Razor 800 Plow setups - Polaris RZR Forum - RZR Forums.net
This is a discussion on Razor 800 Plow setups within the RZR 800 Specific Discussion forums, part of the General RZR category; Post up your Plow setups. Want to see what everyone is using....
Old January 1st, 2013, 03:13 PM   #1
RC51's Avatar
My RZR: 800
Member #41097
View RC51's Photo Gallery(0)
2012 Polaris Razor 50" EPS
Homemade cab enclosure in progress.
http://www.rzrforums.net/showthread....=1#post1974765
RC51 is offline   Reply With Quote
Old January 1st, 2013, 03:42 PM   #2
Tiorum3's Avatar
First Name: Al
Member #10509
Re: Razor 800 Plow setups
Polaris plow mount with RM3 Moose 60 inch plow, moose winch line saver, polaris winch switch on a the gear shifter, tethered plow remote.
Bent the plow last year but got it straightened out over the summer.
Tiorum3 is offline   Reply With Quote
Old January 1st, 2013, 03:47 PM   #3
RC51's Avatar
My RZR: 800
Member #41097
Now that is an interesting setup. I have a 60" moose snow plow that has the push tube. All I need to convert it to front mount is the Polaris mount and the RM3 pushtube?
Old January 1st, 2013, 03:54 PM   #4
Tiorum3's Avatar
First Name: Al
Member #10509
I'd say yes. I bought that plow setup from the dealership so I would guess its readily available through Moose and or Polaris. I'd start with Moose since its all moose stuff. I liked that set up so you dont have to connect it under the machine.
Old January 1st, 2013, 04:04 PM   #5
RC51's Avatar
My RZR: 800
Member #41097
How did you bend your plow? Having mine for 10 years I haven't bent mine.
Old January 1st, 2013, 04:23 PM   #6
Tiorum3's Avatar
First Name: Al
Member #10509
Another stealership mess up. They never set the tension on the springs so they were almost loose. I was going forward faster than I should have been and plow came down and caught on the ground and bent it. I was pi$$ed. After setting the tension properly and got it unbent I havent had a problem since.
I should also add I have a plastic wear bar thats fit in between the metal bar and plow. I'm lucky we have a local plastics plant that makes it for the big snow plows and I got a piece and cut it into 2 bars. I have flipped it once a year. I'll put the next piece on over the summer if its worn enough again to require the next one.
Old January 1st, 2013, 07:44 PM   #7
BugBoyOne's Avatar
First Name: Rob
My RZR: 2012 800 & 2013 570
Member #30151
View BugBoyOne's Photo Gallery(0)
Eagle 72" plow with home-made rear-hitch mounted push tube. After using this a bunch this winter I think a 60" would be too narrow when angled, especially if you're going around curves.
BugBoyOne is offline   Reply With Quote
Old January 1st, 2013, 08:09 PM   #8
Oldog's Avatar
First Name: Sled
My RZR: Gen 2
Member #3377
View Oldog's Photo Gallery(0)
wow nice hook up
Sled
2005 Sportsman 800, winch, ITP mud lites 26"
2008 RZR 50" Sold it
2013 RZR Blue Fire LE 50", winch,Roof, half windshield
26" XTR, Walker Evens shocks and springs
Retired
Oldog is offline   Reply With Quote
Old January 1st, 2013, 08:19 PM   #9
Hunterworks's Avatar
First Name: Todd
My RZR: 2016 XP1000
Member #47437
We have had good success with the Motoalliance and have since dropped the Eagle brand, our choice on that. The motoalliance is heavier duty with the newest model than the Eagle and first model Moto had.
Depends on which RZR I had but would not get the 60" 66" min and 72" being the norm. Why? Turning on angle like mentioned above can leave a tire out in snow.
