Tire size 50" RZR - Polaris RZR Forum - RZR Forums.net
Tire size 50" RZR
This is a discussion on Tire size 50" RZR within the RZR 800 Specific Discussion forums, part of the General RZR category; Don't mean to whip a dead horse here but.... I have a 2008 RZR 50" width. I want to replace the tires with something bigger,and ...
Old July 6th, 2012, 12:20 PM   #1
Feedback Score: 4 reviews
gmck154x4's Avatar
Member #42202
View gmck154x4's Photo Gallery(0)
Colorado Tire size 50" RZR
Don't mean to whip a dead horse here but.... I have a 2008 RZR 50" width. I want to replace the tires with something bigger,and not buy new rims,:greenrzr: or add spacers Will 26x11x12 rear and 26x9x12 fronts fit? I don't mind doing a little grinding on the motor mount if need be. Looking at some Bear claws over at RMATV. Are there any other tires that size anyone would recommend? :greenrzr:
gmck154x4 is offline   Reply With Quote
Old July 6th, 2012, 08:50 PM   #2
gmck154x4's Avatar
Member #42202
Re: Tire size 50" RZR
Anybody????
Old July 8th, 2012, 12:51 PM   #3
farmergunner's Avatar
First Name: jamie
My RZR: 2009 rzr
Member #8311
View farmergunner's Photo Gallery(0)
I have 26" on mine with 15" wheels. All are fine except the left front when I make sharp left turns. Then it runs the footwell. 1in spacers would
Get rid of that
farmergunner is offline   Reply With Quote
Old July 8th, 2012, 01:15 PM   #4
diver165's Avatar
My RZR: 900XP and an 800LE
Member #38076
View diver165's Photo Gallery(0)
You shouldn't have problems with those. Like was stated above, maybe some rubbing on compression during a turn but nothing that's a huge deal. I have 26x9x14 Big Horns and get a little rub when compressing the suspension and turning sharply.
diver165 is offline   Reply With Quote
Old July 8th, 2012, 01:38 PM   #5
rangermac's Avatar
First Name: Charles
My RZR: 2010 800 LE with Polaris Cab
Member #40658
View rangermac's Photo Gallery(0)
I have the new ITP Blackwater Evolutions in the 26 x 9 and 26 x 11 on 12 inch rims and they do fine. When the RZR is jacked up the inside wall tread of the rear tires just nip the edge of the plastic skid plate but I don't think it's rubbing when underway. There's no room to spare though.
rangermac is offline   Reply With Quote
Old July 8th, 2012, 05:20 PM   #6
chopperbill's Avatar
Member #443
26X9X12 Bighorns all the way around. They will work on you stock rear wheels if you grind the motor mount. Most folk buy fronts to put them on the rear, no grinding the mount.
chopperbill is offline   Reply With Quote
Old July 8th, 2012, 08:30 PM   #7
tanglefoot69's Avatar
First Name: Peter
Member #32425
View tanglefoot69's Photo Gallery(5)
27" Zilla's here,11's on the rear and 9's on the front,at full droop the right rear will rub the mount a little but not enough to have any issues.
2012 Sportsman 850XP LE EPS,F/R Deluxe Brushguards,Polaris 2500lb winch,Garmin Etrex 20 GPS.
tanglefoot69 is offline   Reply With Quote
Old July 8th, 2012, 08:32 PM   #8
"Dual Primed!"
Feedback Score: 11 reviews
desertvet1990's Avatar
First Name: Rick
Member #15483
Run 9's in front and 10's in rear, or 9's all around
Land of the Free,, Because of the Brave!!Freedom is'nt free,, I Payed for it!
Shock Therapy Springs
GET FULL COVERAGE INSURANCE!! DONT take the chance!!
desertvet1990 is offline   Reply With Quote
Old July 10th, 2012, 09:41 AM   #9
midnite1987's Avatar
First Name: Austin
My RZR: 800LE
Member #41907
View midnite1987's Photo Gallery(0)
Would 28x10 fit on all 4 corners on stock wheels with just spacers? If so what spacing?
