Engine oil question - Polaris RZR Forum - RZR Forums.net
Engine oil question
This is a discussion on Engine oil question within the RZR 900 Engine forums, part of the Technical category; Polaris specs out their PS-4 Plus synthetic oil for the engine. Does anyone know what the weight is? Also, what are most using in the ...
Go Back   Polaris RZR Forum - RZR Forums.net > Technical > RZR 900 Engine
Old October 27th, 2012, 10:14 PM   #1
MULESKINNER's Avatar
Member #46212
View MULESKINNER's Photo Gallery(0)
Engine oil question
Polaris specs out their PS-4 Plus synthetic oil for the engine. Does anyone know what the weight is? Also, what are most using in the engine?
Also, why is the front axle gear oil different from the rear. Does the front axle have clutch plates? What is the stuff Polaris specs for the front axle. I normally use M1 synthetic gear oil.
Ineptocracy - A system of government where the least capable to lead are elected by the least capable of producing, and where the members of society least likely to sustain themselves and succeed are rewarded with goods and services that are paid for with the confiscated wealth of a diminishing number of producers.
MULESKINNER is offline   Reply With Quote
Old October 29th, 2012, 10:42 AM   #2
UTVRZRREBEL's Avatar
First Name: Anthony
My RZR: 2009 RZR LE Sunset Red
Member #9641
View UTVRZRREBEL's Photo Gallery(0)
Re: Engine oil question
I use Ams-Oil 0-40 weight is which the same weight that is recommended by Polaris. Also use a Wix Oil Filter. I still use all of the Polaris Fluids for the Frt. Diff, Rear Diff, and the Trans. and Trans. Case. The Frt. Diff especially because of the Hillard Clutches because its controlled Electrically and the Polaris Fluid works Great. I change the Frt. and Rear Diff after every ride. Because of where we ride at there is a great chance of getting in Water in the Diffs. to me that is Cheap Insurance to keep everything working good, and its not that expensive to do. So maybe this helps.
UTVRZRREBEL is offline   Reply With Quote
Old October 29th, 2012, 02:01 PM   #3
Member #46212
I have been in touch with Hillard today. I have left a message with "Matt Cowen" the Polaris front axle unit design facility manager. I will post back what he states about approved fluids for the front axle, other than Polaris. I'm not going to be held ransom by the Polaris dealer and made to purchase their over priced lubricating products. Besides, I'm an hours drive from my dealer.
Thank you for your reply though, as you have answered my first question regarding the engine oil. As the engine is a separate crank case and does not hold wet clutches and transmission gears, I will most likely go with some type of a M1 automotive synthetic product. M1 M4 is for M/C wet clutch applications and M1 V-Twin is designed for Harley engines and is too heavy for the Razor. So I'm thinking a 0-40 automotive M1 product.
Old October 29th, 2012, 02:48 PM   #4
Timmi's Avatar
Member #42712
View Timmi's Photo Gallery(0)
All the people I know who have rzr's use multi vis synthetic oil jaso ma approved . Most use auto trans fluid in the front diff
Timmi is offline   Reply With Quote
Old October 29th, 2012, 06:00 PM   #5
Member #46212
Exclamation Re: Engine oil question
Please look at my new post regarding info from Hilliard today.
Old April 24th, 2013, 08:07 PM   #6
dproc870's Avatar
First Name: david
My RZR: 2010 800 ranger rzr 50"
Member #36176
View dproc870's Photo Gallery(0)
alba racing recomended maxima racing oil
they said polaris oil was junk i belive it too i was all about using oem oil
untill i had to have a new bottom end put in
then after that i still used it for about 10 hours and then switched to maxima extra 15w50
the oem oil ex. i rode 40 miles and had to add 6 oz of oil
then the next day i rode the same amount and again had to add 6 oz
sense the switch to maxima no more adding oil everyday stays full every day no matter
how far you ride
i know all this talk about oils is so confusing and i know polaris requires 0w-40 but
if you live in a warmer climate there is no sense in having oil that thin
you cant go wrong with maxima ....
dproc870 is offline   Reply With Quote
Old April 24th, 2013, 08:18 PM   #7
sandblster's Avatar
Member #46247
Check this thread:http://www.rzrforums.net/rzr-xp-900/...what-oils.html
sandblster is offline   Reply With Quote
Old April 24th, 2013, 08:21 PM   #8
Addicted
Feedback Score: 12 reviews
CFDWheeler's Avatar
First Name: Steve
My RZR: 12' Voodoo Blue XP
Member #6186
View CFDWheeler's Photo Gallery(0)
Kinda old thread, but this should help...
