Crank case vent - excess condensation?? - Polaris RZR Forum - RZR Forums.net
This is a discussion on Crank case vent - excess condensation?? within the RZR 900 Engine forums, part of the Technical category; Anyone notice all the moisture developing in the top of the oil fill area and in the crank vent hose? It is much worse on ...
Go Back   Polaris RZR Forum - RZR Forums.net > Technical > RZR 900 Engine
Old February 27th, 2012, 11:00 AM   #1
coker6303's Avatar
First Name: Russell Coker
My RZR: 2016 RZR XPT
Member #33144
View coker6303's Photo Gallery(0)
Anyone notice all the moisture developing in the top of the oil fill area and in the crank vent hose? It is much worse on mine now with the added resistance of extending the vent hose with the snorkels
coker6303 is offline   Reply With Quote
Old February 27th, 2012, 11:29 AM   #2
Sand Pimp
DunerRZR's Avatar
First Name: Jeremy
My RZR: 2011 RZR XP LE
Member #10418
View DunerRZR's Photo Gallery(33)
Re: Crank case vent - excess condensation??
I have a filter at the end of the stock hose (where the OG air intake was) and I ride the sand, There are alot of oil fumes that sand sticks to.
2011 RZR XP LE
2011 Megacab Cummins
2007 Weekend Warrior SLC 3705
DunerRZR is offline   Reply With Quote
Old February 27th, 2012, 11:52 AM   #3
Feedback Score: 176 reviews
swingarm1's Avatar
First Name: Tim
Member #7690
Very tipical to have vapor... Also Polaris put a slit in that line that allows sepage...
Old February 27th, 2012, 01:10 PM   #4
coker6303's Avatar
Member #33144
ya, i removed the stock line that had the slit in it.
Just seems crazy that these motors are producing so much vapor/steam. i'm just worried about it backing up into the motor and milking the oil leading to a spun bearing. Our high compression rotax motors build more than stock but this 900 is crazy.
I'm going to pull the bed and separate the canister when I get a chance. I want to see how exactly it is made and see if anything can be done to help.
Old February 27th, 2012, 07:02 PM   #5
coker6303's Avatar
Member #33144
pictures of what I am talking about. The oil itself isn't milking but I'm certain the top of the tank will fill to the point that it will get into the engine oil over time.
Old March 5th, 2012, 11:40 AM   #6
coker6303's Avatar
Member #33144
more pics. I took the bed off and removed the oil reservoir to flush and clean everything. Even the valve cover vent line had this crap backed up in it so I know its on the valve train. I'm in the process of flushing the motor good so everything should be fine.
I rerouted my vent hose right back into the air box so their is no resistance and should eliminate the build up.
FYI, this was from 1 ride.
Old March 5th, 2012, 11:54 AM   #7
BarRZR's Avatar
My RZR: 2012 RZR 800-S L/E
Member #32278
I'm no expert, but that sure looks like "milked" oil to me, or at least oil vapors mixed with a liberal quantity of water vapor; just saying.......
Cheers
Old March 5th, 2012, 12:04 PM   #8
coker6303's Avatar
Member #33144
Neither the crank case or reservoir oil was milked, but technically what you are looking at is "milked" oil. The dipstick pulls clean oil and the oil drained is perfectly clean with not even a streak of moisture. This saturaded oil is only on the venting side of the oil circuit.
There is no doubt that it is from the crank vapors condensating in the top of the reservoir and in the crank case vent line. Motor has not been sunk and water wasn't that deep on the first ride.
I had a loop in my crank case vent plus it was extended to the top of the cage. I always loop my case vents because if they do get sunk at least it will catch the water for me to unconnect and blow out backwards. In this case, it caused to much back pressure and had a negative effect. I have a clear 3/4" line going straight to the air box to test the effects.
Old March 5th, 2012, 12:20 PM   #9
BarRZR's Avatar
Member #32278
"........The dipstick pulls clean oil and the oil drained is perfectly clean with not even a streak of moisture........." Whew!; had me worried there for a bit!
