Try leaving the Battery Unhooked for a bit, pull and check all the fuses, and for any burnt wires. You may get lucky and not have hurt anything.
21: Loss Synchronization
22: TPS: Open or Short Circuit to Ground
22: TPS: Short Circuit to Battery
23: RAM Error: Defective ECU
25: Transmission Input: Invalid Gear
41: Intake Air Temp Sensor: Open or Short Circuit to =Sensor Voltage(ECU)
41: Intake Air Temp Sensor: Short Circuit to Ground
42: Engine Tempurature Sensor Circuit: Short to Ground
42: Engine Tempurature Sensor Circuit: Open or Short to Battery
45: Barometric Pressure Sensor: Circuit Low Input
46: Barometric Pressure Sensor: Circuit High Input
51: Injector 1: Open Load
51: Injector 1: Short Circuit to Ground
51: Injector 1: Short Circuit to Battery
52: Injector 2: Open Load
52: Injector 2: Short Circuit to Ground
52: Injector 3: Short Circuit to Battery
54: Engine Temperature Lamp: Open Load
54: Engine Tempurature Lamp: Short Circuit to Ground
54: Engine Temperature Lamp: Short Circuit to Battery
55: Diagnostic Lamp: Open Load
55: Diagnostic Lamp: Short Circuit to Ground
55: Diagnostic Lamp: Short Circuit to Battery
56: Pump Relay: Open Load
56: Pump Relay: Short Circuit to Ground
56: Pump Relay: Short Circuit to Battery
10:00 at Calvin, down by the Fenced in Propane Tanks. I will be in a Red Mega Cab Dodge, there will be about 5 or 6 of us going. Check all your Fuses, sounds like you have some blown. Unhook the battery again while checking the fuses, just don't look at them, take them out and test them with a Meter. I have had fuses in the past look good, but were burnt where you cannot see.
We will unload directly North of the Town Cafe, go back behind the Gin Mill and down by the River.
Lot of the guys are from Macalester, Savanna, Kinta. We live up by Choctaw. We ride the River when it gets to hot to hit Kinta, Arkansas etc. We ride with a bunch of Folks down around Macalester, Kinta, Quinton area.
We have Principals/Teachers/Coaches from Macalester, Savanah, and all around that area in our Riding Group. You will probably know some of them. Not all of them are coming tomorrow. But you will get to meet em all eventually. LOL
And your more than Welcome to bring along any others that want to come ride, more the merrier on the River!
