front sway bar? - Polaris RZR Forum - RZR Forums.net
post #1 of 21 Old January 16th, 2013, 12:06 AM Thread Starter
mgammon's Avatar
First Name: michael
My RZR: 2010 rzr 800
Member #45357
View mgammon's Photo Gallery(0)
front sway bar?
i have a 2010 50" rzr 800 with stock springs and shocks, i have been thinking about taking the front sway bar loose for better flex. I do not do a lot of fast riding, most of what i do is slow trail riding, climbing hills, and some rock crawling. i am planning on leaving the rear sway bar connected in case i do decided to sling it around a corner lol. wondering if anyone has an opinion? i have read that it will be the best thing i can do but wonder about it with the stock springs and shocks.
mgammon is offline
post #2 of 21 Old January 16th, 2013, 12:14 AM
Kymedic's Avatar
First Name: Brad
My RZR: 2011 RANGER RZR® 800 Boardwalk Blue/White LE
Member #18622
View Kymedic's Photo Gallery(0)
I did it with stock springs and loved it. I tried taking the rear off too and it was great for articulation but really let it roll when going into curves hot. I put the rear back on until I went with LT suspension.
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
Kymedic is offline
post #3 of 21 Old January 16th, 2013, 07:31 AM
quint1510's Avatar
First Name: Quint
My RZR: 2011 RZR 800 Camo
Member #28870
View quint1510's Photo Gallery(0)
Re: front sway bar?
took the front sway bar off mine and will never but it back on
quint1510 is offline
post #4 of 21 Old January 16th, 2013, 07:56 AM
rardoin's Avatar
First Name: robin
My RZR: 2010 RZR LE +3
Member #16043
Re: front sway bar?
Michael...real easy to decide for yourself. Just disconnect the lower mount for the vertical link on one side and zip-tie up and out of harms way then take a ride. If you don't like it just reconnect, if you do then you can leave it that way or pull the whole bar/links out completely.
rardoin is offline
post #5 of 21 Old January 16th, 2013, 10:18 AM
leadsled01's Avatar
My RZR: 2016 wolverine
Member #42632
View leadsled01's Photo Gallery(0)
Re: front sway bar?
I have both the front and rear disconnected and love it! It rides alot better with not much body roll.
leadsled01 is offline
post #6 of 21 Old January 16th, 2013, 02:54 PM
toomanytoys's Avatar
My RZR: 2010 RZR 800 LE
Member #47688
View toomanytoys's Photo Gallery(0)
Re: front sway bar?
My advice would be at least upgrade your springs before disconnecting. The stock shocks sag enough as it is.
toomanytoys is offline
post #7 of 21 Old January 16th, 2013, 02:56 PM
Goodtimes
BlackRhinoSteven's Avatar
First Name: Steven Bell
My RZR: S
Member #36644
View BlackRhinoSteven's Photo Gallery(4)
Re: front sway bar?
I like the above post, Its easy to do, so give it a shot. if you like it off you will want to do a spring up grade down the road.
Setting the trend for today's EXTREME SideX Sides"
Shop online and like us on facebook
Steven Bell (619) 561-5000
Web
http://www.blackrhinoperformance.com/
Facebook
http://www.facebook.com/BlackRhinoFanPage?ref=ts
BlackRhinoSteven is offline
post #8 of 21 Old January 16th, 2013, 06:04 PM
317pro's Avatar
Member #45917
View 317pro's Photo Gallery(0)
Re: front sway bar?
I took mine off and put the Racer Tech RZR 800 50" Quick Disconnect Front Sway Bar Kit on mine. That way I can easily connect or disconnect the front sway bar. It works great and was very easy to install. I did find that I get some spring sag and loose some ground clearance when they are disconnected. I have the 2011 Walker Evans model. I'll be ordering the Racer Tech heavy weight replacement spring kit in the spring.