"......In this case, it caused too much back pressure and had a negative effect. I have a clear 3/4" line going straight to the air box to test the effects.......". Yes, that makes perfect sense to me, since vent-line pressure is so low that it would be easily overcome by line-resistance in a long tube, leading to stagnation. The line going straight to the airbox should solve your problem.
Cheers
Old March 11th, 2012, 06:57 PM   #10
coker6303's Avatar
Member #33144
check it out. Here is a video of my 900 idling at operating temp, fan has already cycled. You can see how much blow by and steam I have coming out. On other motors I have been around, we haven't seen this much venting unless we are running 12.5:1 or higher compression pistons.
Still driving me nuts! It doesn't milk the oil or leave traces. but the condestation continuously lines the upper chamber of the oil reservoir.
Motor has not been sunk, this is not the same as milking the oil itself so don't get confused. Motor is bone stock with 500 miles. I am running an advanced tune with each cylinder tuned out using my PC5 and dual autotune.
Notice the white on the threads inside the can, the entire upper will coat itself with a mixture of oil vapor and condensation.
Old March 12th, 2012, 05:58 AM   #11
Klutch's Avatar
Member #2493
View Klutch's Photo Gallery(0)
That's close to what I'm seeing for venting. 95mm big bore and 11.1:1 pistons in mine. Do you notice any oil consumption? How much?
Klutch is offline   Reply With Quote
Old March 12th, 2012, 07:38 AM   #12
coker6303's Avatar
Member #33144
I change my oil too much to tell consumption. No haze or puff out the exhaust that I or anyone in the group has seen.
I would expect it on a larger bore higher compression motor.
Is yours causing the upper chamber to build up milky oil on the walls?
Old March 12th, 2012, 12:06 PM   #13
Klutch's Avatar
Member #2493
No, and I check my oil daily. That milky build up has me stumped. Is it cold where you are? Is the machine in the cold when you start it?
Old March 12th, 2012, 01:47 PM   #14
coker6303's Avatar
Member #33144
I'm in Houston, TX so humidity could be an issue. It has been very cold last couple of times I've been riding so condensation could easily have built up but I would expect it to burn off or go away after a while.
I'm confident my original crank case vent hose route caused the condensation build up in the can originally but I have since pulled the oil reservoir and thoroughly cleaned everything. I'll be going no a short ride this week and then a 4 day ride the last weekend of the month. We will see how it does then.
Old May 21st, 2012, 09:47 AM   #15
coker6303's Avatar
Member #33144
The excess condensation was most likely caused by the water pump seal beginning to leak. If you see signs of moisture in the top of your dry sump tank like I did, go ahead and change the $7 water pump seal as a precaution.
See here for my findings
http://www.rzrforums.net/rzr-900-eng...gn-flaw-2.html
Russell Coker
-3P-
http://3pclutching.com/
2011 900 rzr blowing crank seals
900 rzr external oil tank moisture
condesation in engine crankcase
crack in the crankcase polaris rzr900
crank case breather for a xp900 polaris
crank case vent rzr 800 s
engine knock at high rpm
excess engine moisture
is motor condensation fine in atvs
polaris rzr 900 crank seal blowing out of case
rzr 900 xp dry sump vent line
rzr crank case steam
rzr900 breather
what cause a dry sump engine to put steam in dry sump tank
what causes crankcase condensation
Cracking the case to get to the crank FunRide Engine and Drivetrain 90 October 18th, 2016 03:29 PM
2011 rzr s crank case vent wiskeyman RZR-S Specific Discussion 7 November 26th, 2011 11:59 AM
Crank case swap help!!! jwams Engine and Drivetrain 1 April 22nd, 2011 01:38 PM
crank case vent hose jls189 Engine and Drivetrain 3 March 13th, 2010 01:28 PM
condensation in vent line supertuner General RZR Discussion 0 June 12th, 2008 06:47 PM
