Ported head, bigger valves, stage 3 cams, 11.5:1 comp pistons. How much is timing?? - Polaris RZR Forum - RZR Forums.net
This is a discussion on Ported head, bigger valves, stage 3 cams, 11.5:1 comp pistons. How much is timing?? within the RZR 900 Engine forums, part of the Technical category; I've ran this setup at 3 and 4 degrees advanced and no issues. I'm just wondering what others think or have ran for timing with ...
Go Back   Polaris RZR Forum - RZR Forums.net > Technical > RZR 900 Engine
Old August 27th, 2012, 11:06 AM   #1
Klutch's Avatar
Member #2493
View Klutch's Photo Gallery(0)
I've ran this setup at 3 and 4 degrees advanced and no issues. I'm just wondering what others think or have ran for timing with similar setups on premium pump gas. Thx.
Klutch is offline   Reply With Quote
Old August 27th, 2012, 11:34 AM   #2
poflo's Avatar
First Name: Don
My RZR: xp 900
Member #11987
View poflo's Photo Gallery(0)
Re: Ported head, bigger valves, stage 3 cams, 11.5:1 comp pistons. How much is timing
3 or 4 degrees initial or total timing... I know of a few guys running 7 to 9 degrees more timing on stock motors........I know what i think is stock timing and that seems way high....just my .02
poflo is offline   Reply With Quote
Old August 27th, 2012, 12:11 PM   #3
Smooth Moderator
roguedriver's Avatar
First Name: Ken
My RZR: 2011 900XP
Member #24045
View roguedriver's Photo Gallery(0)
Are you using a Power Commander? I stopped making power on the dyno at around 5deg above stock timing on the big end, so i run it around 3 to 4 above stock. I would assume your not gonna make much more power where your running now and could probably leave stock timing only in there to give yourself a little room for error and not really leave much power on the table as well.
Ken R.
roguedriver is offline   Reply With Quote
Old August 27th, 2012, 12:16 PM   #4
Feedback Score: 176 reviews
swingarm1's Avatar
First Name: Tim
Member #7690
Listen to Don and save yourself a lot of $$$$...
Old August 27th, 2012, 06:25 PM   #5
Klutch's Avatar
Member #2493
So I;m running up to four over stock with 11.5 comp pistons. Is that safe with pump gas? Or should I stay at 3?
Old August 27th, 2012, 06:38 PM   #6
AlbaNate's Avatar
Member #24131
View AlbaNate's Photo Gallery(0)
You know my opinion on the topic Cole...
Nate
Alba Racing
NATE@TEAMALBARACING.COM
LIKE ME AND ALBA!!!
Check us out on Yelp.
AlbaNate is offline   Reply With Quote
Old August 27th, 2012, 06:44 PM   #7
swingarm1's Avatar
First Name: Tim
Member #7690
Nate
Alba Racing
He's his own worst enemy...
Old August 27th, 2012, 06:48 PM   #8
poflo's Avatar
First Name: Don
My RZR: xp 900
Member #11987
Nate has had a lot of motors on the dyno......He is a great person and shouldn't steer you wrong........if you are using his combination,I would go with what he says.........not every builder has the same ideas or knowledge,so what I suggest is what works for my builds(doesn't mean that there aren't others that work better)
Old August 27th, 2012, 06:52 PM   #9
AlbaNate's Avatar
Member #24131
We see the same on this 1 Don and Rogue found the same with his independent testing as well. I limit to 4 degrees advance over stock at any given rpm. Anyhting past that we started seeing a drop in HP and a need for additional octane.
Nate
Alba Racing
LIKE ME AND ALBA!!!
Old August 27th, 2012, 06:59 PM   #10
poflo's Avatar
First Name: Don
My RZR: xp 900
Member #11987
I'm pretty conservative on timing.......I like to allow for changes in fuel & running hard on hot days......if I'm building a true race only motor,then good fuel is a must,......I then time to max torque & them back off 1 to 2 degrees....again my .02
Old August 27th, 2012, 09:07 PM   #11
Smooth Moderator
First Name: Ken
My RZR: 2011 900XP
Member #24045
I think you got the input you were looking for. I'm running 4 over max, and thats only at the top. I'm also running nothing but premium now and have a little room being at 6000ft. I'm also running stock CR. If i was running your CR, i'd just drop it back to stock timing to be safe and not worry about it. If i remember right, when i was on the dyno, the difference between stock timing up top and 4deg over was 1 maybe 2whp max. Nothing to write home about....
Ken R.
Old August 28th, 2012, 05:32 AM   #12
charlot's Avatar
Member #22932
View charlot's Photo Gallery(1)
if i remember right pass 6000rpm i put the timing back to 0 because i was loosing HP if I add timing. ( and i have pretty much the same setup as you)
Big thank to my sponsor for this season
Plxsport.com
Autopartsfreak.com
Elka suspension
charlot is offline   Reply With Quote
Old August 28th, 2012, 05:33 AM   #13
Klutch's Avatar
Member #2493
Nate
Alba Racing
True statement Tim!
I think I'll back it off to 3 degrees advanced. This motor runs pretty snappy, almost like a big 2 stroke twin in a sled.
Thx for the input guys.
Old August 28th, 2012, 05:43 AM   #14
Klutch's Avatar
Member #2493
Just thinking now, do you guys run the same timing every where in the rpm/throttle range? I've just been running the same timing from low/mid to top end. As well as startup/idle range.
Old August 28th, 2012, 06:00 AM   #15
charlot's Avatar
Member #22932
No i use a different timming i will try to find my pcv file and i will send it to you
Plxsport.com
Autopartsfreak.com
Elka suspension
4deg cam advance ve tables
can i run a turbo on a rzr 900 with stage 3 cams
competition cam for polaris razor 800
do i need ported heads for stage 3 cams
do stage 3 cams work on pistons ??
high+performance+heads,+cams,+valves,+pistons+for+can+am commander
how much power gain ported head rzr
performance gains from ported head for rzr 900
polaris rzr 900 xp high compression piston compression test
porting rzr900 head
rzr 800 head porting
rzr 800 head porting gains
rzr900 high compression piston
stage three cam idle advance
stage3 cams for big valve head
Ported head gains? turbojamie RZR-S Specific Discussion 0 April 23rd, 2012 05:44 PM
ported cyl.head dr.vacation Polaris RZR Parts For Sale 3 January 12th, 2011 08:54 AM
high comp. pistons????? billrigg Engine and Drivetrain 19 December 17th, 2010 07:40 PM
weber pistons and valves 4 -sale sandracer1 Polaris RZR Parts For Sale 4 June 3rd, 2010 06:53 AM