RZR 800 50" Quick Disconnect Front Sway Bar Kit - Racer Tech - Performance UTV Parts Store
317pro is offline
post #9 of 21 Old January 16th, 2013, 06:28 PM Thread Starter
mgammon's Avatar
First Name: michael
Member #45357
Usa Re: front sway bar?
does this disconnect kit work with the stock sway bar links if so then this will be my best option i believe until i can order better springs/shocks
mgammon is offline
post #10 of 21 Old January 16th, 2013, 06:30 PM
317pro's Avatar
Member #45917
Re: front sway bar?
Yes. Check out the link. Mr RZR is totally stock. Thats exactly what I'm doing.
317pro is offline
post #11 of 21 Old January 16th, 2013, 06:31 PM Thread Starter
mgammon's Avatar
First Name: michael
Member #45357
then i am ordering them as we speak!
mgammon is offline
post #12 of 21 Old January 16th, 2013, 06:31 PM
dogcatcher's Avatar
First Name: Jason
My RZR: 2016 RZR XP 1000 Sunset Red
Member #8488
View dogcatcher's Photo Gallery(0)
Re: front sway bar?
X2. I loved mine without sway bars
dogcatcher is offline
post #13 of 21 Old January 16th, 2013, 10:36 PM
switzomatic's Avatar
Member #38370
View switzomatic's Photo Gallery(0)
Re: front sway bar?
Had to disconnect mine when I added the walker evans shocks because it would'nt mount with them. I assume the walker evans models have a different sway bar link up top or something. Anyway, a lot of my riding is like you mentioned and have had no issues. No need for a disconnect system-a couple of zip ties(good ones) to the frame and it's out of the way.
09 RZR 800 Camo J-Strong Roof/Light Bar
3" Roktek Lift/12" STI beadlocks w/ 30" Mambas
Walker Evans shocks Big Gun exhaust/EPI clutch
UTV tilting windshield/rear roll-up shield
Full two-piece doors UTV airbox w/snorkels
Too many other odds and ends
2010 Scrambler 500 HO
Lifted 07 Ram Big Horn Hemi Crew 4x4 to haul 'em
switzomatic is offline
post #14 of 21 Old January 16th, 2013, 11:07 PM Thread Starter
mgammon's Avatar
First Name: michael
Member #45357
Re: front sway bar?
well i talked myself out of the disconnect for right now, going to try to unhook it and swing it out of the way. if i like the way it rides then i might order the disconnects. i appreciate all of the ideas and thoughts.
mgammon is offline
post #15 of 21 Old January 17th, 2013, 06:11 AM
olddognewtrick's Avatar
First Name: Jim
Member #18785
Re: front sway bar?
Sway bars are only there to shore up a terrible suspension. The problem is they keep the entire suspension under a bind to provide stability, so if you rock into a hole with one front wheel, the shock goes through the entire car. If you get off camber in big rocks, it affects the opposite side, in a bad way...
Took me two years of reading up here, and healing up in my wallet, but truthfully, almost every downside and almost every new owner complaint about clearance, sag, handling, ride, etc can and will be cured by putting on a quality suspension upgrade, that is quality springs, and quality shocks.
When I did finally do that, the old shocks, springs, and both sway bars hit the dumpster at about the same time. I actually took a chop saw to remove my sways...
I don't think I could stand to drive a stocker for even a day knowing what I have sitting right here, there is that much difference.
2011 Pursuit Camo
olddognewtrick is offline
Front sway bar Taconick RZR 800 Specific Discussion 5 December 26th, 2012 06:48 PM
Front sway bar mxking03 General RZR Discussion 1 July 27th, 2012 02:36 PM
Front Sway Bar joshw_1981 General RZR Discussion 12 August 22nd, 2011 08:37 AM
front sway bar dbow32 RZR 4 Specific Discussion 2 June 24th, 2010 02:32 PM
Front sway bar milosusa RZR-S Specific Discussion 1 March 16th, 2009 05:52 AM