Todd
www.hunterworks.com
Todd
Office phone: 601-771-0070
Hunterworks is offline   Reply With Quote
Old January 2nd, 2013, 09:13 AM   #10
Goose2222's Avatar
My RZR: 2015 XP 1000
Member #34094
View Goose2222's Photo Gallery(0)
I purchased a 66" for my 50" razor and it works perfect. Couldn't be happier.
Goose2222 is offline   Reply With Quote
Old January 2nd, 2013, 09:59 AM   #11
Feedback Score: 31 reviews
IARZR's Avatar
First Name: Adam
My RZR: 2008 RZR 800
Member #44193
View IARZR's Photo Gallery(0)
I use a 60" Warn and love it. I angle the blade and dont have any issues with it no clearing the full width of the RZR and I have bigger tires and inch and a half spacers. For the record, I just have the 50" RZR too, so that makes a difference. I dont use the most extreme tilt because then the blade would be in the tires anyway. Ive used the Warn Plows on my ATV's and it made it an easy choice for the RZR as well. I like the fact that the mount is up and out of the way and I can leave it installed all summer. it doesnt take away any ground clearance.
I like the motoalliance plow system as well and probably would of went that route had they came out with it 2 months sooner than they did. Ive had zero issues with my Warn, but I can assure you that their service would be nothing like Moto's. You will be happy with either one.
IARZR is offline   Reply With Quote
Old January 2nd, 2013, 11:34 AM   #12
dcl
dcl's Avatar
First Name: Don
My RZR: 50"
Member #40394
View dcl's Photo Gallery(0)
I like your setup. Did you replace your plastic rope with a flat strap?
dcl is offline   Reply With Quote
Old January 2nd, 2013, 12:07 PM   #13
BugBoyOne's Avatar
First Name: Rob
Member #30151
Yep. Spooled out the rope fully and duct taped a cheap boat winch strap about 6' long. A few wraps on the drum makes it work. I kept the rope on there as its really tough to access the knot as easy to convert back to summer mode.
Old January 2nd, 2013, 03:50 PM   #14
I8ABUG's Avatar
First Name: Andy
Member #718
View I8ABUG's Photo Gallery(0)
I plow with a Polaris Glacier II 60" Plow on my RZR 800. I have used it for four years, and it works great. I use synthetic rope on the winch because the cable doesn't work too well plowing.
Name:	Plow 002 (1024x768).jpg
ID:	64510   Click image for larger version
Name:	Plow 004 (1024x768).jpg
I8ABUG is offline   Reply With Quote
Old January 2nd, 2013, 05:15 PM   #15
username taken's Avatar
Member #4050
View username taken's Photo Gallery(0)
Anybody tried it with a bucket attachment?
I was considering renting a skid loader to move some gravel around the property and fill a couple of low spots in a dirt driveway, but after seeing some of these set ups, I am wondering if this would be a better option - plus I'd have the rig full time.
username taken is offline   Reply With Quote
2000 sportsman plow mount
how to install a snow plow on a polaris rzr
polaris rzr 800 plow
polaris rzr dozer blade
polaris rzr eager plow hook up
razor set ups
recommend a snow plow for 2013 polaris rzr 800
rzr 800 s eps warn plow
rzr 800 snow plow size
rzr 800 warn plow mount 92100
rzr snow plow
snow plow for 2013 polaris 800s
snow plow for rzr 800
snow plows for 2013 polaris razor
will a 2015 polaris rzr 900 plow fit a 2012 800
Air filter setups peak-j Forced Induction 18 September 20th, 2012 06:40 PM
Best RZR S suspension setups RZR1313 Suspension 9 May 30th, 2011 04:27 PM
Simple MP3 setups jmccown Lighting, Stereo and Electrical 5 October 11th, 2010 02:56 PM
09 Razor - Green - 17 Hours - Denver, CO - Includes Plow, Winch and Warranty Jazman Polaris RZR Parts For Sale 10 March 18th, 2010 08:24 AM
IPOD setups? Muddawg Projects and How-To 10 August 28th, 2008 11:54 PM
