Fuel Problem - Polaris RZR Forum - RZR Forums.net
Fuel Problem
This is a discussion on Fuel Problem within the RZR 900 Engine forums, part of the Technical category; I have a 2010 Rzr LE Walker Evans Model. Two weeks ago, I was riding and had fuel problems. I replaced the pump with an ...
Go Back   Polaris RZR Forum - RZR Forums.net > Technical > RZR 900 Engine
Old August 25th, 2012, 06:36 PM   #1
BigSal46's Avatar
First Name: Don
My RZR: Walker Evans LE
Member #14190
View BigSal46's Photo Gallery(0)
Fuel Problem
I have a 2010 Rzr LE Walker Evans Model. Two weeks ago, I was riding and had fuel problems. I replaced the pump with an Airtech E 8335 model from Auto Zone. This seemed to correct the problem. Then last week, while riding in Utah Mountains, I stopped and turned off the Rzr. When I tried to start it, it would crank and not kick over. (I have a new Odyssey battery. ) no cranking problems. I pulled the passenger seat and removed the fuel line. It was under pressure and spilled out. I replaced the line and tried to start the engine. It started. This happened 3 more times in the next two days. Each time I pulled and re attached the fuel line and the Rzr restarted. This was in the rain.
Can anyone tell me what is wrong.
One of the guys riding with me in a Rzr said it may be a fuel check valve problem. When I push in the gas prior to starting, it opens the valve. However, the other times I had to restart the Rzr, I had been careful not to depress the throttle prior to turning the key.
BigSal46 is offline   Reply With Quote
Old August 29th, 2012, 05:50 PM   #2
charlot's Avatar
Member #22932
View charlot's Photo Gallery(1)
Re: Fuel Problem
i think your in the wrong section here is for the 900
Big thank to my sponsor for this season
Plxsport.com
Autopartsfreak.com
Elka suspension
charlot is offline   Reply With Quote
Old August 29th, 2012, 06:06 PM   #3
N0OSV's Avatar
First Name: Jim
My RZR: 2010 RZR
Member #29795
View N0OSV's Photo Gallery(0)
Rzr Icon Re: Fuel Problem
I would be interested to know if you take of the cap to the gas tank if it will start.
N0OSV is offline   Reply With Quote
Old August 29th, 2012, 10:33 PM   #4
BigSal46's Avatar
First Name: Don
Member #14190
Re: Fuel Problem
Removing the Fuel Cap does not take care of the problem. I tried this.
Old August 30th, 2012, 01:32 AM   #5
N0OSV's Avatar
First Name: Jim
My RZR: 2010 RZR
Member #29795
Sound like vapor lock in the fuel rail. There was another thread that was having the same issue a couple weeks ago. I will see if I can find it and get you connected with it.
Old August 30th, 2012, 06:44 AM   #6
N0OSV's Avatar
First Name: Jim
My RZR: 2010 RZR
Member #29795
The thread was "hard to start when warm" Take a look and maybe you will get some ideas.
2010 polaris ranger fuel pump problems
2010 polaris rzr 800 s fuel pump problems
2011 polaris rzr 900 fuel problems
2012 polaris rzr 800 s fuel delivery problems
fuel problem
fuel starting problem polaris rzr
polaris rzr 800 fuel problems
polaris rzr 800 fuel pump problems
polaris rzr fuel pump problems
polaris rzr fuel valve
polaris rzr xp 900 fuel pump problems
rzr 800 fuel issues
Fuel Problem? sndnsno Engine and Drivetrain 3 January 21st, 2012 11:18 AM
Fuel pump problem damewood RZR XP 900 8 April 19th, 2011 07:29 PM
Fuel Gage Problem? roadsidedoc RZR 4 Specific Discussion 1 January 18th, 2011 08:30 PM
fuel problem pimp800 Engine and Drivetrain 9 November 26th, 2010 07:14 PM
09 fuel pump problem pes1004 Engine and Drivetrain 6 December 6th, 2008 07:10 PM
