water pump seal - design flaw!! - Page 2 - Polaris RZR Forum - RZR Forums.net
This is a discussion on water pump seal - design flaw!! within the RZR 900 Engine forums, part of the Technical category; Just guessing by the pictures and not knowing if their is a reason that is a bad dezigne. Needs to be an outlet for the ...
Go Back   Polaris RZR Forum - RZR Forums.net > Technical > RZR 900 Engine
Old May 19th, 2012, 09:21 PM   #16
edge22's Avatar
My RZR: RZR S
Member #20854
View edge22's Photo Gallery(0)
Re: water pump seal - design flaw!!
Just guessing by the pictures and not knowing if their is a reason that is a bad dezigne. Needs to be an outlet for the water if the seal goes bad (and not into the crank case). Has their been many people with this issue?
edge22 is offline   Reply With Quote
Old May 21st, 2012, 09:38 AM   #17
coker6303's Avatar
First Name: Russell Coker
My RZR: 2016 RZR XPT
Member #33144
View coker6303's Photo Gallery(0)
I don't think many have had a water pump seal go out, these are still new machines and without the external weep hole they should last a long long time (external weep holes can contaminate the back side of the seal).
I would rather replace the $7 seal more often than find water in my oil. I've got 2 options I want to look at.
#1 is putting another oil seal that is trimmed down between the original oil seal and the mechanical water pump seal but turned around backwards so it will hold pressure from the water pump side.
#2 is possible drilling a hole between the 2 seals if there is not enough room for #1 and only if the gap between the 2 falls outside the portion of the pump that fits inside the crank case.
i haven't pulled the mechanical seal out yet, been working on other projects and this is not a priority until the replacement comes in. I ordered 2 of both seals so I can see what mods can be done.
Russell Coker
-3P-
http://3pclutching.com/
coker6303 is offline   Reply With Quote
Old May 21st, 2012, 09:44 AM   #18
coker6303's Avatar
Member #33144
Also, I am going to my dealer that I have a good relationship with in the morning to discuss this problem. Owner is a stand up guy. Main reason being I want them to document for future record what caused the water to get in the motor because it is only a matter of time before the bottom end spins a bearing after being run with so much water in it. I have a 4 year extended warranty through an aftermarket company. It would be different if I had sunk the motor and damaged it myself.
I would really like to contact the regional Polaris rep and see if he has heard or seen anything like this yet because it is only a matter of time before someone locks a motor up from water in the oil due to a bad seal.
Russell Coker
-3P-
Old May 21st, 2012, 10:00 AM   #19
Wpeschel's Avatar
Member #35971
View Wpeschel's Photo Gallery(0)
I hope they take care of you. Also pm me who the dealer is. I'm west of Houston bout a hr or so.
2012 white lightning XP bone stock
2008 brute 750 not stock
Member local 341
Houston Fire Dept
Wpeschel is offline   Reply With Quote
Old May 21st, 2012, 10:57 AM   #20
Feedback Score: 8 reviews
milosusa's Avatar
First Name: milos
My RZR: 2011 XP Red
Member #1361
View milosusa's Photo Gallery(27)
Over the weekend I look in the service manual and don't think will be enough space between mechanical seal and oil seal to install extra seal, but maybe will look different when you take pump at parts.
milos
2015 Sandstorm F350 GSLR
09 Raptor 700
14 RZR XP Z1100
http://czechracingteam.com/
milosusa is offline   Reply With Quote
Old May 21st, 2012, 12:10 PM   #21
coker6303's Avatar
Member #33144
I don't think so either, but i'll take pics and measurements this afternoon if I get a chance to pull the pump an seals apart.
I might be able to take the oil seal to a seal house and get a double lip seal in the same size to take care of the problem.
Russell Coker
-3P-
Old May 21st, 2012, 03:34 PM   #22
coker6303's Avatar
Member #33144
update: the oil seal behind the water pump seal has a double lip so turning a seal around on the shaft is not going to do much good.
Looking at the main shaft through mine, the water pump seal has been out for a while, the shaft is pitted and rusty between the 2 seals. My take is the water pump seal start leaking quite a while ago and the oil seal did its job until the pressure against the sealing lip wore enough of a groove in the shaft that water starting going by.
Good news is there is room to put an external weep hole between the 2 seals. Approx. 4.4mm of room to drill a hole and run a drain line down to monitor the seal leakage. i'll see what I can find.
Russell Coker
-3P-
Old May 25th, 2012, 05:34 AM   #23
coker6303's Avatar
Member #33144
I couldn't find a fitting with thin enough walls to drill and press into the water pump housing. I put it all back together and my milking situation is fixed! I'll try to find a peice of stainless tubing to press in there and run a tube off of for a tattle tale.
Russell Coker
-3P-
Old August 1st, 2012, 10:57 AM   #24
Kurtisp's Avatar
Member #37648
View Kurtisp's Photo Gallery(0)
Did you ever get a tube to fit in the weep hole? I have a weep hole but can't think of a way to run tubing for a tattle tale
Kurtisp is offline   Reply With Quote
Old August 8th, 2012, 11:15 AM   #25
coker6303's Avatar
Member #33144
I don't recall seeing that weep hole on my unit. I got in a hurry and did not rig anything up, just put it back together stock. There is not much room between the 2 seals to open it up for a piece of tubing to press in.
Russell Coker
-3P-
2008 ranger 700 water pump tool
2014 ranger 900 water pump removel
2015 900s leaking around water pump
how to remove rzr 900 water pump
how to replace water pump on rzr xp 900
polaris rzr 900 xp water pump seal
polaris rzr xp 900 water pump mechanical seal tool
ranger 900 water pump for sale
rzr 800 getting water in crankcase head gasket
rzr 800 water pump seal broke
rzr 800s water pump shaft
rzr 900 water pump
water pump test
xp 1000 water pump replace
youtube rzr waterpump replace
Changing a Water Pump Seal chipper Engine and Drivetrain 85 November 18th, 2016 01:54 PM
2011 RZR Water Pump Seal StopShort General RZR Discussion 9 July 20th, 2014 07:22 AM
2011 water pump seal StopShort Engine and Drivetrain 4 May 4th, 2014 10:14 PM
Water Pump Seal? Demoman Engine and Drivetrain 17 September 2nd, 2011 12:27 AM
Another water pump seal ?? jmarx82 Engine and Drivetrain 2 July 1st, 2011 07:27 AM
