front cv boot - Polaris RZR Forum - RZR Forums.net
post #1 of 12 Old June 18th, 2012, 01:04 PM Thread Starter
ADKrzrlvr's Avatar
front cv boot
Just had my front outside cv boot replaced due to a pin hole in it and slow leakage, after I got it back from the shop I noticed the new boot was twisted and not looking like the other boots. After a few short rides the boot blew up!!! Grease all over, I called the guy who replaced it for the last two weeks and he won't call me back. I called a Polaris dealer and now he is saying prob something wrong with the axles/cvs and that why the boot is twisting...I originally found a pin hole and the original boot wasn't twisted at all...could something have happened when they replaced the boot...maybe unseated the axle??? It runs fine with no clicking or anything, not sure why all of a sudden the boot was all twisted then tore itself open....any help or suggestions would be greatly appreciated.
MakinTrax,SATV,Racertech,DragonFireRacing,FUTV,Uni Filter, EPI, Twisted Stitch, SidebySideSport, 27"BigHorns on DWT Beadlocks, WikedBilt, UTVinc, Fluidyne
ADKrzrlvr is offline
post #2 of 12 Old June 19th, 2012, 07:45 AM
I am still 16 in my head!
Feedback Score: 29 reviews
Kandgo's Avatar
Re: front cv boot
Without looking at it, I would think he put on the wrong boot? To big most likely.
Kandgo is offline
post #3 of 12 Old June 20th, 2012, 08:56 AM Thread Starter
ADKrzrlvr's Avatar
Re: front cv boot
the Polaris dealer just called and after putting on an aftermarket boot and 5 minutes riding around the boot started to twist again...he is ordering an o.e. polaris rzr boot and will try that...he said everything seemed good, cv's were turning fine no clicking or binding and doesn't understand why its doing this...no one else has any ideas????
post #4 of 12 Old June 20th, 2012, 10:28 AM
Kandgo's Avatar
Re: front cv boot
You don't have any Gaurds that have bent in. I have seen that twist em off. I would suggest they jack it up in the air and do full turn to turns and look at the boot then. If the CV is good then something is hitting the boot and causing the Twist.
Kandgo is offline
post #5 of 12 Old June 20th, 2012, 03:41 PM
revr's Avatar
Canada Re: front cv boot
must be a bad boot, the wrong boot, or a poor install.
revr is offline
post #6 of 12 Old June 22nd, 2012, 07:46 AM
rzr_max's Avatar
Re: front cv boot
if the guy did not clean the cup and the shaft properly and had a bit of grease on it while he tightened the clamp that will cause the boot to twist.
09- RZR black stealth le.
Team Alba BBK, 11:1 piston, "S"-cam, iTi full exhaust, Holz Oil PRV, mid exhaust porting.
RCI 4 point harness, Snorkel kit, polaris front bush bar, HD springs, 1" spacer front, 1.5" spacer back. polaris roof. 27-12-12 dirt devil2 tires on stock 12-6 crusher rims all four corners, 3500lbs warn winch
rzr_max is offline
post #7 of 12 Old June 22nd, 2012, 08:42 AM Thread Starter
ADKrzrlvr's Avatar
Re: front cv boot
it seems because i put on the forward a arms, aftermarket boots won't work...they would kink at full turn then get twisted and eventually disintegrate....this little bit of info cost me a lot even though I told them to use a stock boot, when they found out it wouldn't work they had to go far away to another polaris dealer to get the stock boot then rode it around for a while and charged me over $200, even though I told them from the beginning to use the stock boot...another shitty polaris service center!
post #8 of 12 Old June 22nd, 2012, 08:53 AM
rzr_max's Avatar
Re: front cv boot
I would not pay! You asked them for a curtain product and they did there own thing. Against what the customer asked for. I bet if the no name book worked they would have charged you for a Polaris one and never said a thing.
rzr_max is offline
post #9 of 12 Old June 22nd, 2012, 09:19 AM
jerrzr's Avatar
Re: front cv boot
Next time you have a pin hole in a cv boot, the black high heat gasket maker will seal it up. One of my inner rear boots had a pin hole that I used that stuff on thinking it may work temporary but to my surprise, its still holding after a year.
jerrzr is offline
post #10 of 12 Old June 22nd, 2012, 11:26 AM Thread Starter
ADKrzrlvr's Avatar
Re: front cv boot
Thanks for the tip jerrzr...will def do that next time, although the forward a arms do put a little more stress on the cv boots than the stock a arms but will def give the gasket maker a try...good ending to this story...the owner of the dealership met me at the counter...listened to me and charged me the normal rate for a stock boot replacement, little over a $100, will def go back there again since the owner was a stand up guy
post #11 of 12 Old June 27th, 2014, 08:23 PM
Muddonkey's Avatar
Re: front cv boot
I kind of have the same problem going on right now, I had an 8" S3 lift installed on a 1000 with the gorilla axles and the inside boots on the rear are heating up and exploding like balloons and I cant figure out what is causing it this is my second set of boots. its not low on fluid or anything and the axles are not at such a high angle that it could be causing cv binding that i can see. I called s3 and first they told me that the axles needed to be broke in lol,, then he told me i was driving too far too fast 2miles at 30-40mph lol. something is going on and I cant figure out where the heat is coming from weather it is the cv's or something in the rear end.
Any help would be greatly appreciated.
Muddonkey is offline
post #12 of 12 Old June 27th, 2014, 11:47 PM
bob7's Avatar
Re: front cv boot
I've never heard of that stuff being used for boots. Is there a brand name that works better than others? I have about a 1/8 inch puncture in my cv boot. Will it seal it? Is there a process that is needed when you apply it? How thick do you put it on? How wide do you make the 'patch'?
Thanks.
Bob
bob7 is offline
Front inner CV boot protection! RZR_WV General RZR Discussion 8 May 4th, 2012 04:42 PM
Cut a front inner CV boot today! jdboy RZR-S Specific Discussion 4 October 1st, 2011 09:00 AM
Front CV Boot Guards ClevelandRZR RZR XP 900 0 March 25th, 2011 12:31 PM
Inner Front CV Boot needed m741329 Polaris RZR Parts For Sale 0 June 17th, 2008 07:02 PM
Front cv boot great buy hellrazor General RZR Discussion 2 May 4th, 2008 07:57 AM
