2012 XP 900 drive shaft Center Support / Carrier Bearing Replacement - Page 2 - Polaris RZR Forum - RZR Forums.net
This is a discussion on 2012 XP 900 drive shaft Center Support / Carrier Bearing Replacement within the RZR 900 Engine forums, part of the Technical category; Could someone post a photo of how the 2012 bearing is mounted? I'd prefer adapting my 2011 to the 2012 style..which is an actual automotive ...
Go Back   Polaris RZR Forum - RZR Forums.net > Technical > RZR 900 Engine
Old May 10th, 2012, 03:11 PM   #16
HIGHOCTANE's Avatar
Member #16360
Re: 2012 XP 900 drive shaft Center Support / Carrier Bearing Replacement
Could someone post a photo of how the 2012 bearing is mounted? I'd prefer adapting my 2011 to the 2012 style..which is an actual automotive isolated D/S hanger bearing versus the 2011 pillow block style( if feasable ). I know it mounts completely different..would just like to see how they designed the mount.
HIGHOCTANE is offline   Reply With Quote
Old May 10th, 2012, 03:37 PM   #17
eabigrick's Avatar
First Name: anthony
My RZR: 900 xp
Member #32126
View eabigrick's Photo Gallery(0)
does that toyota bearing have a grease zert? if not its going to break down just as fast as the stock one. not saying that the pillar block bearing i have is the best way to fix the issue but its greasable and that means a lot to us guys that submerge this things in water and mud
eabigrick is offline   Reply With Quote
Old May 10th, 2012, 06:35 PM   #18
Gunner56's Avatar
First Name: Dean
My RZR: 2016 Rzr 900 4 orange
Member #26763
View Gunner56's Photo Gallery(0)
The timken bearing does not have a grease fitting. I'll probably have to go to a pillow block eventually. This was a quick fix & the bearing was only $78 at autozone. Here is a pic of where the 2012 bearing mounts.
Gunner56 is offline   Reply With Quote
Old May 10th, 2012, 06:37 PM   #19
HIGHOCTANE's Avatar
Member #16360
Old May 10th, 2012, 07:16 PM   #20
eabigrick's Avatar
First Name: anthony
My RZR: 900 xp
Member #32126
The pillow block 119 bearing is only 80 bucks and only thing you have to do is get a bolt a half inch longer and it bolts right up. And then for us water/mud guys pop 3/4 hole in the side of the shifter console and easy greasing during maintenance
Old May 11th, 2012, 04:48 PM   #21
Smooth Moderator
roguedriver's Avatar
First Name: Ken
My RZR: 2011 900XP
Member #24045
View roguedriver's Photo Gallery(0)
Do you have a manufacturer and part number for this bearing?
Ken R.
roguedriver is offline   Reply With Quote
Old May 11th, 2012, 05:27 PM   #22
MotoXman's Avatar
First Name: Lee
My RZR: XP900
Member #1509
View MotoXman's Photo Gallery(0)
So what is the fix for the 2011 and the part number for it? Any help is appreciated.
-LEE- It's not a bike!
MotoXman is offline   Reply With Quote
Old May 11th, 2012, 07:22 PM   #23
eabigrick's Avatar
First Name: anthony
My RZR: 900 xp
Member #32126
There are several company's that make pillow block bearings. Basically just go to your local napa or parts store and tell them you want a "119 pillow block bearing". This is the style bearing used on bush hogs of many brands so it's just all you got to tell them that's what your looking for and they can get you going
Old May 15th, 2012, 09:14 AM   #24
MotoXman's Avatar
First Name: Lee
My RZR: XP900
Member #1509
Would this one work on the 2011? http://www.amazon.com/Browning-VPE-119-Bearing-Eccentric-Contact/dp/B007PVAH1E/ref=reg_hu-rd_add_1_dp Does the pillow block come close to hitting anything? Not sure if I would need one with a shorter profile than this? Thanks for any input on this, I need one for my trip to Nevada this month and would like to have a spare.