2012 Voodoo Blue 900XP :rzrs:
Factory UTV UHMW skids & A-arm guards, UTV Inc TA guards, SATV radius rods, CROW 4pts
Viper Elite 4K on EMP front bumper, Pro Armor rear bumper, TFBB Doors, SSV Works Stereo; EMP Hard Top
30" Roctanes on STI HD5's w/ fender mod; RacerTech Heavy Springs, 30" front and 6'' rear LED lights
IAFF LOCAL 38 Covington KY
CFDWheeler is offline   Reply With Quote
Old April 24th, 2013, 10:48 PM   #9
GrMeyer's Avatar
First Name: Greg
My RZR: 900 Xp
Member #15161
View GrMeyer's Photo Gallery(0)
I know when I had my 800 I would lose oil using the Polaris oil. I then switched to Rotella T6 5w-40 full synthetic and it has a ZDDP content of 1200ppm. Stopped burning oil. I have now kept using that in my 900 for 2 years know with some hard driven miles in the dunes. Changed oil after every 3 trips.
GrMeyer is offline   Reply With Quote
Old May 7th, 2013, 12:16 AM   #10
BCRacing24's Avatar
First Name: Brian
My RZR: 2016 XPT-4
Member #20030
View BCRacing24's Photo Gallery(0)
Usa Re: Engine oil question
Polaris specs out their PS-4 Plus synthetic oil for the engine. Does anyone know what the weight is?.....5w-50
Also, what are most using in the engine?..... Mobil 1 15-50 Synthetic
15W-50 Synthetic Oil | Mobil 1 15W-50
Front diff uses a electromagnetic locker by Hilliard. Supposably the locker will not engage\disengage correctly if 80\90 style fluid is used. Hilliard recommends Mobil 424 or LT (Light Transmission fluid) I use Mobil 1 Synthetic ATF
ATF | Mobil 1 Synthetic ATF
Auto Locking Front Differential for On-Demand 4WD - The Hilliard Corporation
BCRacing24 is offline   Reply With Quote
Old May 7th, 2013, 06:02 AM   #11
dproc870's Avatar
First Name: david
Member #36176
15W-50 Synthetic Oil | Mobil 1™ 15W-50
ATF | Mobil 1™ Synthetic ATF
polaris ps4 plus is 0w-40 ps4 xtream is 2w-50 i use maxima 15w-50 extra in mine my rzr was using 6 oz every 40 miles of the ps4 oil , the maxima oil stopped the oil usage
Old May 7th, 2013, 07:40 AM   #12
dproc870's Avatar
First Name: david
Member #36176
as far as mobile one i thought about using it but alba racing said you need to use a motorcycle approved oil and mobile 1 is for car engines , but alot of people use mobile 1 with good results
Old May 7th, 2013, 10:55 AM   #13
BCRacing24's Avatar
First Name: Brian
My RZR: 2016 XPT-4
Member #20030
Engine oil question
[quote=dproc870;1353716]
NO.............
PLus is 5-50 http://purepolarisoil.com/product_detail.asp?id=4
Extreme is 10-50 http://purepolarisoil.com/product_detail.asp?id=53
Sent from my iPhone 4s using Tapatalk
Member #247
Old May 7th, 2013, 11:08 AM   #14
dproc870's Avatar
First Name: david
Member #36176
[quote=BCRacing24;1353985]
NO.............
PLus is 5-50 PURE POLARIS OIL
Extreme is 10-50 PURE POLARIS OIL
my owners manual says use ps4 or equ. 0w40
Old May 7th, 2013, 11:14 AM   #15
BCRacing24's Avatar
First Name: Brian
My RZR: 2016 XPT-4
Member #20030
We had over 700mi on both our 570's we traded in for the XP4. I used Mobil 1 0-40 & Mobil 1 M1-110 or WIX 51356 filter from day 1 (literally day 1) NEVER a problem what so ever out of either unit. I am running Mobil 1 15-50 in the XP4. If you wanted to strictly use Motorcycle oils "JASO" only I would recommend the 4T 10-40 or V-Twin 20-50 depending on your weather conditions.
Motorcycle Oil | Mobil 1
engine oil for polaris rzr 900
mobil 1 fully synthetic 10w30 in a polaris ranger
mobil 1 oil in my 2011 polaris rzr 900
oul for 2013 polaris rzr 900
polaris engine oil weight
polaris ranger 900 xp engine oil specs
ps-4 oil substitute maxima
razzer engine oil
recommended weight o synthetic oil for polaris atv's
rzr xp 4 oil brand
what kind of oil for polaris rzr 900
what kinda oil goes in a 2011 rzr 900
what oil to put in a 2015 ranger 900
what type oil in 2011 rzr xp 900
xp 900 oil capacity
engine RPM question Contentsunderpressur Engine and Drivetrain 4 March 22nd, 2011 06:36 PM
Just a question about the XP engine Chopjaw Engine and Drivetrain 5 February 21st, 2011 01:02 PM
engine swap question kedi General RZR Discussion 7 March 9th, 2010 05:20 PM
Quick question about the RZR Engine AndyBees General RZR Discussion 7 September 1st, 2008 08:57 PM
Engine brake question FatTireRacer General RZR Discussion 5 June 28th, 2008 09:52 PM