Dont mean to hijack the thread
2012 RZR 800. SATV +5 kit. 2" racertech lift, 29.5 outlaws, snorkeled, 6.5" speaker pods, Prp doors.
2006 F350 6.0 powerstroke. 4.5" lift and 33's, livewire ts tuner, 4"turbo back dual exhaust, custom rack for rzr
midnite1987 is offline   Reply With Quote
Old July 10th, 2012, 09:55 AM   #10
Boozin' and Crusin'
Speed 1B's Avatar
First Name: Brady
My RZR: '10 LE
Member #16961
View Speed 1B's Photo Gallery(0)
You will need 4+3 wheels or spacers to clear the motor mount on the passenger side rear. I am running ITP wheels to get my clearence with the bighorns and i have just enough room to make it work.
2010 Stealth Black LE
26'' Bighorns
ITP SS212s
Lots of EMP goodies
Speed 1B is offline   Reply With Quote
Old July 12th, 2012, 10:54 PM   #11
First Name: Austin
My RZR: 800LE
Member #41907
28x10 zillas on all 4 corners.
1.5" rear spacer and molded the front floorboard
Old July 13th, 2012, 03:59 AM   #12
Dguillor's Avatar
Member #38825
View Dguillor's Photo Gallery(0)
I am running 28/10/12 EDL vampairs with 1.5 inch spacers with no problems
Dguillor is offline   Reply With Quote
Old July 13th, 2012, 11:34 PM   #13
rapidrobert's Avatar
First Name: Robert
My RZR: 2009 rzr170 air box update, 2012 RZR 800
Member #30065
View rapidrobert's Photo Gallery(0)
I have just gone through this on my 50" with stock rims and a 26x10-12 will rub big time. I ended up going with a stock size rears 25x10-12 set up with the gbc radial Spartans and they just clear the frame by 1/4 inch when jacked up on right rear.
I have been told if you run front rims all the way around you can run 26x9-12 and they will clear but a 26x10-12 will rub even on a front rim on the rear because I tried to do that before I went back to the stock size and it will not work. With out rubbing or modifying the mount. Rapidrobert...
A bad day on the trail is better than a good day at work!
rapidrobert is offline   Reply With Quote
Old July 13th, 2012, 11:54 PM   #14
First Name: Austin
My RZR: 800LE
Member #41907
with a 1/5" wheel spacer on the rear i have no issues with the 28x10-12 zillas...
and my rzr had 26x11 rear and 26x9 polaris tires on stock rims when i got it.... and they cleared just fine as they are what came on it....
Old July 14th, 2012, 11:15 PM   #15
First Name: Austin
My RZR: 800LE
Member #41907
1.5" not 1/5" oops
2008 polaires rzr tire wheel size
2011 polaris rzr 800 width
2011 polerace side by side 800 tire size
26 zillas on 50 rzr with no mods
best tire 50 rzr 800
how much is the 50 size polaris
modifying rzr 50 for bigger tires
polaris rzr tire size
poloris 50 tire size
rzr 800 with 28 tires
rzr sizes
stock tire size on 2008 rzr 800 50 ?
what size 2008 polaris rzr tires?
what size tire will fit a polaris rzr
will 26 tires fit my 2011 polaris rzr 800 stock
"2 rdc lift/ tire size?? Elroy Wheels and Tires 11 January 10th, 2016 09:51 AM
Tire size on 50"? Plz help scottrod Wheels and Tires 5 May 20th, 2012 09:44 PM
"WANTED" 1-stock front rzr-s tire w/rim 26x9x12 mabe same size on other rzr's (spare) PITBULL77 Want to Buy 3 September 30th, 2011 11:12 AM
9" Front & Rear tire size jmowens RZR XP 900 2 April 18th, 2011 08:27 PM
"WANTED" 1-stock front rzr-s tire w/rim 26x9x12 mabe same size on other rzr's (spare) PITBULL77 Polaris RZR Parts For Sale 0 March 1st, 2009 07:08 AM