Old May 22nd, 2012, 05:17 AM   #25
mane3215's Avatar
Member #26389
View mane3215's Photo Gallery(0)
So to be clear, this 119 Pillow Block will fit the 2011 correct? Going riding this weekend and mine just went out last weekend. Not many hours, bit of a let down.
mane3215 is offline   Reply With Quote
Old May 23rd, 2012, 08:35 PM   #26
sgracing's Avatar
Member #16301
View sgracing's Photo Gallery(0)
My 2012 VooDOO blue has 125 miles and is broken!! im pissed polaris wont even sell the part they say they are working on the problem i have to wait till 6/15/2012 before any dealer will get the new part. My buddy owns the polaris dealer here and has tried everything to fix this for me what should i do ????
sgracing is offline   Reply With Quote
Old May 23rd, 2012, 08:59 PM   #27
Redstroke's Avatar
First Name: Adam
My RZR: XP900
Member #39003
View Redstroke's Photo Gallery(0)
Good deal, now I know what to go with when mine fails... thanks guys..
2012 XP900 Red, 28x10x12 28x12x12 Mudlites, Warn RT40 4000 lb winch, STM Rage 6, Gen 2 Tuner Secondary, Tusk Roof and Back, Half windshield, S3 High Clearance Rear Lower Radius Arms, UTV INC Gusset Kit, Front and Rear .120" wall bumpers.
Redstroke is offline   Reply With Quote
Old May 24th, 2012, 09:36 AM   #28
MotoXman's Avatar
First Name: Lee
My RZR: XP900
Member #1509
I went ahead and got this one: http://www.amazon.com/Browning-VPE-119-Bearing-Eccentric-Contact/dp/B007PVAH1E/ Hopefully it will fit. I will keep it with me for spare parts for now.
Old May 24th, 2012, 05:59 PM   #29
skipdaddie's Avatar
First Name: Scott
My RZR: 2012 XP LE & 2010 RZR S LE
Member #9035
View skipdaddie's Photo Gallery(0)
Have your dealer install the Carrier bearing out of a 2003 Tacoma 4 x 2. The Polaris part was on back order until 5/10/12, but they keep extending it.
2014 XP4 1000
2012 XP4 LE (sold)
2012 XP900 LE (sold)
2010 800 S LE (sold)
2009 800 LE (sold)
skipdaddie is offline   Reply With Quote
Old June 8th, 2012, 04:53 PM   #30
sledge42's Avatar
First Name: kev
My RZR: 2011 RZR4
Member #36599
View sledge42's Photo Gallery(0)
guys the 2011 has a 30mm bearing so a pillow block 30mm will be a good fit i found them on
BearingsOn.com: Pillow Blocks, 2-Bolt, 3-Bolt, 4-Bolt Flanges, Radial Ball Bearings, Insert Bearings cast iron with a zert for 12.49....cant beat it
sledge42 is offline   Reply With Quote
'13 800 crew carrier replacement bearing
2012 rzr 900xp carrier bearing
2013 900xp rzr carrier bearing pillow block
2015 rzr 1000 center support bearing
900 xp carrier bearing
bearing de centre pour rzr 900 s 2015
best replacement center support bearing for rzr 1000
how to check carrier bearing rzr 900
polaris flex bearing replacement
polaris ranger carrier bearing swap with toyota
polaris ranger crew pillow block 30mm
rzr 900 carrier bearing
rzr 900 driveshaft aglinement
rzr 900 xp carrier bearing
WTB drive shaft (prop shaft is what polaris calls it) CREES Polaris RZR Parts For Sale 2 May 24th, 2011 07:36 PM
Do you get the bearing when you buy a new oem carrier? savk Suspension 2 December 11th, 2010 09:35 PM
09 RZR Carrier Bearing L & R wheelman20012002 Polaris RZR Parts For Sale 0 October 11th, 2009 04:43 PM
New drive/prop shaft replacement... freedom24 General RZR Discussion 2 September 22nd, 2009 04:18 PM
I have a front prop shaft/drive line/drive shaft part #1332439 twvette Polaris RZR Parts For Sale 8 June 6th, 2009 09:36 AM
