Rear tire help - Polaris RZR Forum - RZR Forums.net
post #1 of 1 Old May 19th, 2017, 01:59 PM Thread Starter
DW-ID's Avatar
Member #199313
View DW-ID's Photo Gallery(0)
Rear tire help
Hello all, Im new to the forum, -my first post here and hope this post is going to the right place.
I have a 2011 standard -RZR 800 EPS- with Crusher wheels. Im about to buy 5 new tires 4 + a spare for it and would like- to buy Maxxis BH 26x12x12 tires for it (not the 2.0s) if I can use the 12 width w/out problems --but that's the question.
The machine currently has Duro Power Grip 26x11x12s on the rear using 7/8 spacers. The rt. tire sits very close to the motor mount but its OK and Ive had no problems. I know the Duros run small compared to Big Horns though so Im not sure what kind of problem I would run into in going to 12 wide BHs.
Does anyone out there use 26x12 BH on the standard 800 and if so, what did you end up doing to clear the motor mnt., wider spacers or?
Ive had standard BHs on an ATV for close to 3000 miles and still have over half the tread left and would like to use them on the rzr as well, if possible in a 26x12.
The rears on the ATV are -25x10x12- and are mounted on steel wheels. I put one of them on the Rt. rear of the RZR to see how it fit/looked to try and get an idea of how a 26x12 might fit but the ATV tires are mounted on steel wheels so I really couldnt tell because the steel wheels offset isnt as deep as the Crushers. It looks like I could probably use the 12s mounted on steel wheels and would sit out far enough to not be a problem but Id as soon stay w/the crushers if I could, since I have already them.
I can easily modify the motor mnt. by removing the rear vert. supt. and welding in vert. brace back under the edge of the horiz. plate if that would do it, but I'm thinking I'd still need a thicker spacer than the 7/8" that I have there now, if spacers would even do it?
Thanks much for any help/suggestions. DW
DW-ID is offline
Wheel offset vs Suspension performance Shock Therapist Shock Therapy 148 April 5th, 2017 06:09 AM
DIY Tire Changing BeadBuster Projects and How-To 0 November 28th, 2016 02:22 PM
Which Gets Blown/torn More often, Front or Rear Tire? DanW RZR 570 Specific Discussion 14 November 12th, 2016 06:24 PM
Rear tire size Bigg Dave RZR-S Specific Discussion 7 September 7th, 2016 02:00 PM
Xp900 rear cage extension and baja cross front tire ingeniusone7 Want to Buy 3 May 12th, 2016 01:16 PM
