know intake and exhaust open and close degrees @.050. Also really ...
Go Back   Polaris RZR Forum - RZR Forums.net > Technical > RZR 900 Engine
Old December 10th, 2012, 05:55 PM   #1
HoleShot's Avatar
Member #34309
View HoleShot's Photo Gallery(3)
Also really like to know stock ignition timing at WOT from 4000 to 9000 rpm.
Thanks-
Nate @ team alba
Eric @ Empire Industries
HoleShot is offline   Reply With Quote
Old December 10th, 2012, 06:56 PM   #2
Feedback Score: 6 reviews
rappy60guy's Avatar
First Name: Kc
Member #19623
View rappy60guy's Photo Gallery(3)
Re: stock xp cam and timing specs
look for a guy poflo ...hey will know
rappy60guy is offline   Reply With Quote
Old December 10th, 2012, 07:34 PM   #3
HoleShot's Avatar
Member #34309
Hey thanks ill go find him.
Sent from my PC36100 using Tapatalk 2
Thanks-
Nate @ team alba
Old December 12th, 2012, 02:25 PM   #4
poflo's Avatar
First Name: Don
My RZR: xp 900
Member #11987
View poflo's Photo Gallery(0)
SENT PM
poflo is offline   Reply With Quote
Old December 12th, 2012, 02:49 PM   #5
Banned
itsruf's Avatar
First Name: Mark -
Member #16159
why not talk about it on here?
already know how to take stickers off and choose a trailer.
itsruf is offline   Reply With Quote
Old December 12th, 2012, 03:18 PM   #6
HoleShot's Avatar
Member #34309
I pulled some specs from crowers website.
Stock intake lift .360"
Stock intake duration 217
Stock exh lift .334"
Stock exh duration 226
Poflo also sent some numbers which i havent taken time to work with and ill let him post them since its his info if he wants.
Im looking for valve open and close numbers and overlap without degreeing the motor myself. This will help me decide if i want to run stock cams or not with the turbo. Yes i know they will run thats not the question.
Thanks-
Nate @ team alba
Old December 12th, 2012, 03:35 PM   #7
poflo's Avatar
First Name: Don
My RZR: xp 900
Member #11987
See,thats different specs than what I sent you.....I would go with their specs...different than what I measured.... same lifts,but diff exh duration...I only saw 214....I didn't even know Crower did cams for xp
Old December 14th, 2012, 01:09 PM   #8
Benchmark Performance
s2k1's Avatar
My RZR: 2011 XP900
Member #1458
View s2k1's Photo Gallery(0)
I had Dannyis Crower do a set for me right when the XP came out.
Chris@BenchmarkPerformance.us
760-484-0986
Engine Specialists, Side x Side Parts & Accessories, Discount OEM Parts
s2k1 is offline   Reply With Quote
Old December 14th, 2012, 02:13 PM   #9
poflo's Avatar
First Name: Don
My RZR: xp 900
Member #11987
I had Dannyis Crower do a set for me right when the XP came out.[/quote]
Chris,what do you have as stock specs.....I found another spec on another forum
Old December 29th, 2012, 01:28 PM   #10
Damage's Avatar
First Name: D
My RZR: Turbo RZR & Turbo XP900
Member #7012
View Damage's Photo Gallery(0)
Any info on the stock ignition timing
Damage is offline   Reply With Quote
Old December 29th, 2012, 01:56 PM   #11
HoleShot's Avatar
Member #34309
Yeah it would be real nice to know actual peak timing at 7000 to 8500 rpm
Thanks-
Nate @ team alba
2011 rzr 900 timing help
2012 polaris rzr 900 cam timing
2012 polaris rzr 900 timming specs
cam timing rzr900 xp
how 2 put a polaris rzr 1000 on timing#gsc.tab
how to set cam timing on polaris razor 900 xp
how to set timing on 900 xp
how to set timing on a polaris rzr 900
polaris rzr 2014 timing specs
retiming polarus rzr motor
rzr 900 timing marks
rzr900 cam timing
specs stock rzr xp camshaft
xpcams.com
Rzr Timing Steven_ikari Engine and Drivetrain 7 November 30th, 2016 06:33 PM
Stock 2012 xp cam specs? KingR RZR 900 Engine 10 June 21st, 2016 09:13 PM
PM's timing out RMR Man Member Introductions 5 August 21st, 2012 09:18 PM
Timing and Boost WFC Forced Induction 76 April 28th, 2012 07:50 PM
Ignition Timing martymoe Engine and Drivetrain 19 February 17th, 2009 07:23 PM
